snoedoc
Can't Save As PDF
Apr 22, 2009 5:34 AM
I am working with DITA files in Frame 8, and am unable to save a generated Frame file as a PDF. I keep getting these errors:
  • "To execute "Save as PDF" command you must have Acrobat Distiller version 5.05 or higher installed."
  • "To execute "Save as PDF" command you must have PDF Job Options defined.
I have Acrobat Distiller 8 installed, so I don't know why I'm getting the first error. I opened Distiller, and still got the error.
Also, I did try to set job options using Format > Document > PDF Setup. On the PDF Setup dialog box, the only job option in the PDF Job Options drop-down list was High Quality Print. When I clicked Set, I got a message stating that "The selected PDF Job Option does not existing in the current installation. Either create this Job Option or select an available Job Option."
How do you create a valid job option? How do you get it to show up in the drop-down list? I looked at the Adobe PDF properties in Print Setup, and the Default Settings show several job options including the High Quality Print option.
Any advice would be greatly appreciated.
    Apr 22, 2009 8:22 AM   in reply to snoedoc
    It sounds like FM is not seeing your Acrobat installation properly.
    Did you install Acrobat before or after FM? You might want to try running the "Repair Acrobat Installation" option in Acrobat under the Help menu.
    Did you by any chance also install the PDF Creation add-on that came with FM as well as having the Acrobat 8 installed? If so, these can not coexist and you have to uninstall the PDF Creation add-on.
    Apr 29, 2009 9:07 AM   in reply to Arnis Gubins
    Hi, Arnis,
    I work with snoedoc.  We have myriad problems and have decided to divide and conquer as far as our questions.
    How do we know if we have the PDF Creation Add on?  We have TechComm Suite 4.0 installed and I see that there is a folder called PDFMaker in the Acrobat 8 folder. Is that what you are referring to?
    Somehow, both Snoedoc and I have Acrobat 8 installed three different ways. The folders are named:
    Acrobat8
    Acrobat 8
    Acrobat 8.0
    Is this a normal installation? Could that be causing some of our problems?  Our tech support team installed the TechComm Suite and really struggled with it. I am noticing some differences between the contents of the different Acrobat folders.
    Also, we seem to be able to select joboptions, but then we get the message that it's not available. What causes that?
    Thanks.
    Apr 29, 2009 11:14 AM   in reply to cvgs
    It sounds like you may have gotten multiple installations of Acrobat components and that has hosed some of the pointers in the Registry that FM is relying upon. I had a similar issue at one point and found incorrect Registry entries pointing to C: drive locations when I had installed on D:.
    I'd say the best bet at this point is to uninstall Acrobat 8. Then do a thorough scan to wipe out any folders or Registry entries that pointed to Acrobat. You might want to run Adobe's CS3 clean script, which should get rid of the Acrobat 8 entries. See <http://www.adobe.com/support/contact/cs3clean.html> and I'd also recommend running Microsoft's Windows Installer Cleanup utility at <http://support.microsoft.com/kb/290301>
    There also is an Adobe CS4 Clean utility, but this will look for Acrobat9.
    After the machines have been cleaned, then re-install Acrobat 8 from the TechCommSuite DVD and get make sure that you download all of the patches (auto-update should flag these anyway for you).
    Apr 30, 2009 4:36 AM   in reply to Arnis Gubins
    Arnis,
    I only wish things were that simple.  We do not have the TechComm DVD.  Our technical support did the install for us and I believe it was a download. No one ever got the DVD. We have had a lot of turnover in that department and all information re: the TechComm install cannot be found.  In fact, we have one team member who had to get a new laptop and can't load the TechComm Suite because no one knows anything about it.  If you have any idea who  at Adobe could help us, that would be wonderful.
    Apr 30, 2009 10:18 AM   in reply to cvgs
    You can also re-install from the download (provided your IT people kept it around).
    However, if you don't have your license info available, then you need to contact Adobe Customer Service. There's a Knowledgebase article on what you can do if you've lost the serial number: http://www.adobe.com/go/tn_15292
    As far as getting the TCS, you can either download the whole thing again (I hope you have a fast connection) or order a trial disk from the trial downloads page.
