I have a photo that I wanted to send off to have developed but I would like it to have the antique rectangle 2 frame around it. I can select that frame when I choose print multiple but can't save the file. Is there a way to easily re-create this frame with the tools in Adobe Elements 6.0 or do I have to print it, scan it and then send off somewhere to be printed?
Cheryl
You need to open the Editor, and then open the Artwork and Effects pallet. Find the Frames and you can put the antique on your photo. I don't have PSE 6 handy to tell you the exact steps... First, create a new document the size you want your print. Then choose the frame from the Artwork and Effects pallet. Size the frame to the size of your document. Then, double click in the middle of the frame and select your photo. Then do a File->Save As to save the file as a jpeg.
-Trish
In Elements 6.0, there is a palette called Effects and it has Filters, Layers and Photo effects. I also see a Content palette where you can select frames, but I don't see the Antique Rectangle 2 frame in this palette like the one I see when I can print the photo. You would think I could apply this same frame to my photo to save but I don't see it anywhere except when I go to print the photo. Didn't know if there was a simple way to re-create this frame to save.
North America
Asia Pacific
