When posting code in this forum, do NOT use "Insert Raw HTML". Use Syntax Highlighting > Plain instead, as shown here:
You can also paste code directly into your post. However, using Syntax Highlighting > Plain has the advantage of preserving code formatting like this:
<h1>User Login</h1>
<form id="form1" name="form1" method="POST" action="<?php echo $loginFormAction; ?>">
<p>
<label for="username">Username:</label>
<input type="text" name="username" id="username" />
</p>
<p>
<label for="pwd">Password:</label>
<input type="password" name="pwd" id="pwd" />
</p>
<p>
<input type="submit" name="doLogin" id="doLogin" value="Login" />
</p>
</form>
If you use "Insert Raw HTML", the forum interprets the tags as HTML, in effect hiding your code. This is the same code entered using "Insert Raw HTML":
North America
Asia Pacific
