Why does Photoshop CS4 keep crashing?! (Mac OS)
Jan 3, 2012 12:39 PM
I use Photoshop often, daily even. I upgraded to CS4 at the beginning of this year and have a CONSTANT and very IRRITATING problem. It keeps crashing, for no apparent reason. It will crash during all kinds of "tasks". Saving, opening an image from RAW, using the liquify tool, using the clone tool, running an action and any number of others tasks cause a crash in Photoshop CS4.
I work relatively fast, as I use Photoshop on a daily basis. This is how it will happen...
I'll be working on an image and I "command S" to save. There will be a slight delay of about 2-4 seconds and then Photoshop will crash and I will get a pop-up screen to submit a crash report. I have submitted literally hundreds, if not thousands of these. Then, Photoshop sits idle for a few minutes as if it is locked up, unable to "Relaunch". So, I then usually have to "Force Quit" Photoshop, yet, it will not immediatly quit. It takes another couple of minutes to do so before I am able to begin working again. This process happens, on average, a couple of times per hour, if not more.
Luckily, I have "trained" myself to save after almost ever thing I do. But, I inevitable loose something as it happens just after a "task" or during a "save". (It happens during a save frequently.) Plus, I'm loosing valuable time waiting on it to Relaunch, and figuring out where I'm at on the image all over again.
Needless to say, I'm beyond frustrated, to say the least.
There is something else that doesn't make sense. My business partner, who also has a new IMac (not the VERY newest model that just came out but the one just prior to that...It was purchased in December 08 as well) and also runs CS4 does not have this crashing problem! At all! Not once.
Here's the difference in our systems...He purchased the 24" model, while I purchased the 20". And, this is where I actually think the problem may lie...I am running dual monitors, while he does not.
I've tried to trouble-shoot this problem, since he does not have the problem, while I do. I did "About this Mac" on both our machines to see if there were any obvious differences, besides running dual monitors. What I found under HARDWARD were only two minor differences. His processor speed is 2.8 while mine is 2.66 GHz. and the SMC Version of his machine is 1.3f1, while mine is 1.29f1. There were no differences in the GRAPHICS/DISPLAYS section either, beyond my having a second display.
Both his and my graphics/displays are as follows:
ATI Radeon HD 2600 Pro:
  Chipset Model:    ATI Radeon HD 2600 Pro
  Type:    Display
  Bus:    PCIe
  PCIe Lane Width:    x16
  VRAM (Total):    256 MB
  Vendor:    ATI (0x1002)
  Device ID:    0x9583
  Revision ID:    0x0000
  ROM Revision:    113-B2250L-259
  EFI Driver Version:    01.00.259
  Displays:
iMac:
  Resolution:    1280 x 800
  Depth:    32-bit Color
  Core Image:    Hardware Accelerated
  Main Display:    Yes
  Mirror:    Off
  Online:    Yes
  Quartz Extreme:    Supported
  Built-In:    Yes
Below is the information regarding my second display.
LaCie 324:
  Resolution:    1920 x 1200 @ 60 Hz
  Depth:    32-bit Color
  Main Display:    Yes
  Mirror:    Off
  Online:    Yes
  Rotation:    Supported
  Television:    Yes
As you can see, my second display is a Lacie 324. It is rather new, I purchased it in November or December 08 as well as my IMac. I have the Lacie set as my main display.
When I have Googled this Photoshop CS4 crash problem, I have come across some mention of the GPU Settings and Enable OpenGL Drawing. I have to admit, I really don't understand this. Should OpenGL Drawing be on or off??? I turned OpenGL Drawing off some time ago because I had a problem with calibrating my Lacie monitor. My monitor was showing images skewed toward red, while my prints were coming out with less red. I Googled this problem (at the time I didn't think this was related to the crashing issue) and someone said they were having trouble calibrating their monitor as well and managed to "fix" that by turning "Enable OpenGL Drawing" off. I did that and it did indeed fix the problem with getting my Lacie monitor calibrated. FYI, my business partner also turned off the Enable OpenGL Drawing feature and...again...he has NOT had the problem with Photoshop CS4 crashing. So, since he is not having the problem and I am, I would assume the "Enable OpenGL Drawing" issue that is mentioned on this site, is not the crashing problem, though I could be wrong.
So, I go back to having a second monitor as being the most-likely candidate for causing the Photoshop crashes. I am wondering if the Lacie display is "drawing" the graphics at the speed that differs, or is incompatable, with Photoshop CS4??? This is just a guess from someone who is not all that technically savy. But, again, I'm not sure. I have also looked on the Lacie website for any updates for the Lacie 324. There are none, as far as I can tell.
I am curious if others with and without dual monitors are having these crashes. If so, have you found any resolution? I'm desperate for help so if anyone can shed any light on this issue, it would be most appreciated.
Below, I will put some specs about my machine, in case that is helpful.
Hardware Overview:
  Model Name:    iMac
  Model Identifier:    iMac8,1
  Processor Name:    Intel Core 2 Duo
  Processor Speed:    2.66 GHz
  Number Of Processors:    1
  Total Number Of Cores:    2
  L2 Cache:    6 MB
  Memory:    4 GB
  Bus Speed:    1.07 GHz
  Boot ROM Version:    IM81.00C1.B00
  SMC Version:    1.29f1
I have the 11.0.1 version of Photoshop CS4.
PLEASE help if you can. Thanks so much!
DGJ [email address deleted by host]
Replies 1 2 3 Previous Next
    Apr 15, 2009 4:55 PM   in reply to DGJ193
    I'm not sure that your Video card supports OpenGL turn it off if you can. also disconnect the second monitor see if it crashes.
    the other thing you can try is a new user.
    Apr 15, 2009 7:53 PM   in reply to DGJ193
    New user a clean account good for troubleshooting.
    Apr 19, 2009 10:53 AM   in reply to DGJ193
    Hey DGJ193.... I've had the same problem since I upgraded from CS3 to CS4. I'm on a 1st generation Intel MacPro with tons of ram. I read somewhere else on the Adobe web page that only certain graphics cards support the Open GL Drawing, so I upgraded to a NVIDIA GeForce 8800 GT, but it didn't fix the crashes. I've also noticed that occasionally, at certain magnifications, rectangular blocks of static start flashing on and off throughout the image I'm working on. This seems to happen only at either 50% or 66.7% magnifications.
    Talk about annoying... when it locks up, you can't even Force Quit it. It seems to take several minutes and then, finally, it quits. Like you, I'm saving my work constantly. I don't care if it's just a couple of brush strokes, it's CMD + S for me. I emailed Adobe this morning with all the pertinent information. If I hear of anything, I'll post it. If you find a fix, please do likewise.
    Greg
    Apr 22, 2009 5:22 AM   in reply to DGJ193
    Adobe has instructions on what you can do here: http://kb.adobe.com/selfservice/viewContent.do?externalId=kb404898
    I have a similar problem with my Radeon HD 2600 on my PC laptop running Windows x64 (it doesn't crash, it just shows blocks). I had to disable OpenGL). I really hope they get it fixed soon because I really wanted to use the Open GL features of Photoshop CS4.
    Apr 23, 2009 6:37 AM   in reply to DGJ193
    After a couple of month’s of pretty much satisfactory performance by Photoshop CS4 I recently got a new computer which runs OS X 10.5.6 (2x3 GHz Quad-Core Intel Xeon, 8 GB 800 MHz DDR2 FB-DIMM) and since then Photoshop CS4 has been performing pretty badly – frequent crashes etc.
    But I’m not yet done troubleshooting, so I don’t want to complain too much.
    What surprised me however is one of the warnings that occasionally precede the crashes:
    Apr 24, 2009 12:38 AM   in reply to DGJ193
    The waiting-time before being able to restart Phtoshop is quite
    familiar to me.
    Anyway so far the new user-solution seems to coniderably improve
    Photoshop’s reliability; of course loading all the preferences for all
    the applications anew is a nuisance.
    A side-note: When I – against Adobe’s recommendation – work on files
    on our servers and the crash occurs while trying to save the file gets
    destroyed, so working on local drives seems doubly recommendable.
    But I manage to focus my irritation less on Adobe and more on
    Macintosh (because any new System that abandons the possibility to
    sort search-results by change-date in favour of last opened-date seems
    peculiar to me).
    Apr 24, 2009 1:25 AM   in reply to c.pfaffenbichler
    I've gotta admit, I've been running Photoshop CS4 on my Windows 7 x64 box and it's so much faster than my Mac or Vista machines. It pops open almost immediately (the dang splash screen takes the longest amount of time). If I close and reopen, it's faster everytime. And the memory management is awesome, too. I'll have Bridge/Lightroom, Photoshop, and a virtual machine open at the same time and there's really no flakiness. For all you Microsoft haters, you should take a moment and check it out.
    I just wish I could try out the OpenGL stuff. I got CS4 the week it came out and found the OpenGL crap on day 1. This stupid ATi Radeon HD 2600 card is crap, I don't understand why ATi and Adobe didn't work something out by now. I would bet that any of you (Mac or PC) with this card are having the same flakiness I'm getting.
    Apr 24, 2009 1:59 AM   in reply to DGJ193
    Hey Dedra.....
    Sorry I took so long to respond. This is starting to get comical. The other night I had CS4 running in the background... no images open, just running in the background, while I was surfing the web and getting my email. All of a sudden I get the dreaded "Photoshop Has Quit Unexpectedly". I didn't even have an image open, yet it still crashed!
    To answer some of your questions.... oh, BTW, I'll be very surprised if the "different account" fixes your problem. You seem to be having way more crashes than me. If I have a bunch of images to work on, and I'm basically using CS4 throughout the day, I'll only get about two crashes. And they happen so randomly that I can't come up with any pattern or workflow that may be the cause. It just crashes whenever it pleases. I can't imagine what you're going through!
    OK, I'm not running dual monitors and as far as downloading the latest drivers for your graphics card, it's a lesson in frustration, being a Mac user. Before I upgraded to the GeForce 8800 GT, I almost pulled the hair out of my head trying to find the latest drivers for my 7300 GT. It seems that they just don't support Macs. Every driver you could imagine was out there for Windows, but zippo for a Mac... at least as far as NVIDIA goes. The good news, for me is, the latest drivers for my new card are included in Apple's Software Updates. So, they'll come automatically whenever they're updated.
    Judging from past experience, it takes a while before Adobe responds... but I will let you know immediately if I find out anything from them or anybody else, for that matter. As you said, let's keep our fingers crossed.
    All the best...
    Greg
    Apr 24, 2009 2:07 AM   in reply to shoebacca
    Hey shoebacca....
    I have no problem or issue with how long CS4 takes to launch on my Mac. The splash screen is there only momentarily. And yes, like you, if I close and reopen it's even faster. Also, no problem with the overall speed of CS4.
    About the OpenGL.... I've gotten so used to it, that I can't live without it. I could easily go back to "crash-free" CS3, but, even with CS4 crashing, I can't live without the OpenGL. I like it that much.
    Greg
    Apr 24, 2009 4:29 AM   in reply to DGJ193
    Dedra....
    I've seen that "plug-ins not available....." before. Highly unlikely that it has anything to do with the crashing problem. I would identify the plug-ins in question and then go to the manufacturer's web page to see if there are updates for them.
    Hope this helps.
    Greg
    Apr 28, 2009 5:16 PM   in reply to DGJ193
    I'm running photoshop cs4 on windows xp (dell inspiron e1505) and it crashes *constantly*.  Sometimes I'm doing something intensive and it crashes, but sometimes I open photoshop and do nothing and it crashes about 10 seconds later.  I have a final due in a couple days in a photoshop class and I may very well miss the deadline because of this........
