Exporting to JPG:  Dimensions are Wrong
May 2, 2009 3:38 PM
When I create a new design using Adobe Illustrator, I typically set the artboard size to the desired size for the intended use of the design.
I have a printing process as one example that requires a specific JPG size which is:  1125 x 638    or   638 x 1125  (rotated)
When I export to a JPG file at CMYK, the resulting JPG file does not seem to be 1125 x 638, but something larger.
Then, I have to use Photoshop to re-size the file.
Is there a way to have Adobe Illustrator make the JPG file at the correct size in the first place?
I noticed a "Use Artboards" checkbox during the export process, but that didn't do the trick.
    May 2, 2009 6:42 PM   in reply to DDmUSA
    I do not see that problem except if I give it a bleed then it exports with the bleed area.
    The way to avoid this is set the bleed to zero, no need to ha ve the bleed if you are not using it.
    Don't know if this is causing your problem but it is the only way I was able to duplicate what you saw.
    Document set up turn the bleeds to zero.
    May 4, 2009 8:55 PM   in reply to DDmUSA
    Trash the settings folder the Adobe Illustrator CS4 Settings folder  in your User's Preferences
    I would say that would be the only problem I can imagine except if you have a stray point outside your artboard but I can say I do not know how that would effect it either.
    It has to be corrupt preferences.
    May 5, 2009 12:20 AM   in reply to DDmUSA
    Sorry for not replying sooner. First of all are you on a Mac or PC?
    May 5, 2009 12:56 AM   in reply to DDmUSA
    We are up late:
    Go to
    Users/Username(the name you gave your account)/Library/Preferences/Adobe Illustrator CS4 Settings folder, you trash that but first you quit Illustrator.
    By the way the folder in your applications folder is called Adobe Illustrator not Illustrator but in any event you never trash that folder.
    If for some reason you ever have to reinstall you use the uninstaller in the Utilities folder which is in your Applications folder.
    You did the right thing by making certain you were after the right files.
    May 5, 2009 8:19 AM   in reply to DDmUSA
    The pixel dimensions are the pixel dimensions there really is not such
    thing as 300 ppi at 638 x 1126 pixels. if you understand that then you
    will be fine.
    638x1126 pixels is the resolution of the file, come hell or high water.
    Now if you need the file to 300 ppi that means you bring the file into
    photoshop then in photoshops image size turn off resample and change
    the resolution to 300 ppi.
    You then have a file size as the attached I am sending this by e-mail
    and will attach the image  a little later.
    I'll try it by e-mail. Didn't work by e-mail had to do it with the camera icon.
    May 5, 2009 9:14 AM   in reply to DDmUSA
