AndyNils
Inability to use eps graphics in Word 2007 and make a pdf
May 29, 2009 9:03 AM
Hi there …
I work at a small "intellectual capital" company where virtually all of our documents (our products!) depend on embedding eps "pictures" into Word and pdf'ing the result.  While this process works great in Word 2003, it fails miserably in Word 2007 - the "mechanics" work fine and a pdf is produced, but the rendering of the eps images are terrible.  I spent some effort looking into this issue trying to find a solution and came up with the following (thanks in part to this post) ... if anyone has any more details, corrections, or solutions feel free to post!
It appears that, over the years, there have been three flavors of eps import filters for Word ... (for the curious the filter is found in Program Files\Common Files\Microsoft Shared\Grphflt\EPSIMP32.FLT )
  1. The simplest (and oldest) filter basically embeds the eps code unmodified into the Word doc and will display a raster preview of the image if one is included in the eps file.  if the file is printed on a postscript printer or to Acrobat, the eps code is passed through (so it produces perfect pdfs, and the screen image in Word looks as good as the preview image embedded in the eps file). if the file is printed to a generic printer, no image appears (so it doesn't work for joe user).
  2. The Word 2003-era filter pastes the eps code unmodified into the Word doc, then renders a (very poor) preview image (using an OEM'd eps converter).  if a preview image is in the eps file it is ignored (which is bad).  if the file is printed on a postscript printer or to Acrobat, the unmodified eps code is passed through (so it produces perfect pdfs, though the screen image in Word looks yucky). if the file is printed to a generic printer, the poorly rendered preview image is printed (so it works poorly but better than nothing for joe user - and probably gives joe user a bad impression of eps).
  3. In what might be an attempt to improve things for joe user, the Word 2007 filter immediately interprets the eps code (using a slightly updated eps converter from the same OEM) and pastes the resulting rendered image into Word. It NO LONGER embeds the unmodified eps code in the Word doc. While the rendered image looks better than filter #2, it still leaves A LOT to be desired - in my brief testing, colors are VERY wrong and curves become choppy. if the file is printed on a postscript printer or to Acrobat, the poorly rendered image is used since the original eps code is gone (unacceptable for my purposes). if the file is printed to a generic printer, the poorly rendered image is printed (so it works better than Word 2003 for joe user).
So where does this leave anyone that wants to upgrade to Word 2007, use eps images, and make quality pdfs ??
  • Filters #1 & #2 were interchangeable in Word 2003.  The true eps experts like #1 the best, and it is by far the simplest technically (76k of code vs 400+k), so they merrily swapped and used it with Word 2003.  (Very) unfortunately filters #1 and #2 do not work with Word 2007 - if they did the problem would be nicely solved.
  • Find another graphics file format to work with?  This is undesirable because the "beauty" of #1 & #2 above is the unmodified eps code gets fed to the pdf maker (which itself is native eps) - Word is just a transport (no "transcoding" loss in compression-speak).  if there were an efficient way to convert eps to say wmf (microsoft's proprietary vector graphic format), and the images were able to survive two transcodes (from eps to wmf back to eps for pdf), it might be livable. But of course Adobe Illustrator cannot save as wmv (nor should it IMHO).  Of note - there is another industry standard vector format - svg - which AI can save as but Word does not support.
  • Stay in Word 2003 doc format while using Word 2007 (don't use docx).  Doesn't work. My testing shows a Word 2003 doc file with embedded eps created in Word 2003 (and pdf's correctly in Word 2003) does not pdf correctly in Word 2007.
  • Use a work-around. As suggested here, "Open the EPS in Illustrator. Select all, and Edit > Copy. In Word, Edit > Paste Special > Enhanced Metafile."  This seems to work for small images such as logos, but not for larger graphical stuff (probably because of the internal transcoding to WMF).
  • Stay with Word 2003.  This appears to be the only workable option for now IF you want to use Word and render eps pictures in pdf's with acceptable quality.
IMHO the best solution would be to have the very simple 76k filter #1 ported to Word 2007 (those who need the capability can swap the filter files) or (not as optimal but does not require swapping filter files) add the option in filter #3 to still embed the eps code.  Microsoft is the right place to do it, or (politics aside), Adobe could and should do it (given some support from MSFT).
I am surprised this issue has not caused more rumblings from users - perhaps it has, the symptoms are just worded differently.  Or maybe everyone is just staying with Word 2003 (which is what I have done until now).  The problem is most companies are being forced to upgrade now, so I think this will become a bigger issue for Adobe / Microsoft going forward.