  • Ramón G Castañeda
    Jul 27, 2006
    Apr 28, 2009 5:50 PM   in reply to adobesuxisalreadytaken
    That's most unfortunate, but this is the Photoshop Macintosh forum.  The Windows forum is across the hall.
    Misery loves company, so it's good to know that Windows users have their share of Photoshop problems.
    Apr 28, 2009 6:42 PM   in reply to Ramón G Castañeda
    I guess I made the same mistake, I posted to the Mac forum as well.
    As I posted earlier, I'm not crashing at all on Windows 7 or Windows Vista x64. I've only got the stupid driver problem for the Radeon 2600 HD and I'm hoping ATi and Adobe figure it out since i'm missing out on the OpenGL fun.
    Apr 28, 2009 9:10 PM   in reply to Ramón G Castañeda
    Sorry to post in the wrong forum!  I just wanted to quickly vindicate Adobe, though, after my rather jaded previous post.  I just downloaded the update from Adobe Automatic Updates and Photoshop hasn't crashed since.  Don't know if that will help you Mac folks or not, but I thought I'd just let you know.  Good luck!
    May 12, 2009 4:33 PM   in reply to DGJ193
    TXNDeleteObject is part of an OS supplied API for text editing widgets in the user interface.  It is part of Apple's code, and somewhere inside that code Apple has a bug that causes it to crash.  The bug was apparently introduced in MacOS 10.5.0 (10.4.x doesn't see this crash).  And the crash appears to affect Photoshop CS3 and CS4 (CS2 doesn't want to run on 10.5.x due to other Apple issues).
    But there can be other causes of crashes: bad drivers (printer, scanner), bad hardware (RAM), bad third party software (antivirus, third party plugins), corrupt files (like fonts), etc.  Without seeing the crash logs, we can't tell you exactly what might be causing your crashes.
    May 12, 2009 5:17 PM   in reply to Chris Cox
    10.5.7 is out today.. I've got my fingers crossed that Apple corrected something.
    May 14, 2009 9:12 AM   in reply to DGJ193
    Here are my last four crashes (all in the last few days). I turned off Default Folder to make sure it wasn't that but it didn't make a difference. Photoshop CS4 crashes a lot on my Nehalem Mac Pro 8-core 10.5.7.
    May 14, 2009 9:13 AM   in reply to DGJ193
    here are my last four crash logs
    May 14, 2009 9:24 AM   in reply to cgbeige
    after trying to post them all at once in code syntax things, Firefox crashed so I'll post them in 3 separate messages.
    Process:         Adobe Photoshop CS4 [293]
    Path:            /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/MacOS/Adobe Photoshop CS4
    Identifier:      com.adobe.Photoshop
    Version:         11.0.1 (11.0.1x20090216 [20090216.r.522 2009/02/16:17:00:00 cutoff; r branch]) (11.0.1)
    Code Type:       X86 (Native)
    Parent Process:  launchd [141]
    Date/Time:       2009-05-14 11:32:42.473 -0400
    OS Version:      Mac OS X 10.5.7 (9J61)
    Report Version:  6
    Anonymous UUID:  9A059F57-309E-4E59-893D-54D405B7DCE2
    Exception Type:  EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000094a18a8
    Crashed Thread:  0
    Thread 0 Crashed:
    0   com.apple.QD                      0x92c943cd _SetDstBits32BGRA + 8
    1   com.apple.QD                      0x92cb64f0 DevFrameRect + 795
    2   com.apple.QD                      0x92c7b89d StdRectWithPort + 267
    3   com.apple.QD                      0x92c7b77b CallRect + 53
    4   com.apple.QD                      0x92cb61d3 FrameRect + 43
    5   com.adobe.Photoshop               0x000ce083 0x1000 + 839811
    6   com.adobe.Photoshop               0x00571249 0x1000 + 5702217
    7   com.adobe.Photoshop               0x00568ba0 0x1000 + 5667744
    8   com.adobe.Photoshop               0x00350997 0x1000 + 3471767
    9   com.adobe.Photoshop               0x0006aa63 0x1000 + 432739
    10  com.adobe.Photoshop               0x0006af52 0x1000 + 434002
    11  com.adobe.Photoshop               0x000629f0 0x1000 + 399856
    12  com.adobe.Photoshop               0x0006a7e5 0x1000 + 432101
    13  com.adobe.Photoshop               0x00063d65 0x1000 + 404837
    14  com.adobe.Photoshop               0x00063ed3 0x1000 + 405203
    15  com.adobe.Photoshop               0x0006222f 0x1000 + 397871
    16  com.adobe.Photoshop               0x002206aa 0x1000 + 2225834
    17  com.adobe.Photoshop               0x00220736 0x1000 + 2225974
    18  com.adobe.Photoshop               0x00003912 0x1000 + 10514
    19  com.adobe.Photoshop               0x00003839 0x1000 + 10297
    Thread 1:
    0   libSystem.B.dylib                 0x900649c6 kevent + 10
    1   libSystem.B.dylib                 0x90065155 _pthread_start + 321
    2   libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 2:
    0   libSystem.B.dylib                 0x900342ce semaphore_wait_signal_trap + 10
    1   libSystem.B.dylib                 0x900662c6 _pthread_cond_wait + 1267
    2   libSystem.B.dylib                 0x900ab539 pthread_cond_wait + 48
    3   com.adobe.amt.services            0x04b7a552 AMTConditionLock::LockWhenCondition(int) + 46
    4   com.adobe.amt.services            0x04b75995 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 115
    5   com.adobe.amt.services            0x04b7a5b0 AMTThread::Worker(void*) + 20
    6   libSystem.B.dylib                 0x90065155 _pthread_start + 321
    7   libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 3:
    0   libSystem.B.dylib                 0x9003b46e __semwait_signal + 10
    1   libSystem.B.dylib                 0x90065dcd pthread_cond_wait$UNIX2003 + 73
    2   libGLProgrammability.dylib        0x91afeb32 glvmDoWork + 162
    3   libSystem.B.dylib                 0x90065155 _pthread_start + 321
    4   libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 4:
    0   libSystem.B.dylib                 0x900342da semaphore_timedwait_trap + 10
    1   ...ple.CoreServices.CarbonCore    0x96cf047f MPWaitOnSemaphore + 125
    2   MultiProcessor Support            0x1dabaeff 0x1da8b000 + 196351
    3   ...ple.CoreServices.CarbonCore    0x96cdd057 PrivateMPEntryPoint + 56
    4   libSystem.B.dylib                 0x90065155 _pthread_start + 321
    5   libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 5:
    Thread 6:
    Thread 7:
    Thread 8:
    Thread 9:
    Thread 10:
    Thread 11:
    Thread 12:
    Thread 13:
    Thread 14:
    Thread 15:
    Thread 16:
    Thread 17:
    Thread 18:
    Thread 19:
    2   ...ple.CoreServices.CarbonCore    0x96cdee83 TSWaitOnCondition + 126
    3   ...ple.CoreServices.CarbonCore    0x96cbdd6a TSWaitOnConditionTimedRelative + 202
    4   ...ple.CoreServices.CarbonCore    0x96cdeb00 MPWaitOnQueue + 208
    5   AdobeACE                          0x027c138d 0x2790000 + 201613
    6   AdobeACE                          0x027c0d85 0x2790000 + 200069
    7   ...ple.CoreServices.CarbonCore    0x96cdd057 PrivateMPEntryPoint + 56
    8   libSystem.B.dylib                 0x90065155 _pthread_start + 321
    9   libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 20:
    Thread 21:
    Thread 22:
    Thread 23:
    Thread 24:
    Thread 25:
    Thread 26:
    Thread 27:
    Thread 28:
    Thread 29:
    Thread 30:
    Thread 31:
    Thread 32:
    Thread 33:
    Thread 34:
    0   libSystem.B.dylib                 0x900343a6 mach_wait_until + 10
    1   libSystem.B.dylib                 0x900ab3ad nanosleep + 314
    2   com.adobe.PSAutomate              0x23834755 ScObjects::Thread::sleep(unsigned int) + 143
    3   com.adobe.PSAutomate              0x238347b5 ScObjects::Thread::wait(unsigned int) + 23
    4   com.adobe.PSAutomate              0x23825502 ScObjects::BridgeTalkThread::run() + 332
    5   com.adobe.PSAutomate              0x23834a77 ScObjects::Thread::go(void*) + 239
    Thread 35:
    0   libSystem.B.dylib                 0x90034286 mach_msg_trap + 10
    1   libSystem.B.dylib                 0x9003ba7c mach_msg + 72
    2   com.apple.CoreFoundation          0x9477704e CFRunLoopRunSpecific + 1790
    3   com.apple.CoreFoundation          0x94777cd4 CFRunLoopRun + 84
    4   com.apple.DesktopServices         0x90614e17 TSystemNotificationTask::SystemNotificationTaskProc(void*) + 123
    5   ...ple.CoreServices.CarbonCore    0x96cdd057 PrivateMPEntryPoint + 56
    Thread 36:
    4   com.apple.DesktopServices         0x90614f90 TFSEventsNotificationTask::FSEventsNotificationTaskProc(void*) + 216
    Thread 37:
    5   com.apple.DesktopServices         0x9061ff72 TNodeSyncTask::SyncTaskProc(void*) + 84
    6   ...ple.CoreServices.CarbonCore    0x96cdd057 PrivateMPEntryPoint + 56
    7   libSystem.B.dylib                 0x90065155 _pthread_start + 321
    8   libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 38:
    Thread 39:
    0   libSystem.B.dylib                 0x900836fa select$DARWIN_EXTSN + 10
    Thread 40:
    5   com.adobe.CameraRaw               0x269be438 0x26803000 + 1815608
    6   com.adobe.CameraRaw               0x269bdd36 0x26803000 + 1813814
    Thread 41:
    Thread 42:
    Thread 43:
    Thread 44:
    Thread 45:
    Thread 46:
    Thread 47:
    Thread 48:
    Thread 49:
    Thread 50:
    Thread 51:
    Thread 52:
    Thread 53:
    Thread 54:
    Thread 55:
    3   com.adobe.CameraRaw               0x2684803a 0x26803000 + 282682
    4   com.adobe.CameraRaw               0x26af9374 EntryFM + 802340
    5   com.adobe.CameraRaw               0x268e80e6 0x26803000 + 938214
    Thread 56:
    4   com.adobe.CameraRaw               0x26b88f88 EntryFM + 1391160
    Thread 57:
    0   libSystem.B.dylib                 0x900342e6 semaphore_timedwait_signal_trap + 10
    1   libSystem.B.dylib                 0x900662af _pthread_cond_wait + 1244
    2   libSystem.B.dylib                 0x90067b33 pthread_cond_timedwait_relative_np + 47
    3   com.apple.Foundation              0x93034dcc -[NSCondition waitUntilDate:] + 236
    4   com.apple.Foundation              0x93034be0 -[NSConditionLock lockWhenCondition:beforeDate:] + 144
