picarcyr
Unable to create PDF/A from InDesign
May 12, 2009 8:35 AM
Hello,
I'm trying to create PDF/A document from InDesign CS4 with Adobe Acrobat 9.
I create my PDF from InDesign (I create a tagged PDF).
For each document create from InDesign, I receive this message from the Preeflight "Convert to PDF/A (sRGB)" of Acrobat.
PDF document is not compliant with PDF/A-1a (2005)
- Structured PDF : Type entry in a structure element not "StructElem"
- Structured PDF : Type entry missing
Thank for your help.
Cyril.
    May 12, 2009 8:38 PM   in reply to picarcyr
    You say 'I'm trying to create PDF/A document from InDesign CS4 with Adobe Acrobat 9.'  This might be your problem, you need to export from Indesign, File>Export then choose PDF from the file type and it brings up a PDF dialogue box in which you can change a lot of settings.
    May 13, 2009 12:35 AM   in reply to picarcyr
    Doh!  And I thought I was reading your post carefully...  Just a
    suggestion, you've obviously tries all the other types of PDF that you can
    export to see if that makes a difference?  PDF X etc
    May 13, 2009 3:38 AM   in reply to picarcyr
    Also, seeing you're doing it in Acrobat try the Acrobat forum.
    May 13, 2009 4:25 AM   in reply to picarcyr
    picarcyr wrote:
    Hello Steve,
    Thank for your reply, but it's not possible to create PDF/A-1a directly from InDesign.
    You need to create your PDF from InDesign and after to transforme your PDF to PDF/A-1a from Acrobat.
    Cyril
    You've answered your own question.
    May 13, 2009 5:58 AM   in reply to picarcyr
    I have not created PDF/A files. Are you saying Acrobat's preflight conversion is not working?
    OK I see that's exactly what you are saying. I'd suggest you move this to the Acrobat forum.
    May 13, 2009 6:48 AM   in reply to picarcyr
    I've come across something else. You may be able to PRINT to PDF\A rather than export. In the print dialog click the setup button, then go to the PDF Printer preferences and choose the standard from the default settings dropdown.
    Peter
    May 13, 2009 7:42 AM   in reply to picarcyr
    Cyril,
    I've exhaausted everything I can think of. You REALLY need to move to the Acrobat forum to get more help from the Acrobat gurus.
