nlfuria
Expanded or collapsed layer status
Apr 25, 2009 5:02 PM
Every time that I open a file, almost all the layers in the first level appears expanded, even when the file was saved with these layers colapsed.
So, as I have a lot of layers and sublayers/groups, it is difficult to navigate to a specific location and I need to collapse layer by layer.
Are there some trick to force Illustrator to remember the layer status?
Furia
    Apr 26, 2009 11:22 AM   in reply to nlfuria
    There is no way to force it. Illustrator simply does not remember hte collapse state of layers. Lord knows, I wish it would.
    I've files 2 or 3 feature requests for this.... file yours too. The more Adobe gets the more likely it is to happen.
    http://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Aug 19, 2010 5:07 AM   in reply to [scott w]
    Here the same problem, I will also submit this, or is it fixed in CS5?
    Aug 19, 2010 1:54 PM   in reply to Raymarcher
    Same issue in CS 5 and many previous versions.
    To ease it you can put all your layers into one master layer. After saving and reopening your file, Alt/Option Click the triangle on the left hand side of the master layer item in order to collapse or expand all sublayers inside the master layer.
    Jan 16, 2014 12:22 AM   in reply to nlfuria
    This issue is fixed in 17.1 update released for Illustrator CC
    Satinder
    Illustrator Team