    5   com.apple.Foundation              0x93034b45 -[NSConditionLock lockWhenCondition:] + 69
    6   com.apple.AppKit                  0x90f9fd20 -[NSUIHeartBeat _heartBeatThread:] + 753
    7   com.apple.Foundation              0x92feee0d -[NSThread main] + 45
    8   com.apple.Foundation              0x92fee9b4 __NSThread__main__ + 308
    9   libSystem.B.dylib                 0x90065155 _pthread_start + 321
    10  libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 58:
    3   data_flow                         0x03ba02b2 boost::detail::condition_impl::do_wait(_opaque_pthread_mutex_t*) + 24
    4   data_flow                         0x03b9365b void boost::condition::do_wait<boost::recursive_mutex>(boost::recursive_mu tex&) + 51
    5   data_flow                         0x03b96061 boost::threadpool::detail::pool_core<boost::threadpool::prio_task_fun c, boost::threadpool::prio_scheduler, boost::threadpool::static_size, boost::threadpool::resize_controller, boost::threadpool::wait_for_all_tasks>::execute_task() volatile + 135
    6   data_flow                         0x03b96bba boost::threadpool::detail::worker_thread<boost::threadpool::detail::p ool_core<boost::threadpool::prio_task_func, boost::threadpool::prio_scheduler, boost::threadpool::static_size, boost::threadpool::resize_controller, boost::threadpool::wait_for_all_tasks> >::run() + 232
    7   data_flow                         0x03b9390b boost::_bi::bind_t<void, boost::_mfi::mf0<void, boost::threadpool::detail::worker_thread<boost::threadpool::detail::p ool_core<boost::threadpool::prio_task_func, boost::threadpool::prio_scheduler, boost::threadpool::static_size, boost::threadpool::resize_controller, boost::threadpool::wait_for_all_tasks> > >, boost::_bi::list1<boost::_bi::value<boost::shared_ptr<boost::threadpo ol::detail::worker_thread<boost::threadpool::detail::pool_core<boost:: threadpool::prio_task_func, boost::threadpool::prio_scheduler, boost::threadpool::static_size, boost::threadpool::resize_controller, boost::threadpool::wait_for_all_tasks> > > > > >::operator()() + 43
    8   data_flow                         0x03b95fd1 boost::function0<void, std::allocator<boost::function_base> >::operator()() const + 79
    9   data_flow                         0x03ba1bc5 thread_proxy + 99
    10  libSystem.B.dylib                 0x90065155 _pthread_start + 321
    11  libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 59:
    Thread 60:
    Thread 61:
    Thread 62:
    Thread 63:
    Thread 64:
    Thread 65:
    Thread 66:
    Thread 67:
    Thread 68:
    Thread 69:
    Thread 70:
    Thread 71:
    Thread 72:
    Thread 73:
    Thread 74:
    3   ...ple.CoreServices.CarbonCore    0x96cbdd96 TSWaitOnConditionTimedRelative + 246
    5   com.apple.DesktopServices         0x90621ebc TFolderSizeTask::FolderSizeTaskProc(void*) + 104
    Thread 75:
    4   ...ple.CoreServices.CarbonCore    0x96cbdb76 TSWaitOnSemaphoreCommon + 422
    5   ...ple.CoreServices.CarbonCore    0x96cbd877 AsyncFileThread(void*) + 73
    Thread 0 crashed with X86 Thread State (32-bit):
      eax: 0x094a18a8  ebx: 0x0000003f  ecx: 0xbfffea84  edx: 0xff000157
      edi: 0xbfffefe8  esi: 0xbfffed0a  ebp: 0xbfffea48  esp: 0xbfffe9ec
       ss: 0x0000001f  efl: 0x00010282  eip: 0x92c943cd   cs: 0x00000017
       ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
      cr2: 0x094a18a8
    Binary Images:
        0x1000 -  0x19aefdf +com.adobe.Photoshop 11.0.1 (11.0.1x20090216 [20090216.r.522 2009/02/16:17:00:00 cutoff; r branch]) (11.0.1) <5151e2340b0a4c1da3dea7ac2285e24e> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/MacOS/Adobe Photoshop CS4
    0x207f000 -  0x2084fff  org.twain.dsm 1.9.3 (1.9.3) /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
    0x208d000 -  0x246701f +com.adobe.linguistic.LinguisticManager 4.0.0 (7863) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/Adob eLinguistic
    0x251b000 -  0x2715fcf +AdobeOwl ??? (???) <4cca2c7b48964ddaa14b725fb0c202b5> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
    0x2790000 -  0x289dfff +AdobeACE ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
    0x28bb000 -  0x2c85fef +AdobeMPS ??? (???) <277e01a3cac34fa9a5914bc0a5bc125a> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
    0x2d14000 -  0x2d74fc7 +AdobeXMP ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
    0x2d83000 -  0x307efff +AdobeAGM ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
    0x313e000 -  0x33d1fe7 +AdobeCoolType ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeC oolType
    0x3455000 -  0x346efff +AdobeBIB ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
    0x3478000 -  0x3499ff7 +AdobeBIBUtils ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeB IBUtils
    0x34a6000 -  0x34c1ff9 +AdobePDFSettings ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/Ado bePDFSettings
    0x34db000 -  0x34ffff6 +AdobeAXE8SharedExpat ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A /AdobeAXE8SharedExpat
    0x3512000 -  0x359f2cb +libicucnv.dylib.36.0 ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libic ucnv.dylib.36.0
    0x35cc000 -  0x35e780f +libicudata.dylib.36.0 ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata .dylib.36.0
    0x35ea000 -  0x37a0ff4 +com.adobe.amtlib amtlib 2.0.1.10077 (2.0.1.10077) <cb2ec3bf67714dabbf296775fb6f9608> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
    0x37d7000 -  0x3867fc3 +WRServices ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/WRServices.framework/Versions/A/WRService s
    0x39e9000 -  0x39edffc +com.adobe.AdobeCrashReporter 2.5 (3.0.20080806) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/A dobeCrashReporter
    0x39f3000 -  0x3a0ffd7 +com.adobe.LogTransport 1.0 (1.0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/LogTransport.framework/Versions/A/LogTran sport
    0x3a1a000 -  0x3aeffdd +FileInfo ??? (???) <f0932f89fc984ba9b4f2c58d0e71d3c1> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
    0x3b20000 -  0x3b77fff +aif_core ??? (???) <b4dcb439e1eeabe3bd122c42e980366b> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
    0x3b8f000 -  0x3bacffd +data_flow ??? (???) <8e452b6f803239d8eb5c49a4e31cb988> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
    0x3bd8000 -  0x3c51fff +image_flow ??? (???) <498a857df8c6f9e0c92fbc3ec8680ed0> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flo w
    0x3cb7000 -  0x3cc7fff +image_runtime ??? (???) <f379a95229831e44676dbbd8259f131a> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_ runtime
    0x3cdc000 -  0x3e9bffe +aif_ogl ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
    0x3f4c000 -  0x444afc3 +AdobeOwlCanvas ??? (???) <fcb2d1a31f6e41828e2cd0b23572d285> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/A/Adobe OwlCanvas
    0x4593000 -  0x4665fe7 +AdobeAXEDOMCore ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/Adob eAXEDOMCore
    0x4719000 -  0x477bfe7 +com.adobe.PlugPlug 1.0.0.73 (1.0.0.73) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
    0x47dc000 -  0x4823fc7 +com.adobe.adobe_caps adobe_caps 2.0.99.0 (2.0.99.0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_cap s
    0x4833000 -  0x4872fff  com.apple.vmutils 4.1 (104) <ce02dba5e2e99fa2eb41a81bc9680985> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutil s
    0x4b00000 -  0x4b03fff +com.stclairsoft.DefaultFolderX.osax Default Folder X Addition version 1.0 (4.2d11) <20ae7639d6757ddcf4bc4056fe20f03c> /Users/beige/Library/ScriptingAdditions/Default Folder X Addition.osax/Contents/MacOS/Default Folder X Addition
    0x4b46000 -  0x4b47fe1  com.apple.textencoding.unicode 2.2 (2.2) <09ac11c81bf4e673a30cc364868fdc11> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
    0x4b5a000 -  0x4bfbfc3 +com.adobe.amt.services AMTServices 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) <31e82904c3c2424ea1aea5efadbb19b8> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/amtservices.framework/Versions/a/amtservi ces
    0x4da3000 -  0x4da5fff +com.unsanity.menuextraenabler 1.0.3 (1.0.3) /Library/InputManagers/Menu Extra Enabler/Menu Extra Enabler.bundle/Contents/MacOS/Menu Extra Enabler
    0x4dd7000 -  0x4de5feb  libSimplifiedChineseConverter.dylib ??? (???) <c3123eb807ed45151fe0d12da8e51d04> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
    0x4dea000 -  0x4dfcfff  libTraditionalChineseConverter.dylib ??? (???) <8a2b4c7bfd8d7941fcf64a2575095e36> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
    0x4f00000 -  0x4f01ff3  ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
    0x4f73000 -  0x4f80ff7 +com.adobe.asneu.framework asneu version 1.6.2f01 (1.6.2) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/asneu.framework/Versions/a/asneu
    0x4f8e000 -  0x4f8effd  libmx.A.dylib ??? (???) /usr/lib/libmx.A.dylib
    0x4fa5000 -  0x4fa7ffa +Adobe Unit Types a2.0.0 (2.0.0) /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types
    0x9499000 -  0x94a5ff3 +net.telestream.license 1.0.0.2-GC (1.0.0.2-GC) <1e96dd44a98bbc9c09855d80a6ea4574> /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
    0x96f8000 -  0x96fdff7  com.apple.AppleMPEG2Codec 1.0.1 (220) <6fdff3c87ececb7413749c0230c54f78> /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG 2Codec
    0x9891000 -  0x98abfc3  com.apple.AppleIntermediateCodec 1.2 (145) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/Ap pleIntermediateCodec
    0xc12c000 -  0xc145ff3  com.apple.applepixletvideo 1.2.18 (1.2d18) <386af0b779e8c148e6b6cbc7f5489d45> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/A pplePixletVideo
    0xc272000 -  0xc510ff0 +org.perian.Perian 1.1.3 (1.1.3) <7baeef0d5eeb1d10d9b0c9293effe582> /Users/beige/Library/QuickTime/Perian.component/Contents/MacOS/Perian
    0xc7a2000 -  0xc999fd2 +net.telestream.wmv.import 2.2.2.3 (2.2.2.3) <77e650a498b347a8af2eacf5ceeebf9f> /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
    0xc9cd000 -  0xcb2ffe2 +net.telestream.wmv.advanced 2.2.2.3 (2.2.2.3) <d5ceb82d96d540efad02bf868248ce5d> /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
