Why did images disappear from text boxes?
May 14, 2009 8:02 AM
I'm finishing up on a project in RH6 after a 6 month layoff, so I'm a bit rusty! However, I just discovered that the images that I added to text boxes no longer show up when topics are generated or printed-out (they do show in the project manager view). Any clues out there? Thanks.
  • RoboColum(n)
    Oct 8, 2004
    May 14, 2009 8:25 AM   in reply to RightOar
    I want to ask why you have images in text boxes but maybe I won't .
    Perhaps instead you can elaborate on what you are seeing. Is there a placeholder for the image but no image or is there nothing at all inside the text box. Also is this only happening in the generated output (I'm assuming from your words this is webhelp?) in which case I'm wondering if this is a browser issue.
    Read the RoboColum(n) for mutterings on RoboHelp, Technical Communication Suite and technical communication.
    May 20, 2009 5:59 AM   in reply to RightOar
    Hi there
    Thanks for sharing. Looks interesting.
    However, I might suggest the following amendment to your instructions:
    RightOar wrote:
    In case anyone is interested in adding a little "spice" to their text boxes, I did figure-out (remember) how to imbed images into text boxes.
    • 1) Create an image and save as jpg. in your project folder (I'm thinking the image type makes no difference)
    • 2) Insert text box into desired topic(s)
    • 3) Right-click text box and select "text box properties"
    • 4) Under "Shading" tab, select color and then insert desired image under the "Pattern" section
    • 5) Under the "Repeat" section, select "No-Repeat" and keep the "Scroll box" checked-on
    In this way, the image is imbedded as a pattern rather than an image.
    Cheers... Rick
