Japoliveira
Java Script Error Number 45 Line 428
May 12, 2009 2:46 AM
Hi!
I need help for my Indesign CS4, on start Indesign CS4 is this error: "Java Script Error! Error Number:45 Error String Object is invalid File: /Scripts/XHTML For Digital Editions/Startup Scripts/OEBExportMenuItemLoader.jsx  Line 428  Interpreter: CS3 (5.0)"
thanks
    May 12, 2009 4:57 AM   in reply to Japoliveira
    hi
    I think "XHTML For Digital Editions" is for ID CS3 only - probably it can't work with ID CS4 ...
    you need to uninstall this software - XHTML For Digital Editions - or manually delete this catalog - but ONLY "XHTML For Digital Editions" catalog from "Scripts" catalog
    or you can go to this file "OEBExportMenuItemLoader.jsx" and check line 428 ...
    robin
    www.adobescripts.co.uk
    May 12, 2009 5:07 AM   in reply to AdobeScripts
    Try to temporarily remove OEBExportMenuItemLoader.jsx file from Startup Scripts folder and restart ID. See if the problem has gone.
    May 12, 2009 11:17 AM   in reply to Kasyan Servetsky
    Hi José,
    Is it possible that your script preferences have been changed to use an earlier version of the scripting object model? If that's the case, then the following one-line script:
    app.scriptPreferences.version = 6.0;
    ...might fix the problem.
    Ole