    0xcb6e000 -  0xcb91fe7  com.apple.AppleProResDecoder 1.0.1 (53) /System/Library/QuickTime/AppleProResDecoder.component/Contents/MacOS /AppleProResDecoder
    0xcbc3000 -  0xcc28fef  com.apple.AppleVAH264HW.component 1.0 (1.0) <f625e0d0d8c834ee6d65370345c2f6bc> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/Appl eVAH264HW
    0xcce3000 -  0xcd1efff  com.apple.QuickTimeFireWireDV.component 7.6 (1291) /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacO S/QuickTimeFireWireDV
    0xcd2b000 -  0xcd79fe3  com.apple.AppleVAFramework 4.1.16 (4.1.16) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleV A
    0x19141000 - 0x19162feb +com.stclairsoft.DefaultFolderX.CarbonPatcher kBundleVersion (kBundleVersion) <8b93f82fae47535ac5ac173ee8e6040b> /Users/beige/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Carbon Patcher.bundle/Contents/MacOS/Carbon Patcher
    0x1916f000 - 0x1918dff7 +Cocoa Patcher ??? (???) <f334cea477fc7dfa50ece44251cb5a78> /Users/beige/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Cocoa Patcher.bundle/Contents/MacOS/Cocoa Patcher
    0x1c426000 - 0x1c449ff7 +CSI-Launcher.dylib ??? (???) /Library/Application Support/Adobe/CS4ServiceManager/CSI-Launcher.dylib
    0x1c466000 - 0x1c5ebfe3  GLEngine ??? (???) <3bd4729832411ff31de5bb9d97e3718d> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle /GLEngine
    0x1c619000 - 0x1c8f7ff1  com.apple.ATIRadeonX2000GLDriver 1.5.44 (5.4.4) <aeb5e93202779fb8e0f5da88291ce9f6> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/Mac OS/ATIRadeonX2000GLDriver
    0x1c95b000 - 0x1c977ff7  GLRendererFloat ??? (???) <927b7d5ce6a7c21fdc761f6f29cdf4ee> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRe ndererFloat.bundle/GLRendererFloat
    0x1da35000 - 0x1da40fff +Enable Async IO ??? (???) <fd91e79fc4aa4ebcaf6d3e154f14878f> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/Enable Async IO.plugin/Contents/MacOS/Enable Async IO
    0x1da45000 - 0x1da50fff +UseOldShortcuts ??? (???) <a9de9f74fcf34c1cacf5cc296335f84d> /Applications/Adobe Photoshop CS4/Plug-ins/UseOldShortcuts.plugin/Contents/MacOS/UseOldShortcuts
    0x1da55000 - 0x1da6302f +FastCore ??? (???) <f12878b7bee940ca9f0565cd0f5688e2> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
    0x1da69000 - 0x1da74ffb +PPCCore ??? (???) <ed521eb7681d45aa9ae36bf4663e4bd3> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/PPCCore.plugin/Contents/MacOS/PPCCore
    0x1da7a000 - 0x1da85ffe +AltiVecCore ??? (???) <a967ae2af2ae4e12a7b668b981cbd906> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/AltiVecCore.plugin/Contents/MacOS/AltiVecCore
    0x1da8b000 - 0x1dad2ff7 +MultiProcessor Support ??? (???) <001a163b53144613a23af35b63065fd0> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
    0x1dc00000 - 0x1dc65fe3 +MMXCore ??? (???) <e206c8dcaea849df8fbc8b447e3a59a1> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
    0x1dd03000 - 0x1de55fc7 +com.adobe.coretech.adm 3.10x16 (3.1) /Applications/Adobe Photoshop CS4/Plug-ins/ADM/AdobeADM.bundle/Contents/MacOS/AdobeADM
    0x1ed51000 - 0x1ed5efff +com.alienskin.autolayer2 2.0.1 (2.0.1) <420807129f42aa6e0264f66de8c18c6b> /Applications/Adobe Photoshop CS4/Plug-ins/Alien Skin/Autolayer2.plugin/Contents/MacOS/Autolayer2
    0x1f04c000 - 0x1f056ffe  com.apple.URLMount 3.1.1 (3.1.1) <0189760dca64cd07c190e1a7b10283e5> /System/Library/PrivateFrameworks/URLMount.framework/URLMount
    0x20680000 - 0x20685ff3  libCGXCoreImage.A.dylib ??? (???) <3a78abc535c80f9819931b670da804a2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage. A.dylib
    0x23700000 - 0x2395cfdf +com.adobe.PSAutomate 11.0 (11.0) /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/Script ingSupport
    0x23bf0000 - 0x23cbefff +AdobeExtendScript ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/Ad obeExtendScript
    0x23d35000 - 0x23dd6fd7 +AdobeScCore ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScC ore
    0x23e32000 - 0x2402afff  com.apple.RawCamera.bundle 2.0.14 (436) <a8dd51882088fae463f33bc0674583e8> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
    0x24378000 - 0x243a9fe3 +com.adobe.amt.registration AMTRegistration 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/registration.framework/Versions/a/registr ation
    0x24680000 - 0x24b02fe3 +AdobeLM_libFNP.dylib ??? (???) <02e9ac769cc64974af0548e737c2cc20> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/amtlib.framework/Versions/a/AdobeLM_libFN P.dylib
    0x24c2c000 - 0x24c88ff2 +AdobeUpdater ??? (???) <064cfaa41caf46e3bebf04948641c927> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeUpdater.framework/Versions/a/AdobeUp dater
    0x26803000 - 0x26f0aff9 +com.adobe.CameraRaw 5.3 (5.3.0f21) <077769d6e7737a315c4fb417c2ae4dcd> /Library/Application Support/Adobe/Plug-Ins/CS4/File Formats/Camera Raw.plugin/Contents/MacOS/Camera Raw
    0x3bf0a000 - 0x3bf78fd7 + ??? (???)
    0x40000000 - 0x400ae030 +AdobeJP2K ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
    0x42782000 - 0x42889fcf +com.adobe.versioncue ??? (4.0.1.095) /Library/Application Support/Adobe/Adobe Version Cue CS4/Client/4.0.1/VersionCue.framework/VersionCue
    0x8fe00000 - 0x8fe2db43  dyld 97.1 (???) <9736a715ebabb914fef61680520dc1e0> /usr/lib/dyld
    0x90003000 - 0x90019fff  com.apple.DictionaryServices 1.0.0 (1.0.0) <7d20b8d1fb238c3e71d0fa6fda18c4f7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x9001a000 - 0x90026ff9  com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpD ata
    0x90033000 - 0x9019aff3  libSystem.B.dylib ??? (???) <b47c8e6e45aef620730710a732bf1930> /usr/lib/libSystem.B.dylib
    0x9019b000 - 0x9024bfff  edu.mit.Kerberos 6.0.13 (6.0.13) <804bd1b3f08fb57396781f012006367c> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x9024c000 - 0x9028bfff  com.apple.CoreMediaIOServicesPrivate 15.0 (15.0) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framewor k/Versions/A/CoreMediaIOServicesPrivate
    0x9028c000 - 0x90290fff  libGIF.dylib ??? (???) <3578a8fe9fb40ab4abf8f3c8356320c2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x90291000 - 0x90335fec  com.apple.CFNetwork 438.10 (438.12) <fde64bbb20532794396fb21911ccaa98> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
    0x90336000 - 0x90367ffb  com.apple.quartzfilters 1.5.0 (1.5.0) <92b4f39479fdcabae0d8f53febd22fad> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzFilters.framework/Versions/A/QuartzFilters
    0x90368000 - 0x90368ffa  com.apple.CoreServices 32 (32) <373d6a888f9204641f313bc6070ae065> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
    0x90369000 - 0x90391ff7  com.apple.shortcut 1.0.1 (1.0) <131202e7766e327d02d55c0f5fc44ad7> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Short cut
    0x90392000 - 0x90392ffd  com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
    0x90393000 - 0x903cafff  com.apple.SystemConfiguration 1.9.2 (1.9.2) <eab546255ac099b9616df999c9359d0e> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
    0x903cb000 - 0x903cbff8  com.apple.Cocoa 6.5 (???) <a1bc9247cf65c20f1a44d0973cbe649c> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x903cc000 - 0x903f5fff  com.apple.CoreMediaPrivate 15.0 (15.0) /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions /A/CoreMediaPrivate
    0x903f6000 - 0x905c7ffb  com.apple.security 5.0.5 (36371) <c13e0bb1acfdcf94be4d3ee118ef190e> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x905c8000 - 0x90602fe7  com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x90603000 - 0x90612ffe  com.apple.DSObjCWrappers.Framework 1.3 (1.3) <182986b74247b459b2a67a47071bdc6b> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A /DSObjCWrappers
    0x90613000 - 0x9069dfe3  com.apple.DesktopServices 1.4.8 (1.4.8) <3065de6531ce839c7cb5b6dd70e03f4f> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
    0x906d9000 - 0x907c1ff3  com.apple.CoreData 100.2 (186.1) <8fb61e1714a4b8d587ce97605ad32547> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x90846000 - 0x9086ffff  libcups.2.dylib ??? (???) <1b0435164b9dc6c773d0b1f24701e554> /usr/lib/libcups.2.dylib
    0x90ec2000 - 0x90ef1fe3  com.apple.AE 402.3 (402.3) <b13bfda0ad9314922ee37c0d018d7de9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
    0x90ef2000 - 0x90ef8fff  com.apple.print.framework.Print 218.0.3 (220.2) <5b7f4ef7c2df36aff9605377775781e4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
    0x90ef9000 - 0x916f7fef  com.apple.AppKit 6.5.7 (949.46) <a80f8cb62f6bdcb3bed3c8675d55881d> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x916f8000 - 0x9183eff7  com.apple.ImageIO.framework 2.0.4 (2.0.4) <bf2299657a0600d4d4bc1f0b45ce2252> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
    0x9183f000 - 0x9190afff  com.apple.ColorSync 4.5.1 (4.5.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
    0x9190b000 - 0x9194cfe7  libRIP.A.dylib ??? (???) <69bd09fcd8d8b235cee7a405290d6818> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x9195d000 - 0x91a3eff7  libxml2.2.dylib ??? (???) <068cab13eb4608a7c6a5fad807ee0e33> /usr/lib/libxml2.2.dylib
    0x91a3f000 - 0x91a49feb  com.apple.audio.SoundManager 3.9.2 (3.9.2) <df077a8048afc3075c6f2d9e7780e78e> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
    0x91a4a000 - 0x91ad6ff7  com.apple.framework.IOKit 1.5.2 (???) <97b9f9d584f48891377f0481b9104434> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x91ad7000 - 0x91fa8fbe  libGLProgrammability.dylib ??? (???) <7f18294a7bd0b6afe4319f29187fc70d> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
    0x91fa9000 - 0x920e1fe7  com.apple.imageKit 1.0.2 (1.0) <c5d490cabf34706b82e70d6b900f3df6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Ima geKit.framework/Versions/A/ImageKit
    0x920e2000 - 0x920e4ff5  libRadiance.dylib ??? (???) <232d7e7bbe8c65c16098bc1a52b30b9b> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x920e5000 - 0x92109fff  libxslt.1.dylib ??? (???) <f0872c9ba3c17861fba8c45a3647cee1> /usr/lib/libxslt.1.dylib
