Session variables are set, then immediately disappear. What now?
May 7, 2009 11:52 AM
Ok, this is strange. Maybe because I'm darn tire. But anyway...
I have a simple login script that checks stuff and then if successful logs them in via setting session variables into the session via a struct like so:
<cfset session.user = {} />
I then set all my other user specific stuff in this struct. That's straightforward...and when I dump session.user...it shows the data. However, if I refresh the page, this session variable disappears. If I simply dump "session" then I see the usual CFID and CFTOKEN stuff. So session is enabled and ready, but why then does it disappear?
I have done stuff like this before so I really can't see what's happening. The session timeout is also set to 30 minutes in the Application.cfc so that shouldn't be it.
My CFC code is below.
Many thanks,
Mikey.
<cffunction name="authenticateUser" returntype="void" output="true" access="public" displayname="authenticateUser">
        <cfargument name="userName" type="string" />
        <cfargument name="userPassword" type="string" />
        <cfargument name="userCaptcha" type="string" />
        <cfargument name="userCaptchaEncrypted" type="string" />
        <cfset var local = {} />
        <cfset local.fieldsValid = true />
        <cfif not len(trim(arguments.userName))>
            <cfset request.messagesObject.addMessage("info","User name is required.") />
            <cfset local.fieldsValid = false />
        </cfif>
        <cfif not len(trim(arguments.userPassword))>
            <cfset request.messagesObject.addMessage("info","Password is required.") />
        </cfif>
        <cfif not len(trim(arguments.userCaptcha))>
            <cfset request.messagesObject.addMessage("info","The security code is required.") />
        <cfelse>
            <cfif not trim(arguments.userCaptcha) eq decrypt(arguments.userCaptchaEncrypted,"iloveyou","CFMX_COMPAT","Hex" )>
                <cfset request.messagesObject.addMessage("error","The security code entered was incorrect.") />
            </cfif>
        </cfif>
        <cfif len(trim(arguments.userCaptcha)) neq 5>
            <cfset request.messagesObject.addMessage("info","The security code must be 5 characters in length.") />
        </cfif>
        <cfif not len(trim(arguments.userCaptchaEncrypted))>
            <cfset request.messagesObject.addMessage("error","The encrypted security code is required by the system but was not found.") />
        </cfif>
        <cfif local.fieldsValid>
            <!---<cftry>--->
                <cflock name="lockGetUser" type="exclusive" timeout="30">
                    <cfquery name="local.qryGetUser" datasource="#request.dsn#" username="#request.username#" password="#request.password#">
                    SELECT userID, userName, userPassword, userRole, userDeleted
                    FROM #request.tbl_users#
                    WHERE userName = <cfqueryparam cfsqltype="cf_sql_varchar" value="#trim(arguments.userName)#" />
                    AND userPassword = <cfqueryparam cfsqltype="cf_sql_varchar" value="#trim(arguments.userPassword)#" />
                    AND userDeleted = 0
                    </cfquery>
                </cflock>
                <cfif local.qryGetUser.recordcount eq 1>
                    <cflock scope="session" timeout="30" type="exclusive">
                        <cfset session.user.username = local.qryGetUser.userName />
                        <cfset session.user.role = local.qryGetUser.userRole />
                        <cfset session.user.id = local.qryGetUser.userID />
                        <cfdump var="#session.user#" />
                    </cflock>
                    <cfset request.messagesObject.addMessage("ok","Welcome " & htmlEditFormat(local.qryGetUser.userName) & ". You have been logged in.") />
                <cfelse>
                    <cfset request.messagesObject.addMessage("error","Invalid user name / password combination.") />
                </cfif>
                <!---<cfcatch type="any">
                    <cfset request.messagesObject.addMessage("error","authenticateUser() " & cfcatch) />
                </cfcatch>
            </cftry>--->
        </cfif>
    </cffunction>
    May 7, 2009 12:23 PM   in reply to Kapitaine
    That's dicey! I expected the done thing, namely, <cfset session.user = "">. Could you show us the code in Application.cfc? That's where the engine usually needs oiling.
