Hey Ed Smith,
Thank you, thank you, thank you! (One of those is from my client)
That worked perfectly. I can work this step into my workflow so all I do now is open a project, bring one file in, make a comp, set the output folder, close that project. (This is to have my output set for the files I am about to work on)
Then, open a new project, pre-set my Output Module like you said (which I will do each time) and then just continue working through my worklfow. Except now at the end, I don't spend 20 minutes of wrist spraining clicking setting each output Module individually!
Awsome.
Now if only I could work out how to change the composition settings for each comp to a predefined one instead of ctrl K'ing each one and tabbing down (which when I do, it sounds like I am running a printing press with the repetativeness of my keystrokes.
Thanks so much, life saver. These forums are excellent.
Melvyn