    0x9226e000 - 0x9226efff  com.apple.Carbon 136 (136) <8ae1cd25fd33db22d69ecbd5f5103227> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x9226f000 - 0x9242bff3  com.apple.QuartzComposer 2.1 (106.13) <645bdfea218d17e8a51cc7fee78d9cd3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
    0x9242c000 - 0x9242efff  com.apple.securityhi 3.0 (30817) <547bdd9ce4e7276d9bdc137d4caf9c3f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
    0x9242f000 - 0x92754fe2  com.apple.QuickTime 7.6.0 (1291) <07b7f2aca9aa205e9bd202f0cfa28c19> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x92755000 - 0x927c7fff  com.apple.PDFKit 2.1.2 (2.1.2) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDF Kit.framework/Versions/A/PDFKit
    0x927d2000 - 0x9281bfef  com.apple.Metadata 10.5.2 (398.25) <281076cdaea1362e02b6892b93d16bbb> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
    0x9281c000 - 0x92837ffb  libPng.dylib ??? (???) <ae92a25664039afc82409484407d5e83> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x9290f000 - 0x929c1ffb  libcrypto.0.9.7.dylib ??? (???) <9d714c92872a93dd127ea8556b2c8945> /usr/lib/libcrypto.0.9.7.dylib
    0x929c2000 - 0x92a13ff7  com.apple.HIServices 1.7.0 (???) <a2352abae2b8b44a95a8a76c8e111d36> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
    0x92a26000 - 0x92a2dfe9  libgcc_s.1.dylib ??? (???) <e280ddf3f5fb3049e674edcb109f389a> /usr/lib/libgcc_s.1.dylib
    0x92b10000 - 0x92b10ff8  com.apple.ApplicationServices 34 (34) <ee7bdf593da050bb30c7a1fc446eb8a6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
    0x92b48000 - 0x92b50fff  com.apple.DiskArbitration 2.2.1 (2.2.1) <2664eeb3a4d0c95a21c089892a0ae8d0> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
    0x92b51000 - 0x92c08ff3  com.apple.QTKit 7.6 (1291) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x92c09000 - 0x92c10ffe  libbsm.dylib ??? (???) <fa7ae5f1a621d9b69e7e18747c9405fb> /usr/lib/libbsm.dylib
    0x92c11000 - 0x92c50fef  libTIFF.dylib ??? (???) <745ad643ca5bde81a88c0cdc8c942380> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x92c51000 - 0x92c55fff  libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
    0x92c56000 - 0x92c6eff7  com.apple.CoreVideo 1.6.0 (20.0) <c0f8e729d9876e91f79f9c3b6b13beb0> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x92c6f000 - 0x92d16feb  com.apple.QD 3.11.56 (???) <a94d0f5438b730e88e5efdb233295c52> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
    0x92e97000 - 0x92ef3ff7  com.apple.htmlrendering 68 (1.1.3) <1c5c0c417891b920dfe139385fc6c155> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
    0x92ef4000 - 0x92f09ffb  com.apple.ImageCapture 5.0.2 (5.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
    0x92f0a000 - 0x92f63ff7  libGLU.dylib ??? (???) <a3b9be30100a25a6cd3ad109892f52b7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
    0x92f64000 - 0x92fe3ff5  com.apple.SearchKit 1.2.1 (1.2.1) <bf8c50d86ebd0c199752065658b9e2c3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
    0x92fe4000 - 0x93260fe7  com.apple.Foundation 6.5.8 (677.24) <aa84b0383891378c348ffa4a94853082> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x93261000 - 0x932a3fef  com.apple.NavigationServices 3.5.2 (163) <72cdc9d21f6690837870923e7b8ca358> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
    0x93308000 - 0x93333fe7  libauto.dylib ??? (???) <2e44c523b851e8e25f05d13a48070a58> /usr/lib/libauto.dylib
    0x93334000 - 0x93402ff3  com.apple.JavaScriptCore 5525.26 (5525.26.2) <a8929f0de97428798f858023b3ce2f60> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
    0x93403000 - 0x93480fef  libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
    0x93481000 - 0x9349fff3  com.apple.DirectoryService.Framework 3.5.6 (3.5.6) <daa1307737197c7757f44f16370249dc> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
    0x934a0000 - 0x9351dfeb  com.apple.audio.CoreAudio 3.1.2 (3.1.2) <5a4e6329f8dbca5dcd70924525afd24a> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x9351e000 - 0x93536fff  com.apple.openscripting 1.2.8 (???) <a6b446eb8ec7844096df5fb9002f5c7b> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
    0x93537000 - 0x9383ffff  com.apple.HIToolbox 1.5.5 (???) <b17766e3d8800a73f534c41f624f5ac4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
    0x93840000 - 0x93907ff2  com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
    0x93997000 - 0x9399afff  com.apple.help 1.1 (36) <1a25a8fbb49a830efb31d5c0a52939cd> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
    0x939ce000 - 0x939d3fff  com.apple.CommonPanels 1.2.4 (85) <c135f02edd6b2e2864311e0b9d08a98d> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
    0x939d4000 - 0x939d4ffd  com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x939d5000 - 0x94075fe3  com.apple.CoreGraphics 1.409.3 (???) <25dceb14af3455b768f56e8765ecf3ca> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x94076000 - 0x94086ffc  com.apple.LangAnalysis 1.6.4 (1.6.4) <7ae8dfd6cff0e34cf7c23ffc6cc291cb> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x94087000 - 0x94090fff  com.apple.speech.recognition.framework 3.7.24 (3.7.24) <da2d8411921a3fd8bc898dc753b7f3ee> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
    0x94091000 - 0x9409fffd  libz.1.dylib ??? (???) <a98b3b221a72b54faf73ded3dd7000e5> /usr/lib/libz.1.dylib
    0x940a0000 - 0x940a1ffc  libffi.dylib ??? (???) <eaf10b99a3fbc4920b175809407466c0> /usr/lib/libffi.dylib
    0x940a2000 - 0x94230fe7  com.apple.CoreAUC 3.07.2 (3.07.2) <08a5e0090d94e132ec9fa9ef4034941d> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAU C
    0x94231000 - 0x9423efe7  com.apple.opengl 1.5.10 (1.5.10) <5a2813f80c9441170cc1ab8a3dac5038> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x9423f000 - 0x9425effa  libJPEG.dylib ??? (???) <219f13f403b1e09a67f926c9269582e2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x942cd000 - 0x942cdffc  com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x942ce000 - 0x9468cfea  libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
    0x94692000 - 0x94702ff7  com.apple.iLifeMediaBrowser 2.0.2 (321) <096200840dfe3556d984bed9e9e1e4bc> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Version s/A/iLifeMediaBrowser
    0x94703000 - 0x94703ffb  com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/ InstallServer
    0x94704000 - 0x94837fef  com.apple.CoreFoundation 6.5.6 (476.18) <2d52bab73660117571bd6486dc318f8e> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
    0x9484c000 - 0x948a6ff7  com.apple.CoreText 2.0.4 (???) <f0b6c1d4f40bd21505097f0255abfead> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
    0x9494b000 - 0x949d7ff7  com.apple.LaunchServices 290.3 (290.6) <bdba267184df88bd5b8e2116ea903872> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
    0x94ba4000 - 0x94cddff7  libicucore.A.dylib ??? (???) <cac059ebdac7d9a63ee0f7a648c9f6cf> /usr/lib/libicucore.A.dylib
    0x94cde000 - 0x94cdeffe  com.apple.quartzframework 1.5 (1.5) <6865aa0aeaa584b5a54d43f2f21d6c08> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x94cdf000 - 0x94cdfffd  com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x94ce0000 - 0x94d9afe3  com.apple.CoreServices.OSServices 227 (227) <30cebcb68b1b571df7d77474e0c31556> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
    0x94d9b000 - 0x94da7fff  libbz2.1.0.dylib ??? (???) <2abfe3f3a9bb3207aba59b9103f5ab01> /usr/lib/libbz2.1.0.dylib
    0x94da8000 - 0x94efaff3  com.apple.audio.toolbox.AudioToolbox 1.5.2 (1.5.2) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
    0x94efb000 - 0x94f8efff  com.apple.ink.framework 101.3 (86) <d4c85b5cafa8027fff042b84a8be71dc> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
    0x951f8000 - 0x95236fff  libGLImage.dylib ??? (???) <a6425aeb77f4da13212ac75df57b056d> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
    0x95237000 - 0x9532bff4  libiconv.2.dylib ??? (???) <96ff4c6f84c4a1623cb78287371cdd3f> /usr/lib/libiconv.2.dylib
    0x9532c000 - 0x9533cfff  com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <273d96ff861dc68be659c07ef56f599a> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x9533d000 - 0x9538cfff  com.apple.QuickLookUIFramework 1.3.1 (170.9) /System/Library/PrivateFrameworks/QuickLookUI.framework/Versions/A/Qu ickLookUI
    0x953bd000 - 0x96398ff6  com.apple.QuickTimeComponents.component 7.6 (1291) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacO S/QuickTimeComponents
    0x96399000 - 0x967a9fef  libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
    0x967aa000 - 0x96831ff7  libsqlite3.0.dylib ??? (???) <3334ea5af7a911637413334154bb4100> /usr/lib/libsqlite3.0.dylib
    0x96832000 - 0x96839fff  com.apple.agl 3.0.9 (AGL-3.0.9) <d64d715dab8565014f5e2f239fd2410c> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x9683a000 - 0x968b4ff8  com.apple.print.framework.PrintCore 5.5.4 (245.6) <03d0585059c20cb0bde5e000438c49e1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
    0x968b5000 - 0x968c0fe7  libCSync.A.dylib ??? (???) <9e3544fe087bb4dc760b7afe0850dd6c> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x968f6000 - 0x96c93fef  com.apple.QuartzCore 1.5.8 (1.5.8) <a28fa54346a9f9d5b3bef076a1ee0fcf> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x96c94000 - 0x96f6eff3  com.apple.CoreServices.CarbonCore 786.11 (786.13) <9e2d85d52e5e2951aa4dd53c48ccc52f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
    0x96f6f000 - 0x9704ffff  libobjc.A.dylib ??? (???) <d1469bf9fe852864d4fff185c72768e8> /usr/lib/libobjc.A.dylib
    0x97050000 - 0x970adffb  libstdc++.6.dylib ??? (???) <7d389389a99ce696726cf4c8980cc505> /usr/lib/libstdc++.6.dylib
    0x970ae000 - 0x970b0ff1  com.apple.QuickTimeH264.component 7.6 (1291) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/Quic kTimeH264
    0x970b1000 - 0x970b8ff7  libCGATS.A.dylib ??? (???) <211348279493364e9920adc86484cedd> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
    0x97153000 - 0x97153ffe  com.apple.MonitorPanelFramework 1.2.0 (1.2.0) <1f4c10fcc17187a6f106e0a0be8236b0> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/M onitorPanel
