Default Paper Size Setting
Apr 22, 2008 9:54 AM
How in the blazes does one set this thing to default to "letter" size paper? I've spent the last 30 minutes trying to find stuff in your "help" and "knowledgebase" (You hired the manager of that department from Microsoft, didn't you?)
If I just open a document and print it, it tries to print A4. Fine for you Eurotypes, but my HP printer hangs and asks for A4 paper. I get to have a Microsoft moment, while I spend 10 minutes doing a 1 minute job.
It's not in the "help" and it's not in the "preferences". Is it in the registry? Or a config file?
Your help systems have become too sophisticated. You need to hire some old retired people or non-Adobe people to quality control it. It may make sense to you, but it is almost opaque to someone who doesn't exist inside your sociogram.
    Apr 23, 2008 10:27 AM   in reply to (Gene_Dreher)
    Gene,
    The default paper size is not a Reader setting. Like many applications, the Reader uses the system-wide defaults set in the printer properties for each printer in the Windows control panel. That is the default shown unless you have the Reader's option to "choose paper source by PDF page size" enabled.
    You haven't said what version of Reader or of Windows that you use, but here is the sequence for Windows Vista:
    Open control panel. Click "Hardware & Sound" then Printers. Right-click on the printer in question and click Printing Preferences from the context menu. Choose a new paper size in the appropriate tab, click OK, and exit.
    The procedure for other versions of Windows varies, but there is always a printer properties dialog that sets the defaults. The dialog is available for each printer via the control panel.
    May 16, 2008 11:52 PM   in reply to (Gene_Dreher)
    I have a similiar problem. I use edocprint as default(pdf)printer which opens Acrobat Reader 8.12. When I change the printer to HL-1470 (or any other) I always have to change papersize from user defined (Benutzerdefiniert) to A4. Default Setting edoc and HL is A4. The Workstation is XP pro and my Notebook has Acrobat 5 installed and I have the same problem there when Acrobat prints a PDF and I want to print the PDF on a real printer. Thanks for any suggestions!
    Mar 18, 2014 9:39 AM   in reply to (Gene_Dreher)
    I am creating a pdf from Excel.  In Excel I have sent the doc size to Letter since the pdf is going to the States.  My printer default is A4.
    So how do I create the pdf as Letter size ?  It is always created as A4.
    Mar 18, 2014 9:46 AM   in reply to GaryB4
    Microsoft uses it's own pdf generator. You'll want to ask in one of their forums since this doesn't involve Adobe.
