CS4 Extended won't show any changes I make to images
Apr 8, 2009 4:16 PM
I'm on Windows XP Pro with a Pentium4 2.8ghz, 2gb DDRAM, 256mb Sapphire Radeon graphics card.
If I turn off layer visibility my image won't show the change. I have to click on another layer before it will redraw the image. If I make a levels adjustment level and drag a slider while holding alt to show clipping the screen will stay green and black, red and black, or blue and black depending on the channel I adjust until I click on another layer.
5mb JPG images take about 10 seconds to open, flattening the image takes another 5-8 seconds. When I start Photoshop all menu items are greyed out for some arbitrary amount of time yet I can do commands like open by doing the keyboard shortcut.
If I could return this garbage to the store I would, and I'd go back to CS1 and be so much happier and more productive.
    Apr 8, 2009 4:24 PM   in reply to william_900
    You didn't actually ask a question but you might improve what you are complaining about by updating your video drivers.
    Also you don't mention if you have OpenGL enabled.
    Apr 8, 2009 4:25 PM   in reply to william_900
    First, check here to see if you card falls under the "tested" list. If it doesn't you could disable OpenGL drawing in PS prefs and see if that helps. Definitely make sure all your video card drivers are up to date.
    http://kb.adobe.com/selfservice/viewContent.do?externalId=kb405711