    Apr 30, 2009 1:10 PM   in reply to Arnis Gubins
    Arnis,
    Thanks for the advice and suggestions.  I have contacted Adobe about our license issue and hope to hear back from them in the next few days.  We'll let you know how everything turns out.
    May 5, 2009 5:16 AM   in reply to cvgs
    Arnis,
    Thank you many times over for your wonderful suggestions.  We have been able to get our licensing issues worked out and will be uninstalling and installing Acrobat 8 using the suggestions that you made in one of your earlier posts. We'll let you know the outcome.
    You're a treasure.  Keep up the good work.
    Mary
    May 5, 2009 9:51 AM   in reply to cvgs
    Mary,
    Glad to hear that it's working out for you. Hopefully, a new clean install will vanquish any gremlins.
    Jul 15, 2009 9:51 AM   in reply to Arnis Gubins
    Please excuse me if I am not doing this properly. I have never posted to a forum discussion. We are a small publishing firm that uses Frame 8 for the composition of a 1400 page directory. We are unable to properly save files to PDF format. I am trying to research fixes for this to help Kim who is the one that actually works in Frame. When she trys to create her pdf portions of the page disappear. The files are manageable in size (each state is saved as its own file). She is currently uninstalling CS3 as well as Framemaker and then plans to reinstall just Framemaker with the patches she has found for 8.0.
    Would you be able to help with this at all? If it could prove helpful I am sure she would join the discussion to better answer any questions you have.
    Peggy
    Jul 15, 2009 10:04 AM   in reply to pegnomis
    Sounds like a pretty desperate situation. Been there.
    There are a number of questions to ask.  First of all, you say that Kim is trying to save files to a PDF format.  You actually print files to a PDF format.  Select File > Print > and select Adobe PDF from the print options.  This opens up a window with several tabs of information for you to complete, such as bookmarks that you want to display, the print quality, links. etc. Then when you click Print, a postscript file is generated.  Double clicking the postscript file then generates the PDF.  Is this the process that you are following?
    Also, what is CS3?  If you actually mean the Tech Comm suite I would certainly encourage Kim to reinstall the entire package, since the components are all meant to work with each other.
    Also, you may want to consider creating a new discussion since it would probably get more responses than just replying to my discussion which is several weeks old. But feel free to continue using this avenue if you think it would be helpful.
    Jul 15, 2009 10:34 AM   in reply to cvgs
    I did create the new discussion after I sent this to you. Thanks. Yes,
    we re desperate. The directory must be on the printer's FTP by July 28th.
    We are not new at this - we have been using Frame since 2001. Last year
    with version 7 by saving each file two times (using the procedure you
    have outlined below - she would run the postscript file twice and then
    run the distiller once)  she was able to get the pdf to work. The
    upgrade to 8.0 was added to her computer before she began this year's
    composition. She tried using the same procedure as last year - but it is
    not working.
    She tried creating the PDF file in the way the you have outlined and
    also she tried using the Save As PDF function from the File drop down
    box.  Both give the same issues of missing information.
    We do not have Tech Comm. The CS3 I referred to is Adobe Creative Suite
    3 which includes Illustrator, In Design PhotoShop and Acrobat.
    As I said she is currently removing all of the CS3 and both version 7 &
    8 of Framemaker from her computer. She was then going to reinstall
    Framemaker 8.0 with all patches she has found.
    Do you have any other suggestions?
    Peggy
    Jul 15, 2009 10:53 AM   in reply to pegnomis
    Give me more specifics re: missing information.  What are the error messages.
    You shouldn't have to save a file twice, or run the postscript twice in order to get a PDF.  I wonder what is going on?
    Maybe once I see an example of the errors, I'll know more.
    Jul 15, 2009 11:16 AM   in reply to cvgs
    She does not get any actual "error " messages when creating the file. I
    am attaching the state of Alabama files so you can see.
    She does get font errors when opening all of her fm documents. The
    explanation of the error tells her that Frutiger Bold will be replaced
    with Frutiger heavy, etc... She has always just ignored this error -
    because the replacement font was fine. This is not a new error - it has
    happened in the past.