    0x97154000 - 0x971e7ff3  com.apple.ApplicationServices.ATS 3.7 (???) <a535fc4982d3acff6530ec25c402e679> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
    0x971ed000 - 0x971f9ffe  libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
    0x9723f000 - 0x97244fff  com.apple.DisplayServicesFW 2.0.2 (2.0.2) <df0c1a58d119d2dd90182cd2d88ccf58> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/ A/DisplayServices
    0x97245000 - 0x97272feb  libvDSP.dylib ??? (???) <4daafed78a471133ec30b3ae634b6d3e> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
    0x97273000 - 0x97290ff7  com.apple.QuickLookFramework 1.3.1 (170.9) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x97299000 - 0x972b7fff  libresolv.9.dylib ??? (???) <39f6d8651f3dca7a1534fa04322e6763> /usr/lib/libresolv.9.dylib
    0xb0000000 - 0xb0006ff8  com.apple.carbonframeworktemplate 1.3 (1.3.12) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
    0xba900000 - 0xba916fff  libJapaneseConverter.dylib ??? (???) <1ed47ca6a3bfe0c9bf656dfe3d5cc7c0> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
    0xbab00000 - 0xbab21fe2  libKoreanConverter.dylib ??? (???) <2c1a357c75d048e1eedb6c40a3f5b0e1> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
    0xfffe8000 - 0xfffebfff  libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
    0xffff0000 - 0xffff1780  libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
    May 14, 2009 9:26 AM   in reply to DGJ193
    Process:         Adobe Photoshop CS4 [341]
    Parent Process:  launchd [243]
    Date/Time:       2009-05-12 20:39:54.924 -0400
    Report Version:  6
    Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x00000000ffdf4060
    Crashed Thread:  0
    Thread 0 Crashed:
    0   com.apple.HIToolbox           0x9357d4d8 RemoveEventHandler + 48
    1   com.apple.HIToolbox           0x9369e122 CCarbonEventHandler::InitCarbonEventHandler(TXNCarbonEventInfo*) + 344
    2   com.apple.HIToolbox           0x9369df8e CTextension::StartCarbonEventHandler(OpaqueTXNObject*, TXNCarbonEventInfo*) + 112
    3   com.apple.HIToolbox           0x935e52e2 OpaqueTXNObject::InstallCarbonEventHandler(OpaqueWindowPtr*, OpaqueWindowPtr*) + 384
    4   com.apple.HIToolbox           0x93691858 OpaqueTXNObject::AttachObjectToWindowRef(OpaqueWindowPtr*, unsigned char) + 388
    5   com.apple.HIToolbox           0x936d2430 TXNAttachObjectToWindowRef + 66
    6   com.adobe.Photoshop           0x000c3f8e 0x1000 + 798606
    7   com.adobe.Photoshop           0x000c69c6 0x1000 + 809414
    8   com.adobe.Photoshop           0x000d29dd 0x1000 + 858589
    9   com.adobe.Photoshop           0x000d2bab 0x1000 + 859051
    10  com.adobe.Photoshop           0x000d2bab 0x1000 + 859051
    11  com.adobe.Photoshop           0x000d2bab 0x1000 + 859051
    12  com.adobe.Photoshop           0x000d2bab 0x1000 + 859051
    13  com.adobe.Photoshop           0x000d2bab 0x1000 + 859051
    14  com.adobe.Photoshop           0x000d2bab 0x1000 + 859051
    15  com.adobe.Photoshop           0x000d2bab 0x1000 + 859051
    16  com.adobe.Photoshop           0x000d2bab 0x1000 + 859051
    17  com.adobe.Photoshop           0x002fcbcb 0x1000 + 3128267
    18  com.adobe.Photoshop           0x002fd40f 0x1000 + 3130383
    19  com.adobe.Photoshop           0x002fd773 0x1000 + 3131251
    20  com.adobe.Photoshop           0x000cdcab 0x1000 + 838827
    21  com.adobe.Photoshop           0x000d29a2 0x1000 + 858530
    22  com.adobe.Photoshop           0x000d2bab 0x1000 + 859051
    23  com.adobe.Photoshop           0x000d2bab 0x1000 + 859051
    24  com.adobe.Photoshop           0x000d99f5 0x1000 + 887285
    25  com.adobe.Photoshop           0x000d2df0 0x1000 + 859632
    26  com.adobe.Photoshop           0x000d2df0 0x1000 + 859632
    27  com.adobe.Photoshop           0x000d2df0 0x1000 + 859632
    28  com.adobe.Photoshop           0x000d2df0 0x1000 + 859632
    29  com.adobe.Photoshop           0x000d2df0 0x1000 + 859632
    30  com.adobe.Photoshop           0x000d2df0 0x1000 + 859632
    31  com.adobe.Photoshop           0x0006e70c 0x1000 + 448268
    32  com.adobe.Photoshop           0x000d2df0 0x1000 + 859632
    33  com.adobe.Photoshop           0x0006e70c 0x1000 + 448268
    34  com.adobe.Photoshop           0x000d2df0 0x1000 + 859632
    35  com.adobe.Photoshop           0x000bb51c 0x1000 + 763164
    36  com.adobe.Photoshop           0x000d2df0 0x1000 + 859632
    37  com.adobe.Photoshop           0x000c9be9 0x1000 + 822249
    38  com.adobe.Photoshop           0x0034ca1d 0x1000 + 3455517
    39  com.adobe.Photoshop           0x00566ae4 0x1000 + 5659364
    40  com.adobe.Photoshop           0x004eb324 0x1000 + 5153572
    41  com.adobe.Photoshop           0x004ebc7e 0x1000 + 5155966
    42  com.adobe.Photoshop           0x004ebd09 0x1000 + 5156105
    43  com.adobe.Photoshop           0x0048cc4a 0x1000 + 4766794
    44  com.adobe.Photoshop           0x0048de73 0x1000 + 4771443
    45  com.adobe.Photoshop           0x0006b9ed 0x1000 + 436717
    46  com.adobe.Photoshop           0x0006a79d 0x1000 + 432029
    47  com.adobe.Photoshop           0x00063d65 0x1000 + 404837
    48  com.adobe.Photoshop           0x00063ed3 0x1000 + 405203
    49  com.adobe.Photoshop           0x0006222f 0x1000 + 397871
    50  com.adobe.Photoshop           0x002206aa 0x1000 + 2225834
    51  com.adobe.Photoshop           0x00220736 0x1000 + 2225974
    52  com.adobe.Photoshop           0x00003912 0x1000 + 10514
    53  com.adobe.Photoshop           0x00003839 0x1000 + 10297
    Thread 1:
    Thread 2:
    3   com.adobe.amt.services        0x04b69552 AMTConditionLock::LockWhenCondition(int) + 46
    4   com.adobe.amt.services        0x04b64995 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 115
    5   com.adobe.amt.services        0x04b695b0 AMTThread::Worker(void*) + 20
    Thread 3:
    Thread 4:
    2   MultiProcessor Support        0x1e2a3eff 0x1e274000 + 196351
    Thread 5:
    Thread 6:
    Thread 7:
    Thread 8:
    Thread 9:
    Thread 10:
    Thread 11:
    Thread 12:
    Thread 13:
    Thread 14:
    Thread 15:
    Thread 16:
    Thread 17:
    Thread 18:
    Thread 19:
    Thread 20:
    Thread 21:
    Thread 22:
    Thread 23:
    Thread 24:
    Thread 25:
    Thread 26:
    Thread 27:
    Thread 28:
    Thread 29:
    Thread 30:
    Thread 31:
    Thread 32:
    Thread 33:
    Thread 34:
    2   com.adobe.PSAutomate          0x23cc6755 ScObjects::Thread::sleep(unsigned int) + 143
    3   com.adobe.PSAutomate          0x23cc67b5 ScObjects::Thread::wait(unsigned int) + 23
    4   com.adobe.PSAutomate          0x23cb7502 ScObjects::BridgeTalkThread::run() + 332
    5   com.adobe.PSAutomate          0x23cc6a77 ScObjects::Thread::go(void*) + 239
    Thread 35:
    Thread 36:
    Thread 37:
    Thread 38:
    Thread 39:
    Thread 40:
    Thread 41:
    Thread 42:
    Thread 43:
    Thread 44:
    Thread 45:
    Thread 46:
    Thread 47:
    Thread 48:
    Thread 49:
    Thread 50:
    Thread 51:
    Thread 52:
    Thread 53:
    Thread 54:
    Thread 55:
    Thread 56:
    5   com.adobe.CameraRaw           0x2b5ff438 0x2b444000 + 1815608
    6   com.adobe.CameraRaw           0x2b5fed36 0x2b444000 + 1813814
    Thread 57:
    Thread 58:
    Thread 59:
    Thread 60:
    Thread 61:
    Thread 62:
    Thread 63:
    Thread 64:
    Thread 65:
    Thread 66:
    Thread 67:
    Thread 68:
    Thread 69:
    Thread 70:
    Thread 71:
    3   com.adobe.CameraRaw           0x2b48903a 0x2b444000 + 282682
    4   com.adobe.CameraRaw           0x2b73a374 EntryFM + 802340
    5   com.adobe.CameraRaw           0x2b5290e6 0x2b444000 + 938214
    Thread 72:
    4   com.adobe.CameraRaw           0x2b7c9f88 EntryFM + 1391160
    Thread 73:
    Thread 74:
    Thread 75:
      eax: 0xffdf4060  ebx: 0x9357d4b9  ecx: 0x0001bef9  edx: 0xffdf4060
      edi: 0x1e9426e0  esi: 0xffdf4060  ebp: 0xbfffdb28  esp: 0xbfffdb00
       ss: 0x0000001f  efl: 0x00010246  eip: 0x9357d4d8   cs: 0x00000017
      cr2: 0xffdf4060
    Binary Images:
    0x4b35000 -  0x4b36fe1  com.apple.textencoding.unicode 2.2 (2.2) <09ac11c81bf4e673a30cc364868fdc11> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
    0x4b49000 -  0x4beafc3 +com.adobe.amt.services AMTServices 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) <31e82904c3c2424ea1aea5efadbb19b8> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/amtservices.framework/Versions/a/amtservi ces
    0x4d92000 -  0x4d94fff +com.unsanity.menuextraenabler 1.0.3 (1.0.3) /Library/InputManagers/Menu Extra Enabler/Menu Extra Enabler.bundle/Contents/MacOS/Menu Extra Enabler
    0x4dc6000 -  0x4dd4feb  libSimplifiedChineseConverter.dylib ??? (???) <c3123eb807ed45151fe0d12da8e51d04> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
    0x4dd9000 -  0x4debfff  libTraditionalChineseConverter.dylib ??? (???) <8a2b4c7bfd8d7941fcf64a2575095e36> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
    0x4def000 -  0x4df0ff3  ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
    0x4df8000 -  0x4df8ffd  libmx.A.dylib ??? (???) /usr/lib/libmx.A.dylib
    0xcf9d000 -  0xcf9effb  libGreekConverter.dylib ??? (???) <b63c7bb67f5eb753eb48fda5a428f638> /System/Library/CoreServices/Encodings/libGreekConverter.dylib
    0xd24d000 -  0xd24efff  libCyrillicConverter.dylib ??? (???) <4fec2bf92f6c26af7c58119df77674bf> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
    0xd3ba000 -  0xd3bafe3  libThaiConverter.dylib ??? (???) <181e3ebe4ca849331c03a19ac575e3f0> /System/Library/CoreServices/Encodings/libThaiConverter.dylib
    0x197c7000 - 0x197d4ff7 +com.adobe.asneu.framework asneu version 1.6.2f01 (1.6.2) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/asneu.framework/Versions/a/asneu
    0x197e2000 - 0x197e4ffa +Adobe Unit Types a2.0.0 (2.0.0) /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types
    0x1a920000 - 0x1a92affe  com.apple.URLMount 3.1.1 (3.1.1) <0189760dca64cd07c190e1a7b10283e5> /System/Library/PrivateFrameworks/URLMount.framework/URLMount
    0x1ab00000 - 0x1ab6efd7 + ??? (???)
