Does After Effects CS4 come with tempaltes?
Feb 23, 2009 12:40 PM
Our company bought the suite and it was installed by IT. Can someone tell me does After Effects, Encore etc come with templates?
    Feb 23, 2009 3:50 PM   in reply to r9r9r9
    Yes, After Effects comes with template projects. See the "Template projects and example projects" section of After Effects Help.
    If by 'templates' you meant something else, like animation presets, just say so and we'll point you in the right direction.
    Feb 24, 2009 12:09 AM   in reply to r9r9r9
    Contact your admin regarding the AE templates and Encore Library content. He did not choose to install them it would seem. For your presets, you need to obey correct procedures. Launch After Effects, create a new comp, add a layer. Then open the Effects&Presets palette and choose "Browse in Bridge" from the menu. Now you can simply double-click the preset when viewing it and it will be applied to the layer. Note, that of course text presets will only work on text layers, other presets will usually work on solids or normal layers.#
    Mylenium
