monticus
Adobe Reader 9.1  Disable Display PDF in browser
Apr 23, 2009 2:40 PM
Is there a registry setting I tweek to uncheck the box for Display PDF In Browser?  The only ones I could find grayed out the box but it didn't un check the box.
    Jun 30, 2009 1:53 PM   in reply to monticus
    Unfortunately this is for every user.
    HKCU\Software\Adobe\Adobe Acrobat\9.0\Originals\bBrowserIntegration should be 0 (DWORD) for unchecked.  1 for checked, or just delete bBrowserIntegration.
    Although not test, but for new users, you can have it defaulted to unchecked by creating this registry key:
    HKLM\Software\Adobe\Adobe Acrobat\9.0\Installer\Migrate\_8F96F27E-4B57-411A-A268-632AF06C6929
    (Default)  REG_SZ  Software\Adobe\Adobe Acrobat\9.0\Originals
    name       REG_SZ  bBrowserIntegration
    type          REG_DWORD  4
    val            REG_SZ  0
    Feb 9, 2011 9:33 AM   in reply to monticus
    I'm just confirming what anhnguyen7902 posted.
    This was tested against Acrobat Reader 9.3.1. I exported all of the registry keys from HKEY_CURRENT_USER\Software\Adobe\ with the "Display PDF in browser" setting enabled and disabled. Below are the only relevant differences when changing this setting from within Acrobat Reader.
    With the setting enabled, keys under [HKEY_CURRENT_USER\Software\Adobe\Acrobat Reader\9.0\Originals] are...
    "bHostBasedCM"=dword:00000001
    "iPSLevel"=dword:00000000
    "sProofingSpace"=hex:55,2e,53,2e,20,57,65,62,20,43,6f,61,74,65,64,20,2 8,53,57,4f,50,29,20,76,32,00
    "bDisplayedSplash"=dword:00000001
    With this setting DISABLED, keys under [HKEY_CURRENT_USER\Software\Adobe\Acrobat Reader\9.0\Originals] are...
    "bBrowserIntegration"=dword:00000000
    The difference being the bBrowserIntegration key being present and set to dword:00000000 when this option is DISABLED, but the key being completely removed when the setting is ENABLED.
    While writing this post, I decided to test it against Acrobat Reader v4.2.1. The results were the same.
    Hope this helps.
