Want to access FileReference class add on properties and methods of CS4 in CS3
Apr 7, 2009 8:32 AM
great new look of Forum
Hi All,
     I have an urgent task to implement in my project code. I can't able to access the new properties and methods which are present in FileReference Class. For load() ,save() methods needs runtime version of Flash Player 10. I need to include the flash player 10 in CS3 publish settings Version. Otherwise you can suggest how i can able to access the FileReference class new properties and methods without CS4.
Previously I checked this same for Flash 8 with Flash Player 9. I mean i can compile my Flash 8 code in Flash Player 9 previously. So is it also possible with Flash CS3??
  • kglad
    Jul 21, 2002
    Apr 7, 2009 8:36 AM   in reply to Varun Upadhyay
    the best you can do is run an update of your flash cs3 and see if that gives the capacity to publish for fp 10.
    Apr 9, 2009 7:06 AM   in reply to Varun Upadhyay
    Well, you *could* turn off strict mode and compile the swf using the FP10 FileReference methods.
    Apr 9, 2009 7:29 AM   in reply to Varun Upadhyay
    Or you could do something like this:
    // a Button component instance on the stage
    myButton.addEventListener(MouseEvent.CLICK, onButtonClick);
    var loader:Loader = addChild(new Loader()) as Loader;
    var file:FileReference;
    var fileFilters:Array =
    new FileFilter("Images (*.jpg, *.jpeg, *.gif, *.png)", "*.jpg;*.jpeg;*.gif;*.png")
    function onButtonClick(event:MouseEvent)
    file = new FileReference();
    file.addEventListener(Event.SELECT, selectHandler);
    file.addEventListener(Event.COMPLETE, completeHandler);
    file.browse(fileFilters);
    function selectHandler(event:Event):void {
    var f:FileReference = FileReference(event.target);
    var loadFunc:Function = null;
    try
      loadFunc = f["load"];
    catch(e){}
    if(loadFunc != null)
      loadFunc();
    function completeHandler(event:Event):void {
    var d:ByteArray=null;
    try
      d = f["data"];
    catch(e){}
    if(d != null){loader.loadBytes(d);}
  • kglad
    Jul 21, 2002
    Apr 9, 2009 8:07 AM   in reply to Raymond Basque
    and you'll want to manually change your html file to require fp 10.
    Apr 12, 2009 5:30 AM   in reply to Varun Upadhyay
    It appears that the swf using FileReference must be marked version 10. Here's a quick hack to force CS3 to do so:
    Navigate to the Flash program player configuration folder. i.e. <drive>:\Program Files\Adobe\Adobe Flash CS3\en\Configuration\Players and copy FlashLite3_0.xml to FlashPlayer10.xml.
    Open the FlashPlayer10.xml and make these changes:
    <players>
      <player id="Flash Player 10" version="10">
      <name>Flash Player 10</name>
      <feature name="mobileAuthoringIntegration"  supported="false" />
    </players>
    You can leave the rest of the xml as is. Restart Flash.
    In Publish Settings, select Flash Player 10, and recompile.