    0x1add7000 - 0x1add7fff +com.insidersoftware.fontagentpro.pluginsupportframework FontAgent Pro 4.0.3 build 41A6 (4.0.3) <1a613241bd6d4f4a8d3cad85995d88cd> /Library/Frameworks/FAProPluginSupport.framework/FAProPluginSupport
    0x1c03c000 - 0x1c03ffff +com.stclairsoft.DefaultFolderX.osax Default Folder X Addition version 1.0 (4.2d11) <20ae7639d6757ddcf4bc4056fe20f03c> /Users/beige/Library/ScriptingAdditions/Default Folder X Addition.osax/Contents/MacOS/Default Folder X Addition
    0x1c045000 - 0x1c066feb +com.stclairsoft.DefaultFolderX.CarbonPatcher kBundleVersion (kBundleVersion) <8b93f82fae47535ac5ac173ee8e6040b> /Users/beige/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Carbon Patcher.bundle/Contents/MacOS/Carbon Patcher
    0x1c073000 - 0x1c091ff7 +Cocoa Patcher ??? (???) <f334cea477fc7dfa50ece44251cb5a78> /Users/beige/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Cocoa Patcher.bundle/Contents/MacOS/Cocoa Patcher
    0x1c1d1000 - 0x1c1f4ff7 +CSI-Launcher.dylib ??? (???) /Library/Application Support/Adobe/CS4ServiceManager/CSI-Launcher.dylib
    0x1c227000 - 0x1c22cff3  libCGXCoreImage.A.dylib ??? (???) <3a78abc535c80f9819931b670da804a2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage. A.dylib
    0x1c4f2000 - 0x1c6eafff  com.apple.RawCamera.bundle 2.0.14 (436) <a8dd51882088fae463f33bc0674583e8> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
    0x1c9b3000 - 0x1cb38fe3  GLEngine ??? (???) <3bd4729832411ff31de5bb9d97e3718d> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle /GLEngine
    0x1cb66000 - 0x1ce44ff1  com.apple.ATIRadeonX2000GLDriver 1.5.44 (5.4.4) <aeb5e93202779fb8e0f5da88291ce9f6> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/Mac OS/ATIRadeonX2000GLDriver
    0x1cea8000 - 0x1cec4ff7  GLRendererFloat ??? (???) <927b7d5ce6a7c21fdc761f6f29cdf4ee> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRe ndererFloat.bundle/GLRendererFloat
    0x1dfc3000 - 0x1dfcefff +Enable Async IO ??? (???) <fd91e79fc4aa4ebcaf6d3e154f14878f> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/Enable Async IO.plugin/Contents/MacOS/Enable Async IO
    0x1dfd3000 - 0x1dfdefff +UseOldShortcuts ??? (???) <a9de9f74fcf34c1cacf5cc296335f84d> /Applications/Adobe Photoshop CS4/Plug-ins/UseOldShortcuts.plugin/Contents/MacOS/UseOldShortcuts
    0x1dfe3000 - 0x1dff102f +FastCore ??? (???) <f12878b7bee940ca9f0565cd0f5688e2> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
    0x1e14f000 - 0x1e15affb +PPCCore ??? (???) <ed521eb7681d45aa9ae36bf4663e4bd3> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/PPCCore.plugin/Contents/MacOS/PPCCore
    0x1e160000 - 0x1e16bffe +AltiVecCore ??? (???) <a967ae2af2ae4e12a7b668b981cbd906> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/AltiVecCore.plugin/Contents/MacOS/AltiVecCore
    0x1e171000 - 0x1e1d6fe3 +MMXCore ??? (???) <e206c8dcaea849df8fbc8b447e3a59a1> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
    0x1e274000 - 0x1e2bbff7 +MultiProcessor Support ??? (???) <001a163b53144613a23af35b63065fd0> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
    0x1e2d3000 - 0x1e425fc7 +com.adobe.coretech.adm 3.10x16 (3.1) /Applications/Adobe Photoshop CS4/Plug-ins/ADM/AdobeADM.bundle/Contents/MacOS/AdobeADM
    0x1f1ae000 - 0x1f1bdfe3 +FontAgent Pro ??? (???) <cd990c15489c946a041b570f3f9879ed> /Applications/Adobe Photoshop CS4/Plug-ins/FontAgent Pro.plugin/Contents/MacOS/FontAgent Pro
    0x1f349000 - 0x1f356fff +com.alienskin.autolayer2 2.0.1 (2.0.1) <420807129f42aa6e0264f66de8c18c6b> /Applications/Adobe Photoshop CS4/Plug-ins/Alien Skin/Autolayer2.plugin/Contents/MacOS/Autolayer2
    0x20162000 - 0x2016eff3 +net.telestream.license 1.0.0.2-GC (1.0.0.2-GC) <1e96dd44a98bbc9c09855d80a6ea4574> /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
    0x202ca000 - 0x202e4fc3  com.apple.AppleIntermediateCodec 1.2 (145) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/Ap pleIntermediateCodec
    0x20bf6000 - 0x20bfbff7  com.apple.AppleMPEG2Codec 1.0.1 (220) <6fdff3c87ececb7413749c0230c54f78> /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG 2Codec
    0x23b92000 - 0x23deefdf +com.adobe.PSAutomate 11.0 (11.0) /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/Script ingSupport
    0x24082000 - 0x24150fff +AdobeExtendScript ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/Ad obeExtendScript
    0x241c7000 - 0x24268fd7 +AdobeScCore ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScC ore
    0x24c2c000 - 0x24c5dfe3 +com.adobe.amt.registration AMTRegistration 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/registration.framework/Versions/a/registr ation
    0x24c96000 - 0x24cf2ff2 +AdobeUpdater ??? (???) <064cfaa41caf46e3bebf04948641c927> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeUpdater.framework/Versions/a/AdobeUp dater
    0x24fe2000 - 0x24ffbff3  com.apple.applepixletvideo 1.2.18 (1.2d18) <386af0b779e8c148e6b6cbc7f5489d45> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/A pplePixletVideo
    0x29f3f000 - 0x2a046fcf +com.adobe.versioncue ??? (4.0.1.095) /Library/Application Support/Adobe/Adobe Version Cue CS4/Client/4.0.1/VersionCue.framework/VersionCue
    0x2b444000 - 0x2bb4bff9 +com.adobe.CameraRaw 5.3 (5.3.0f21) <077769d6e7737a315c4fb417c2ae4dcd> /Library/Application Support/Adobe/Plug-Ins/CS4/File Formats/Camera Raw.plugin/Contents/MacOS/Camera Raw
    0x32d37000 - 0x32d5afe7  com.apple.AppleProResDecoder 1.0.1 (53) /System/Library/QuickTime/AppleProResDecoder.component/Contents/MacOS /AppleProResDecoder
    0x32eb7000 - 0x33155ff0 +org.perian.Perian 1.1.3 (1.1.3) <7baeef0d5eeb1d10d9b0c9293effe582> /Users/beige/Library/QuickTime/Perian.component/Contents/MacOS/Perian
    0x333e7000 - 0x33422fff  com.apple.QuickTimeFireWireDV.component 7.6 (1291) /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacO S/QuickTimeFireWireDV
    0x3342f000 - 0x3347dfe3  com.apple.AppleVAFramework 4.1.16 (4.1.16) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleV A
    0x3b190000 - 0x3b387fd2 +net.telestream.wmv.import 2.2.2.3 (2.2.2.3) <77e650a498b347a8af2eacf5ceeebf9f> /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
    0x3b3bb000 - 0x3b51dfe2 +net.telestream.wmv.advanced 2.2.2.3 (2.2.2.3) <d5ceb82d96d540efad02bf868248ce5d> /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
    0x3d429000 - 0x3d48efef  com.apple.AppleVAH264HW.component 1.0 (1.0) <f625e0d0d8c834ee6d65370345c2f6bc> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/Appl eVAH264HW
    May 14, 2009 9:26 AM   in reply to cgbeige
    Process:         Adobe Photoshop CS4 [5388]
    Date/Time:       2009-05-13 15:31:59.835 -0400
    Report Version:  6
    Exception Codes: KERN_INVALID_ADDRESS at 0x00000000fb1afa1c
    Crashed Thread:  0
    Thread 0 Crashed:
    0   ???                           0x548df005 0 + 1418588165
    1   libSystem.B.dylib             0x90071fd1 fork + 17
    2   com.vertustech.FluidMaskPlugin 0x2003c2e2 0x20037000 + 21218
    3   com.vertustech.FluidMaskPlugin 0x2003c3bc 0x20037000 + 21436
    4   com.vertustech.FluidMaskPlugin 0x2003d37f PluginMain + 111
    5   com.adobe.Photoshop           0x006c044e 0x1000 + 7074894
    6   com.adobe.Photoshop           0x0040e751 0x1000 + 4249425
    7   com.adobe.Photoshop           0x00412e6a 0x1000 + 4267626
    8   com.adobe.Photoshop           0x0040bee4 0x1000 + 4239076
    9   com.adobe.Photoshop           0x00410c53 0x1000 + 4258899
    10  com.adobe.Photoshop           0x00712708 0x1000 + 7411464
    11  com.adobe.Photoshop           0x007132d3 0x1000 + 7414483
    12  com.adobe.Photoshop           0x0040cf0a 0x1000 + 4243210
    13  com.adobe.Photoshop           0x0070f4f7 0x1000 + 7398647
    14  com.adobe.Photoshop           0x0070fe39 0x1000 + 7401017
    15  com.adobe.Photoshop           0x0040d254 0x1000 + 4244052
    16  com.adobe.Photoshop           0x00410c11 0x1000 + 4258833
    17  com.adobe.Photoshop           0x0048cc4a 0x1000 + 4766794
    18  com.adobe.Photoshop           0x0048de73 0x1000 + 4771443
    19  com.adobe.Photoshop           0x0006b9ed 0x1000 + 436717
    20  com.adobe.Photoshop           0x0006a79d 0x1000 + 432029
    21  com.adobe.Photoshop           0x00063d65 0x1000 + 404837
    22  com.adobe.Photoshop           0x00063ed3 0x1000 + 405203
    23  com.adobe.Photoshop           0x0006222f 0x1000 + 397871
    24  com.adobe.Photoshop           0x002206aa 0x1000 + 2225834
    25  com.adobe.Photoshop           0x00220736 0x1000 + 2225974
    26  com.adobe.Photoshop           0x00003912 0x1000 + 10514
    27  com.adobe.Photoshop           0x00003839 0x1000 + 10297
    Thread 1:
    Thread 2:
    3   com.adobe.amt.services        0x04b7c552 AMTConditionLock::LockWhenCondition(int) + 46
    4   com.adobe.amt.services        0x04b77995 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 115
    5   com.adobe.amt.services        0x04b7c5b0 AMTThread::Worker(void*) + 20
    Thread 3:
    Thread 4:
    2   MultiProcessor Support        0x1e232eff 0x1e203000 + 196351
    Thread 5:
    Thread 6:
    Thread 7:
    Thread 8:
    Thread 9:
    Thread 10:
    Thread 11:
    Thread 12:
    Thread 13:
    Thread 14:
    Thread 15:
    Thread 16:
    Thread 17:
    Thread 18:
    Thread 19:
    Thread 20:
    Thread 21:
    Thread 22:
    Thread 23:
    Thread 24:
    Thread 25:
    Thread 26:
    Thread 27:
    Thread 28:
    Thread 29:
    Thread 30:
    Thread 31:
    Thread 32:
    Thread 33:
    Thread 34:
    2   com.adobe.PSAutomate          0x23c7f755 ScObjects::Thread::sleep(unsigned int) + 143
    3   com.adobe.PSAutomate          0x23c7f7b5 ScObjects::Thread::wait(unsigned int) + 23
    4   com.adobe.PSAutomate          0x23c70502 ScObjects::BridgeTalkThread::run() + 332
    5   com.adobe.PSAutomate          0x23c7fa77 ScObjects::Thread::go(void*) + 239
    Thread 35:
    5   com.adobe.CameraRaw           0x25c86438 0x25acb000 + 1815608
    6   com.adobe.CameraRaw           0x25c85d36 0x25acb000 + 1813814
    Thread 36:
    Thread 37:
    Thread 38:
    Thread 39:
    Thread 40:
    Thread 41:
    Thread 42:
    Thread 43:
    Thread 44:
    Thread 45:
    Thread 46:
    Thread 47:
    Thread 48:
    Thread 49:
    Thread 50:
    3   com.adobe.CameraRaw           0x25b1003a 0x25acb000 + 282682
    4   com.adobe.CameraRaw           0x25dc1374 EntryFM + 802340
    5   com.adobe.CameraRaw           0x25bb00e6 0x25acb000 + 938214
    Thread 51:
    4   com.adobe.CameraRaw           0x25e50f88 EntryFM + 1391160
    Thread 52:
    Thread 53:
    Thread 54:
    Thread 55:
    Thread 56:
    Thread 57:
    Thread 58:
    Thread 59:
    Thread 60:
    Thread 61:
    Thread 62:
    Thread 63:
    Thread 64:
    Thread 65:
    Thread 66:
    Thread 67:
    Thread 68:
    3   com.apple.CoreFoundation      0x94777c78 CFRunLoopRunInMode + 88
