title remote not set
Mar 4, 2006 10:52 AM
Could someone help me please? Tile remote not set comes up when I check my DVD project, but I can not find what it is that I need to change or set!
Maik
    Mar 4, 2006 11:27 AM   in reply to (maik_fleischmann)
    Maik,
    It is a warning rather than an error.
    On the Disc tab there is a "Title Remote" setting which will tell the DVD player what the title key on the remote control should do (e.g. go to the main menu, or to the intro timeline of your project). Additionally, in the Properties of each timeline you will find a "Menu Remote" setting. This determines the behavior of the menu key.
    Mar 22, 2006 5:11 PM   in reply to (maik_fleischmann)
    Hi there,
    Would be I correct in assuming therefore that neither the "title" nor "menu" buttons have to be set-up? Ie., it's a nicety for the user to have but not illegal to the DVD spec.?
    Mar 23, 2006 2:30 AM   in reply to (maik_fleischmann)
    It is a nicety. :)
    Mar 23, 2006 3:16 AM   in reply to (maik_fleischmann)
    Thanks Ruud -- much appreciated...
    Jun 23, 2007 4:31 PM   in reply to (maik_fleischmann)
    It's a warning that an error has occured...this still doesn't answer the question.
    Jun 24, 2007 1:22 AM   in reply to (maik_fleischmann)
    If you read beyond "It is a warning rather than an error." in post #1 you should find an answer to the question. :)
    Aug 17, 2007 3:35 AM   in reply to (maik_fleischmann)
    One minor point of clarification in CS3 I found the "Title Button" setting on the "Properties" tab for the Disc.
    To make the Disc properties appear in the Properties panel:
    Activate the Build panel by clicking its tab. When the Build panel is active, the Properties panel contains the Disc properties.
    Aug 17, 2007 3:44 AM   in reply to (maik_fleischmann)
    Disc properties are also easily accessed by clicking on the Disc icon in the Flowchart panel.
