I have a message that comes up whenever I try to open Adobe Photoshop CS4 Extended.
"Licensing for this product has stopped working.
This product has encountered a problem which requires that you restart your computer before it can be launched
If you continue to see this message after restarting your computer, please contact either your IT administrator or Adobe technical support for help, and mention the error code shown at the bottom of this screen.
Error 148:3
http://www.adobe.com/support"
I restarted several times but I still get the error. How do I fix this?
wow...wssparky thanks a TON.
I got the adobe error today and it was driving me INSANE. I *think* the problem had to do with my having to disable all my startup stuff in Windows7 to fix a problem I was having updating some other Microsoft software. Anyway MS said disable everything using the msconfig and it was after that when Adobe stopped functioning (my McAfee is having an issue as well) properly.
At any rate I got the adobe "fix" and it worked GREAT!
I was NOT having any luck to begin with by going to the support area at adobe.com (HEY ADOBE PEOPLE>> TAKE NOTE)
searching "support" for the error code tells me "Your search of Support for error 148:3 did not match any documents." which I find interesting ![]()
so I finally googled the error code and found this thread.
now a word to those who are less than kind in their posts and make people feel stupid for asking the question here...I would submit these forums are for us (the users) to help each other (read: be nice to each other) so we can USE the software we OWN.
I'm frankly disappointed that going to the Adobe "SUPPORT" was fruitless. MY problem was with the CS4 suite: I own the master collection which wasn't exactly cheap....it wold be nice if I, as a customer was able to at least FIND Adobe's OWN error code on their support section.![]()
again... thanks to wssparky ![]()
I had this error message yesterday, ironically, and the Adobe repair tool worked fabulously. I was getting a little worried when this happened, but the repair tool did what it was supposed to do perfectly.
No need to think that turning off the start up programs in Msconfig was the problem. It was the problem. Start up contains the main action for starting up the DRM for Adobe that is found in services. If you uncheck the wrong thing in startup, at least photoshop, will not run. Not sure about the rest of the Master Collection.
So next time you call a tech support up (lets say McAfee) and they tell you to turn off Startup items to troubleshoot just remember to go back in startup and turn the Adobe stuff back on and reboot. Otherwise it will be fun city all over again.
I wanted to update with some information.
I found that if you use a clean up tool like "Window Washer" it removes the Licenses Records for all Adobe Products.
Some other anti virus and clean up tools do the same.
If you can find the folder with the info, set these tools to ignore it.
Otherwise you'll have to run the License Repair after each cleaning.
I'm glad everyone is getting some use out of this. I know I was at my wits end when i found it.
I've been having problems with CS4 lately. I installed it about 2 months
ago and it worked perfectly. A couple days ago, I opened Photoshop, and
it gave me an error code that my serial number was invalid. I thought it
might have been the licensing error, so I tried that solution. It didn't
work. I tried to open CS4 again, and it didn't even open the program. It
gave me a window that said: "Run on a 30 day trial basis" or: "Enter
your serial number here:". I entered my serial number from the back of
my CS4 DVD case, and it said that it was INVALID! Why would it have been
valid 2 months ago, but doesn't work now? I contacted Adobe support, but
they have not gotten back to me.
I know you might well have solved this by now, but for any one els this
is is how i solved this problem on windows xp sp3 using indesign cs4
got to start on bottom of screen, then click on run, enter service.msc
on the list that now opens goto the line "flexnet licensing service" double click to open - make sure that the startup type is set to manual. then apply this and close. after i did this i could start indesign OK.
I know this is a forum and not tech support , but when you get lost around these sites like me, then like tesco, "every little helps"
Thank you wsssparky! I too had the problem (because of a problem yesterday another company's support had me clean up all the hidden startup programs in msconfig).
All I had was the mysterious 148:3 with the error asking me to restart the machine! (Thanks--that's 5 min. down the drain.)
Ran the licenserecover program and restarted Dreamweaver CS4. Perfect!
I have recently been cleaning up some of the programs in my computer in the hopes of getting it to load faster (bad idea for me). Photoshop was giving me the error message 148:3 and telling me to restart the computer. After reading these posts, I realized I had unchecked several startup services, one of which was FLEXnet Licensing service. When I rechecked this service and restarted the computer, Photoshop started without the error message. Problem solved - thanks to some of you on this forum!
Don,t know what your problem is Noel Carboni but I have a fully paid copy of the programme that I purchased direct from Adobe. Just because People have turned off the licenced option under msconfig does not make them a thief - next time you want to make such accusations i suggest you get a good lawyer, as a small business Owner who pays his way for everything I can do without a self important big mouth like you making such comments.
My intent is to make it clear that I for one don't tolerate piracy or stealing software.
If I have offended you or anyone using a legal license I'm sorry. But people shouldn't need praise for doing things legally, and if you ARE using legally licensed software then I'm sure you understand and agree.
Just keep in mind that people legitimately trying to work out licensing issues don't generally frequent warez and file sharing sites known to distribute cracked software, and your having posted that link identifies you as, at the very least, someone interested in those sites.
If you go walking on the seedy side of town, don't be surprised when people who see you associate you with your surroundings.
-Noel
Here is a link to another solution that works perfectly without having to download anything - http://jaredheinrichs.com/photoshop-cs4-error-1483.html
It's really strange, I never had this problem with a hacked version of photoshop, when my business went big and I could afford Photoshop I bought it to have a legal copy, new computer new installation and I started having problems, maybe Adobe should get hackers to RE-PROGRAM their faulty apps to actually work..
Thank you for misreading what I actually wrote and so says someone who most likely lives in the good ol USA and who benefits from her good fortune. Try living in poverty where you make no money while trying to be honest, it just doesn't work that way my friend. At least I ended up actually buying the software when I could (while almost going bankrupt in the process) and unfortunately I would not say that I have reached a level of success that you speak of, maybe one day. Not to mention that Adobe hikes up proces if you don't live in the US. Lightroom cost us $50 more that you would pay.
My actual rant was that bought software is usually buggy vs hacked software, no that's a sad fact.
North America
Asia Pacific