    Of course, she understands this may be an issue - but can't quite see it
    as the problem.
    Maybe by looking at the files you see her issues.
    Peggy
    Jul 15, 2009 11:26 AM   in reply to cvgs
    as the problem.
    Peggy
    Jul 15, 2009 11:42 AM   in reply to pegnomis
    Peggy,
    I didn't get any attachments, but I wonder if that's because attachments
    can only be sent to the Adobe folks who are constantly trolling the forums
    looking to assist users.
    Mary K. Greer
    Information Developer - Learning Management Solutions
    Intelligent Automation Solutions Client Services
    407.771.8187
    pegnomis <forums@adobe.com>
    07/15/2009 02:26 PM
    Please respond to
    clearspace-1046421661-20863-2-2109954@mail.forums.adobe.com
    To
    Mary Greer/CIMG/CVG@CVG
    cc
    Subject
    Re: Can't Save As PDF Can't Save As PDF
    as the problem.
    Peggy
    Jul 15, 2009 11:51 AM   in reply to cvgs
    If I upload them to my FTP can you get them there? I would have to give
    you the username & password which I would not want to post to the forum.
    Peggy
    Jul 15, 2009 11:58 AM   in reply to pegnomis
    Peggy,
    I'm afraid I can't give you my email here at work or I'll be inundated.  I
    also think it may be against the forum rules.  Arnis Gubins of Adobe is
    usually active in the forums, so perhaps he will be able to come to your
    rescue.  I wish I could help. Have you gotten any response to your other
    posting?  Did you post in two forums: FrameMaker and Adobe Acrobat?
    Are you working in regular FrameMaker or structured FrameMaker?  Please
    try to give me some of the warnings/errors.  You're generating from a book
    file, right?  Have you tried pdfing each chapter separately, then
    stitching them together in the pdf.  Not the best solution, but a
    solution.  Also, sometimes if you open all of the chapters in the book and
    pdf with them open, that solves the problem.
    Mary K. Greer
    407.771.8187
    07/15/2009 02:51 PM
    Please respond to
    clearspace-1046421661-20863-2-2110024@mail.forums.adobe.com
    To
    cc
    Subject
    Peggy
    Jul 15, 2009 12:06 PM   in reply to cvgs
    I posted in the Framemaker Structured  Forum. I have not received any
    further responses.
    We are using FrameMaker 8.0. I do not know what you mean by regular or
    structured. We actually create a separate file for each state of the
    directory. Each file is then made into a pdf file. The pdf files are
    then joined together for the printer. Whether using the File Save As or
    by using Select File - Print there are no errors received. It seems to
    work fine, but when you open the pdf file there is random information
    missing.... sometimes graphics, sometimes text.. not always the same if
    you delete and start over....
    Peggy
    Jul 15, 2009 12:23 PM   in reply to pegnomis
    Structured files means you are working with DITA and tagging your
    information. If you are working in Structured FrameMaker it will have
    Adobe FrameMaker (Structured) in the title bar of your FrameMaker doc.
    Attached is a screen shot of what structured FM looks like.  If you select
    View > Element  Boundaries as tags and don't see something similar to the
    attachment, you are working in regular FrameMaker.  If you are working in
    regular FrameMaker, then you might have better luck posting into that
    forum.
    Mary K. Greer
    407.771.8187
    07/15/2009 03:07 PM
    Please respond to
    clearspace-1046421661-20863-2-2110032@mail.forums.adobe.com
    To
    cc
    Subject
    further responses.
    Peggy
    Jul 15, 2009 12:34 PM   in reply to cvgs
    We are using regular Framemaker... I will try to find that forum and
    post there. Thanks so much for trying to help.
    Peggy
    Jul 15, 2009 12:38 PM   in reply to pegnomis
    I know what an anxious time you are having.  Good luck and let me know
    what kind of responses you get.