    4   com.apple.Foundation          0x93052530 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 320
    5   com.apple.Foundation          0x92feee0d -[NSThread main] + 45
    6   com.apple.Foundation          0x92fee9b4 __NSThread__main__ + 308
    Thread 69:
    4   com.apple.CFNetwork           0x90294298 CFURLCacheWorkerThread(void*) + 388
    5   libSystem.B.dylib             0x90065155 _pthread_start + 321
    6   libSystem.B.dylib             0x90065012 thread_start + 34
    Thread 70:
      eax: 0x5871b999  ebx: 0x9007206e  ecx: 0xa001483c  edx: 0xffffffff
      edi: 0x50c5e8b0  esi: 0x3989fcd0  ebp: 0xbfffd0a8  esp: 0xbfffd08c
       ss: 0x0000001f  efl: 0x00010217  eip: 0x548df005   cs: 0x00000017
      cr2: 0xfb1afa1c
    Binary Images:
    0x4b49000 -  0x4b4afe1  com.apple.textencoding.unicode 2.2 (2.2) <09ac11c81bf4e673a30cc364868fdc11> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
    0x4b5c000 -  0x4bfdfc3 +com.adobe.amt.services AMTServices 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) <31e82904c3c2424ea1aea5efadbb19b8> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/amtservices.framework/Versions/a/amtservi ces
    0x4da6000 -  0x4da8fff +com.unsanity.menuextraenabler 1.0.3 (1.0.3) /Library/InputManagers/Menu Extra Enabler/Menu Extra Enabler.bundle/Contents/MacOS/Menu Extra Enabler
    0x4dda000 -  0x4de8feb  libSimplifiedChineseConverter.dylib ??? (???) <c3123eb807ed45151fe0d12da8e51d04> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
    0x4ded000 -  0x4deeff3  ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
    0x4df6000 -  0x4df6ffd  libmx.A.dylib ??? (???) /usr/lib/libmx.A.dylib
    0x4f00000 -  0x4f12fff  libTraditionalChineseConverter.dylib ??? (???) <8a2b4c7bfd8d7941fcf64a2575095e36> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
    0x4f80000 -  0x4f8dff7 +com.adobe.asneu.framework asneu version 1.6.2f01 (1.6.2) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/asneu.framework/Versions/a/asneu
    0x4f9b000 -  0x4f9dffa +Adobe Unit Types a2.0.0 (2.0.0) /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types
    0x1c1d8000 - 0x1c1fbff7 +CSI-Launcher.dylib ??? (???) /Library/Application Support/Adobe/CS4ServiceManager/CSI-Launcher.dylib
    0x1c552000 - 0x1c74afff  com.apple.RawCamera.bundle 2.0.14 (436) <a8dd51882088fae463f33bc0674583e8> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
    0x1c9cc000 - 0x1cb51fe3  GLEngine ??? (???) <3bd4729832411ff31de5bb9d97e3718d> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle /GLEngine
    0x1cb7f000 - 0x1ce5dff1  com.apple.ATIRadeonX2000GLDriver 1.5.44 (5.4.4) <aeb5e93202779fb8e0f5da88291ce9f6> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/Mac OS/ATIRadeonX2000GLDriver
    0x1cec1000 - 0x1ceddff7  GLRendererFloat ??? (???) <927b7d5ce6a7c21fdc761f6f29cdf4ee> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRe ndererFloat.bundle/GLRendererFloat
    0x1df9b000 - 0x1dfa6fff +Enable Async IO ??? (???) <fd91e79fc4aa4ebcaf6d3e154f14878f> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/Enable Async IO.plugin/Contents/MacOS/Enable Async IO
    0x1dfab000 - 0x1dfb6fff +UseOldShortcuts ??? (???) <a9de9f74fcf34c1cacf5cc296335f84d> /Applications/Adobe Photoshop CS4/Plug-ins/UseOldShortcuts.plugin/Contents/MacOS/UseOldShortcuts
    0x1dfbb000 - 0x1dfc902f +FastCore ??? (???) <f12878b7bee940ca9f0565cd0f5688e2> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
    0x1dfcf000 - 0x1dfdaffb +PPCCore ??? (???) <ed521eb7681d45aa9ae36bf4663e4bd3> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/PPCCore.plugin/Contents/MacOS/PPCCore
    0x1dfe0000 - 0x1dfebffe +AltiVecCore ??? (???) <a967ae2af2ae4e12a7b668b981cbd906> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/AltiVecCore.plugin/Contents/MacOS/AltiVecCore
    0x1e100000 - 0x1e165fe3 +MMXCore ??? (???) <e206c8dcaea849df8fbc8b447e3a59a1> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
    0x1e203000 - 0x1e24aff7 +MultiProcessor Support ??? (???) <001a163b53144613a23af35b63065fd0> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
    0x1e255000 - 0x1e3a7fc7 +com.adobe.coretech.adm 3.10x16 (3.1) /Applications/Adobe Photoshop CS4/Plug-ins/ADM/AdobeADM.bundle/Contents/MacOS/AdobeADM
    0x1f17a000 - 0x1f187fff +com.alienskin.autolayer2 2.0.1 (2.0.1) <420807129f42aa6e0264f66de8c18c6b> /Applications/Adobe Photoshop CS4/Plug-ins/Alien Skin/Autolayer2.plugin/Contents/MacOS/Autolayer2
    0x20037000 - 0x2003ff27 +com.vertustech.FluidMaskPlugin 3.0.2 (4471) /Applications/Adobe Photoshop CS4/Plug-ins/Vertus/Fluid Mask 3.plugin/Contents/MacOS/FluidMask
    0x23b4b000 - 0x23da7fdf +com.adobe.PSAutomate 11.0 (11.0) /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/Script ingSupport
    0x2403b000 - 0x24109fff +AdobeExtendScript ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/Ad obeExtendScript
    0x24180000 - 0x24221fd7 +AdobeScCore ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScC ore
    0x244f0000 - 0x24521fe3 +com.adobe.amt.registration AMTRegistration 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/registration.framework/Versions/a/registr ation
    0x2455a000 - 0x245b6ff2 +AdobeUpdater ??? (???) <064cfaa41caf46e3bebf04948641c927> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeUpdater.framework/Versions/a/AdobeUp dater
    0x24d46000 - 0x251c8fe3 +AdobeLM_libFNP.dylib ??? (???) <02e9ac769cc64974af0548e737c2cc20> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/amtlib.framework/Versions/a/AdobeLM_libFN P.dylib
    0x25acb000 - 0x261d2ff9 +com.adobe.CameraRaw 5.3 (5.3.0f21) <077769d6e7737a315c4fb417c2ae4dcd> /Library/Application Support/Adobe/Plug-Ins/CS4/File Formats/Camera Raw.plugin/Contents/MacOS/Camera Raw
    0x387bd000 - 0x3882bfd7 + ??? (???)
    0x42405000 - 0x4250cfcf +com.adobe.versioncue ??? (4.0.1.095) /Library/Application Support/Adobe/Adobe Version Cue CS4/Client/4.0.1/VersionCue.framework/VersionCue
    0x50ec3000 - 0x50edafff +com.topazlabs.framework.cocoaAdjust ??? (1.0) <fe4f91fa56e0c6372a42ed6d54e60957> /Library/Application Support/Topaz Labs/Adjust 3/Plugins/Topaz_adjust3.plugin/Contents/PlugIns/adjust_cocoa.bundle/C ontents/Frameworks/TopazLabsCocoaAdjust.framework/Versions/A/TopazLabs CocoaAdjust
    0x51337000 - 0x513bbfff  com.apple.xquery 1.3 (27) /System/Library/PrivateFrameworks/XQuery.framework/XQuery
    0x92b11000 - 0x92b47fef  libtidy.A.dylib ??? (???) <7b9fc90dc0d50da27a24f6f84ccdd7b7> /usr/lib/libtidy.A.dylib
    May 14, 2009 11:25 AM   in reply to cgbeige
    Application Specific Information:
    *** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '*** -[NSCFType drain]: unrecognized selector sent to instance 0x199584f0'
    Thread 0 Crashed:
    0   com.apple.CoreFoundation          0x97200f54 ___TERMINATING_DUE_TO_UNCAUGHT_EXCEPTION___ + 4
    1   libobjc.A.dylib                   0x921e4e3b objc_exception_throw + 40
    2   com.apple.CoreFoundation          0x97187a53 CFRunLoopRunSpecific + 4355
    3   com.apple.CoreFoundation          0x97187c78 CFRunLoopRunInMode + 88
    4   com.apple.HIToolbox               0x94abf28c RunCurrentEventLoopInMode + 283
    5   com.apple.HIToolbox               0x94b727ac GetNextEventMatchingMask + 100
    6   com.apple.HIToolbox               0x94b7260e WNEInternal + 151
    7   com.apple.HIToolbox               0x94b7256d WaitNextEvent + 54
    That's an Apple bug of some kind.  Their Objective-C runtime encountered a problem.  It could be due to a plugin that used Objective-C and then unloaded the UI, which is a known defect in Apple's Objective-C runtime code (but a big problem that may not get a fix soon).
    Exception Codes: KERN_INVALID_ADDRESS at 0x00000000c765a8f3
    Crashed Thread:  0
    Thread 0 Crashed:
    0   libobjc.A.dylib                   0x921f0688 objc_msgSend + 24
    1   com.apple.HIToolbox               0x94b2d57c IdleTimerVector + 59
    2   com.apple.CoreFoundation          0x97187ac5 CFRunLoopRunSpecific + 4469
    5   com.apple.HIToolbox               0x94b72907 GetNextEventMatchingMask + 447
    Well inside Apple's code, Objective-C runtime, could be the same sort of problem as above.
    Exception Type:  EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000094a18a8
    Crashed Thread:  0
    Thread 0 Crashed:
    0   com.apple.QD                      0x92c943cd _SetDstBits32BGRA + 8
    1   com.apple.QD                      0x92cb64f0 DevFrameRect + 795
    2   com.apple.QD                      0x92c7b89d StdRectWithPort + 267
    3   com.apple.QD                      0x92c7b77b CallRect + 53
    4   com.apple.QD                      0x92cb61d3 FrameRect + 43
    QuickDraw bug, reported to Apple and was SUPPOSED to be fixed in 10.5.7 (grumble).
    Crashed Thread:  0
    Thread 0 Crashed:
    Hmm, another text related crash inside Apple's text code. Could be related to the previously mentioned TSNDelete crasher.  I really hoped they fixed all of those in 10.5.7.
    Crashed Thread:
    Thread 0 Crashed:
    This is a bug in your Vertus FluidMask plugin. Contact the plugin vendor.
    May 14, 2009 11:49 AM   in reply to Chris Cox
    ah - thanks Chris.
    Dave
    May 14, 2009 12:33 PM   in reply to DGJ193
    Apple hasn't given us the details of their text related crashes. (or most of their crashes for that matter)
    My guess is that the crash depends on some history and configuration -- what operations were done before, how much RAM is available, what plugins are loaded, etc.  That changes what values are in memory, and when a bug happens it frequently reads a wrong location from memory (or one that wasn't initialized) and may crash depending on the exact value read.  It could even come down to what fonts are installed, or what web sites you recently browsed -- we just don't know.
    Some of the Objective-C crashes, I have absolutely no idea about.  We've identified a lot of fragile parts of the Objective-C runtime and loader code and reported those to Apple.
    In that respect we're in the same boat you are: we see problems, we gather data and report them, then wait.
    May 14, 2009 12:34 PM   in reply to DGJ193
    DGJ193 - that's why I quoted the important lines from each report I was responding to.
    May 15, 2009 1:01 AM   in reply to DGJ193
    Reinstalling, etc. won't fix the bugs. Apple has to fix the code.
    The only thing you can reasonably "fix" would be a third party plugin bug - but not using that third party plugin.
    The web sites thing was a wild guess, it's happened before but isn't likely to happen again.  I don't know what factors into Apple's bugs actually crashing versus not crashing.  Apple will have to tell us that when they find the bug in their code.
1 2 3 Previous Next
Actions
