Making Adobe Reader 8 the Default Reader
Feb 7, 2009 2:29 PM
    Feb 9, 2009 7:45 AM   in reply to (Chris_Witze)
    Uninstall any other readers that are also installed.
    Feb 9, 2009 7:48 AM   in reply to (Chris_Witze)
    does anyone know how to make adobe reader 8 default , while also keeping reader 9
    Feb 9, 2009 9:17 PM   in reply to (jag_bains)
    Make Reader 8 open at boot. Remember Adobe doesn't support two versions
    of Reader on the same system. Causes issues.
    Mike
    Feb 16, 2009 5:37 AM   in reply to (Chris_Witze)
    You can right click a pdf file and open with option, and select acrobat reader 8 as default.
    I also think you should uninstall the one you don't use and keep only one version install.
    Good luck!
    Sylvain
    Feb 17, 2009 2:31 PM   in reply to (Chris_Witze)
    What if you have Acrobat 7 and reader 8 and want reader 8 to be the default? I tried the above method of right clicking, open with, always open with reader 8. However, trying to open reader 8 instead lanuches acrobat 7.
    This is an issue because it is on a server, and most users don't have rights to use acrobat (not enough licenses purchased); so acrobat just shuts them down. Reader would/should work them instead.
    Feb 17, 2009 4:34 PM   in reply to (Randall_Dorn)
    Open reader at boot and don't open Acrobat. That is the only way to be
    sure (other than removing Acrobat).
    ...Mike
    Apr 23, 2012 9:18 AM   in reply to MichaelKazlow
    I have nearly the opposite problem.  I want to have Adobe Acrobat 9 be the default reader, not Adobe Reader X.
    Since Reader X was installed it has taken over at my default to open .pdf files.  This is not good.
    I need to know how to change this.
    Kamoxb
