Annotation does not print
Sep 3, 2008 4:44 AM
I have a text annotation that does not print even though it was created with the Print flag set to true. The example PDF can be seen at http://home.fuse.net/mikebrungs/output.pdf
The popup text note in the upper left hand portion of the page is viewable in the PDF but will not print out to paper no matter what I do. Hopefully someone can help.
Mike Brungs
MedPlus Inc.
    Sep 3, 2008 5:33 AM   in reply to (Mike_Brungs)
    You can print the sticky notes with Adobe Acrobat.
    Sep 3, 2008 6:13 AM   in reply to (Mike_Brungs)
    In Adobe Acrobat the setting is under Edit->Preferences, then if you choose Commenting you can select Print notes and pop-ups.
    Sep 3, 2008 6:37 AM   in reply to (Mike_Brungs)
    Yes, Adobe Reader doesn't have this settings in the preferences.
    Sep 3, 2008 10:25 PM   in reply to (Mike_Brungs)
    Adobe Reader doesnt have these settings unfortunately
    Sep 3, 2008 11:47 PM   in reply to (Mike_Brungs)
    Adobe Acrobat uses the following registry entry:
    HKEY_CURRENT_USER\Software\Adobe\Adobe Acrobat\8.0\Annots\cPrefs\bprintCommentPopups
    Sep 4, 2008 4:50 AM   in reply to (Mike_Brungs)
    > Does anyone know if the Adobe Reader 9 supports this registry entry ?
    Look at the registry.
    Dec 12, 2008 8:00 AM   in reply to (Mike_Brungs)
    On the Adobe knowledgebase page for Reader it indicates that you can choose to print comments from within Reader, but this is not true. I am using Reader 8.0 on a Windows computer, and just want to be able to
    print the comments on the page from Reader so that I don't have to bug the designer (who has Pro) every time I want to print with comments. Can this be done, or not. And if not WHY NOT!
    http://help.adobe.com/en_US/Reader/8.0/help.html?content=WS58a04a822e3 e50102bd615109794195ff-7bdf.html
    Print a PDF
    If the desired printing option is in the Print dialog box, set it there rather than through the printer driver. The computer you wish to print a PDF from must be connected either to a local, shared, or network printer and be configured to use that printer.
    Choose File > Print Setup (Windows), File > Page Setup (Mac OS), or File > Print (UNIX) to choose a paper size, page orientation, and other general printing options. The options vary with different
    printers and drivers. See your printer driver documentation for details.
    To print comments, such as sticky notes, in the Preferences dialog box, choose Commenting and select Print Notes And Pop-ups.
    Note: To open Preferences in Windows, choose Edit > Preferences. In Mac OS, choose Reader > Preferences.
    Click the Print button , or choose File > Print.
    Choose a printer from the menu at the top of the Print dialog box.
    (Mac OS) Choose an option from the Presets pop-up menu.
    In Windows or UNIX, click Properties to set any additional options available with the printer driver. In Mac OS, set printer driver options in the Print Center.
    To print comments or forms, select an option from the Comments And Forms pop-up menu.
    Indicate which pages you want to print, and then click OK.
    Dec 12, 2008 8:10 AM   in reply to (Mike_Brungs)
    You can print comments from within Reader.
    Dec 12, 2008 8:19 AM   in reply to (Mike_Brungs)
    Thanks Bernd, would you be able to tell me how?
    I've been trying everything for two days now, with no luck. I can print highlighted text, strike-through text, and it prints the little insert text marks. But it doesn't print the text you want to insert, and I can't get it to print the yellow sticky note itself, only the marker for it.
    Jul 2, 2009 6:09 AM   in reply to (elizabeth_connell)
    This additional step is needed in either Adobe Reader 8 or
    Adobe Acrobat 7 Pro  (those are the versions I've tried):
    File --> Print  -->  Comments and Forms
    (a dropdown menu in upper right under Properties)
    set it to Document and Markups
    You should now see the markups in the Preview area
    of the Print dialog.
    Click OK to print.
    Oct 14, 2011 9:05 AM   in reply to rroodd
    rroodd, You are right!
