Home/Support/
Forums
1372 Views 21 Replies Latest reply: May 5, 2009 4:28 AM by Philip Tory RSS
Philip Tory User 206 posts since
May 28, 2004
Apr 29, 2009 10:40 AM
RoboHelp RH8 Pods
In RH7, I could arrange the pods so that the Topic List appeared as a tab in the same pod as the topics when I opened them. This arrangement had the topic tabs along the top, and the Topic List tab was in amongst them. But I just don't seem to be able to do this in RH8.
(The idea is to maximise the area available for the Topic pane, while hiding the Topic List when I don't need to see it. One click brings it back into view. I really don't want the Topic List to have its own space on the screen, otherwise I'll need a screen 2 feet wide to be able to work properly. And no, I don't want to dock it...)
Can anyone manage to do this?
  • RoboWizard Community Professional 2,856 posts since
    Jan 30, 2004
    1. Apr 29, 2009 10:54 AM (in response to Philip Tory)
    Re: RoboHelp RH8 Pods
    Hey there
    It would help tremendously if you could post a screen capture of how it looked in 7.
    Use the Camera icon next to the smiley so it goes into the post and we see it immediately. Otherwise it gets queued and we have to wait.
    Cheers... Rick
    Jan 30, 2004
    3. Apr 29, 2009 11:32 AM (in response to Philip Tory)
    Hi again
    Do you use the Web interface to post and reply?
    If so, please take a look at this link and you will see what I'm referring to.
    If you are replying using E-Mail I'm not sure it would work.
    Cheers... Rick
    Jan 30, 2004
    5. Apr 29, 2009 11:51 AM (in response to Philip Tory)
    LOL
    I wasn't questioning why you wanted a particular layout. To each his/her own there.
    I was just curious to see what it was you were trying to duplicate in order to see if I could find a way in 8 to do it easily. But you found your answer and that's great!
    Cheers... Rick
  • Peter Grainge Community Professional 11,492 posts since
    Aug 31, 2004
    8. Apr 30, 2009 2:33 AM (in response to Philip Tory)
    Makes me wonder if you do have an installation problem as you suggested. However, I would doubt this would be the only problem you see.
    The standard-flyout environment that is on my site was created in RH7 and works in RH8 for me.
    Aug 31, 2004
    10. Apr 30, 2009 3:25 AM (in response to Philip Tory)
    I don't want to do that on a production machine.
    I have used the standard flyout from RH7 without issue and I have modified it in RH8. Both work without any problems in RH8. Given this is a problem that only you are seeing, I don't think it is a RH bug as at least some other users would be seeing it.
    Are you able to install the trial version on another machine and see if you still get this problem?
    Aug 31, 2004
    12. Apr 30, 2009 4:13 AM (in response to Philip Tory)
    Unless I am misunderstanding your question, that is how I got it there in the layouts on my site.
    Aug 31, 2004
    18. May 1, 2009 5:06 AM (in response to Philip Tory)
    Thanks for the update. Good to know that it is a known problem so that you don't waste time on it.
    Based on the tests I have just done, if you save any one of those three pods, on reopening the project, the environment is not loaded. If you then manually load it, no matter where you have saved that pod in the environment, on attempting to use it, RH crashes.
    I have no problem loading the Topic List into the Editor though. That still works as in RH7.
    Aug 31, 2004
    20. May 1, 2009 5:39 AM (in response to Philip Tory)
    Go to my site and email me the layout to which you want the Topic List added.
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