Thanks for listening.  I look forward to your comments.
Andy
    May 30, 2009 8:33 PM   in reply to AndyNils
    I don't know if it will work any better (Acrobat does what I need) but you might try the Microsoft plugin for Office 2007
    http://www.microsoft.com/downloads/details.aspx?FamilyId=4D951911-3E7E -4AE6-B059-A2E79ED87041&displaylang=en
    May 29, 2009 12:32 PM   in reply to AndyNils
    Could you post an example of the graphic (the EPS file)?
    May 30, 2009 5:19 AM   in reply to AndyNils
    Not that many people use .eps anymore (old format). For use in the Office Suite try to use PNGs. They seem to be supported much better than eps ever has been in Office products.
    May 31, 2009 4:50 AM   in reply to AndyNils
    How about the PS and PDF files? You have not posted them yet.
    May 31, 2009 7:53 AM   in reply to AndyNils
    Not in MSFT Word -- eps is a useless format for a Word processor -- It also is a very old format not used very much now days.
    May 31, 2009 2:28 PM   in reply to S.D.A.
    It may not be that great for WORD, but it is not obsolete in terms of having little use (no I don't use them). A lot of folks still do EPS graphics when doing LaTeX documents. Many publishers also want graphics submitted in EPS form. There may be better formats today, but can we try to help him with his issue. Changing to a different graphics format would be one alternative, but there are still issues of what the problems are with the EPS conversion. EPS and PS are the basic formats used by Distiller in transferring files to PDF. So, every time you create a PDF with Acrobat, you are basically going through the PS process to get to the PDF.
    May 31, 2009 10:22 PM   in reply to AndyNils
    As I suggested before try to use PNG yes raster images when importing to MSFT Word. It doesn't play nicely with .eps format files. Trust me I've been doing this for sometime. Also Word isn't a colour managed application and Acrobat is; so it's quite possible for the image to look different in Acrobat if it's been tagged other than sRGB.
    And in terms of using eps did you think I just made up the fact that it's an old format ?! For reference please the following; citation: Please note the words of a rathe famous Adobe engineer around these parts.
    The future of the EPS file format
    EPS is rapidly becoming an outdated file format which is being replaced by PDF just like PostScript itself is also being phased out and replaced by PDF. Don’t just take my word on this. Here is what Dov Isaacs from Adobe said in a discussion on a PrintPlanet forum about the future of PostScript: “ …Adobe will continue to support EPS as a legacy graphics format for import of non-color managed, opaque graphical data into Adobe applications (such as InDesign and Illustrator). Although we certain do not recommend that new graphical content be stored in EPS format (except to satisfy the need to import data into page layout programs that aren’t quite PDF-centric — no need to mention names here!), our user base should feel comfortable that there is no need to worry about a need to convert their very sizable libraries of EPS-based graphic assets.”
    Jun 2, 2009 12:01 AM   in reply to AndyNils
    OH! this is a different aspect. I have found WORD 2007 do some strange things to graphics. In fact it has replaced the text in a vector graphic with outlines, deleting the text as such. OFFICE 2007 seems to be doing some manipulation to graphics and does NOT retain the original form. It sounds exactly like the problem you are having. Another test would be to use the WORD 2007 plugin to create a PDF directly (MS download). If that does it correctly, then it may be the way that OFFICE is handing the results off to Acrobat. I did some experiment with that and had mixed results. In some cases, graphics (bitmaps in this case) would be split into parts and not be embedded as a regular graphic. It was definitely an OFFICE 2007 issue (PPT in the test case). If you work from the basis that OFFICE is the part that is screwing things up, you are likely on the right track.
    I am not sure if the OFFICE issue is one that MS did not purpose or not. Anyway, I get mixed results and if I play around a bit, I can often get good results. This does not help a lot, but may lead you toward a reliable solution. Try both the Adobe PDF printer and PDF Maker (though one is a preprocessor for the other, there seems to be some difference).
    Jun 30, 2009 2:27 PM   in reply to Bill@VT
    Ahhhh, sorry to resurect a post that has been dormant for a month, but these are the exact issues I've been trying desparately to figure out and the fine Microsoft forums I've been using don't give NEARLY as detailed and technical answers as these!
    So after figuring out that PDF as an importable format only seemed to be working in Word 2008 Mac (and our client needs Word PC), I went back to trying EPS again. On a previous project, we had gotten around this by creating EPS files with WMV previews from a trial version of Corel Draw on our token PC. But that trial ran out, and we're not about to purchase that software JUST to convert graphics for Word. And it wasn't a perfect solution anyways.