    Mary K. Greer
    407.771.8187
    07/15/2009 03:35 PM
    Please respond to
    clearspace-1046421661-20863-2-2110175@mail.forums.adobe.com
    To
    cc
    Subject
    Peggy
    Jul 15, 2009 3:06 PM   in reply to pegnomis
    Peggy,
    The error message when opening the .fm files about the Frutiger Heavy substitution for Frutiger Bold is FM's way of telling you that the actual font that you have on your system has a different weight than specified in the file and FM found the closest match. To get rid of this message, you need to make the substitution permanent by turning off the Remember Missing Font Names in the File > Preferences section and doing a Save/Open cycle to make the changes permanent. You can then reset the preference to what it was.
    Regarding the missing PDF content, you need to apply the MS hotfix mentioned here: http://blogs.adobe.com/techcomm/2008/07/hotfix_for_framemaker_1.html
    It's a system level problem that is being fixed. There's nothing at the FM or Acrobat level that you can do about it.
    Jul 16, 2009 5:52 AM   in reply to Arnis Gubins
    Thank you.
    Peggy
    Jul 16, 2009 5:54 PM   in reply to cvgs
    Structured files do not necessarily use DITA.
    FrameMaker's formatting capability is available with two different document models. In the original model, a flow is a sequence of paragraphs, each associated with a paragraph format. The paragraph format may but need not be stored in the paragraph catalog. There are various complications, including text ranges within the paragraph associated with a character format, tables graphics, and so forth, but still the flow is basicallhy a sequence of paragraphs.
    In the structured model, the document is a hierarchy of elements, each containing text or other elements, or corresponding to a FrameMaker formatting object such as a table, graphic, marker, or cross-reference. Typical elements include an entire document, a list, an individual list item, and an emphasized phrase within a paragraph. User-defined rules in the document assign formatting to elements based on their context. For example, the format rules might assign a paragraph format to the first item in a list that sets its autonumber to start counting at 1 while other items increment the counter. If the user inserts a new item at the start of the list, or rearranges existing items, the numbering automatically adjusts to reflect the new structure. Furthermore, it is easy to select, move, or delete entire elements, so operations such as reversing the order of adjacent sections don't require the usr to click on the start and then find and shift-click on the end of the structure.
    Structured documents also have rules for which elements are allowed where. These rules in effect can coach a user to enter components of  some types of material (such as complicated front matter) in the correct order. They can also prevent the user from incomplete constructs and from creating documents that violate organizational policy. For example, a list with a single item or a section with only one subsection can be reported as invalid.
    The structured document model is based on that of SGML and XML and hence it is much easier to move structured material back and forth between SGML or XML and FrameMaker than it is to move documents that use the original model.
    Jul 17, 2009 10:22 AM   in reply to Arnis Gubins
    Sorry for the double posting of the pdf issue - I am new to this.But -I
    just wanted to say THANK YOU for your help.. the font issues are cleared
    up and the pdf files are being created with no missing text...
    Peggy
    Jul 17, 2009 11:22 AM   in reply to pegnomis
    That is absolutely wonderful news.  Deadlines can be so stressful anyway,
    but to have issues related to the software makes it doubly so.  Now you
    can enjoy your weekend.
    Mary K. Greer
    407.771.8187
    07/17/2009 01:22 PM
    Please respond to
    clearspace-1800457585-20863-2-2115239@mail.forums.adobe.com
    To
    cc
    Subject
    Peggy
    Jan 28, 2011 8:48 AM   in reply to Arnis Gubins
    I followed your recommendation and used the below program link as a cleaner. It worked and my PDF save problem is gone. However, I am unable to reinstall Adobe Illustrator CS3 which was uninstalled while running the cleanup program. The problem seems to be that there are remnant files left in my Adobe progam files. Any suggestions?
    I was able to successfully reinstall Adobe Acrobat.
    http://<http://www.adobe.com/support/contact/cs3clean.html>
    Jan 28, 2011 9:09 AM   in reply to checkdot
    I'm glad that your original problem of not being able to save as a PDF is resolved. However, I'm not familiar with the cleaner that you used or the resulting problem. I am sure that one of the wonderful experts out there will respond with a resolution that doesn't have any further side effects.
Incoming Links