    For this project the end result will need to be PDFs that anyone can download from a website and print on any number of different printers (most likely NOT postscript). So we want the graphics to look good, but they can't be postscript data.
    In my testing here, the EPS files that were imported into Word 2008 on Mac look/print/export to PDF perfectly. But then again, so do PDF files. But when these files are opened in Word 2007 on our PC, the graphics are now bitmapped. So they print and export to PDF OK, but nowhere near as nice and crisp as if they were still vector.
    So then I tried replacing the picture in Word 2007 with the original EPS file. But when we print it to our high-end postscript printer, it has a thin hairline around it. And when we made the PDF, a tiny bit of the bottom is getting cutoff! So I put an empty box around the graphic in Illustrator and resaved the EPS (I use CS2 as format, with TIFF preview - no fonts). But the hairline is still there.
    Next, I tried saving the Word document for 2003 and opening in Word 2003. I placed the same EPS here, and now it seems to print OK (without hairline). Unfortunately, I don't have Acrobat Pro on this machine, so I can't export a PDF from 2003.
    Lastly, I opened this file saved from Word 2003 (with the EPS placed in 2003) into Word 2007. The file appears to print OK. And when I use the 'Save to PDF' plugin for Word 2007, the PDF looks fine and the graphic is still vector.
    - So wondering if I should place graphics in Word 2003; then open in Word 2007 to finish any layout issues; then save to PDF from Word 2007 (using the plugin instead of Distiller)?
    - Or is there a way (or should I try) to get the EPS import filter from Word 2003 and put it into Word 2007 to save me a step or two?
    THANKS!
    * On a side note, I did try the 'convert everything to a PNG file' method so strongly recommended on the last project. I was going to give up on vector and just make a hi-res PNG instead. But even though the PNG files were pretty small (maybe 150k-250k), once I imported them into my Word doc it ballooned up to 5MB+ file size! I know the client won't want to manage 100's of files of that size. And having the graphic be linked instead of embedded is even more dangerous if it's a large corporation with many departments. Way too easy to 'misplace'.
    Jun 30, 2009 7:36 PM   in reply to AndyNils
    Well here's what I tried and the results I got:
    1) Opened file in Word 2003 on PC
    2) Replaced graphics with same EPS files
    3) Saved and opened in Word 2007 on PC
    4) Used filter to save as PDF (Publish a copy of the document as a PDF or XPS file).
    5) Opened in Acrobat Reader on PC & Acrobat Pro on Mac. File looks fine on screen and prints perfectly to our Doc 12 (postscript) and Brother ('emulated' postscript) printers. Also preflighted in Acrobat Pro to make sure graphics were still vector - they were.
    So those are my results using a trial of Word 2007 on a PC running XP and no Acrobat Pro (or Distiller), only Acrobat Reader.
    And files print perfectly from Word 2007 or Acrobat to both of our printers (postscript and 'emulated' postscript).
    Now the only issue is that the graphics are all messed up when I open the Word files in Word 2008 on Mac. It's like there is a small preview image on top of a larger preview image. Oh well, can't win them all when dealing with Microsoft products...
    My only concern now may be whether our tests are skewed because we have a decent and proper postscript printer driver installed on this PC. Not sure if that is used in any way when using the 'Save as PDF' filter from within Word 2007. We'll have to have our client try it on their end and hope for the best.
    Jun 30, 2009 7:37 PM   in reply to AndyNils
    I think that some of this may have to do with the format that MS has used for docx files. I still need to look at the one that has been posted in PDF, but you might try saving the file as a DOC file first and then importing the EPS file. OFFICE 2007 seems to do some strange processing the the "x" versions of graphics. I have also found a difference when using the create PDF versus printing to the Adobe PDF printer as I remember. I have tried AA8 and AA7 both with WORD 2007 and found problems. When using AA7 with WORD 2003, the results were fine. As I said in a post to another topic, it almost appears as though MS put a hook in OFFICE 2007 for Acrobat - but we are supposed to assume that companies play fair.
    Nov 1, 2009 5:27 PM   in reply to AndyNils
    I faced this EPS import problem in Word 2007 last week. Sometime ago I had a problem with the import filter (EPSIMP32.FLT) in Word 2000 because the installation of Microsoft Visio replaced the original version with a "broken" one, so the first thing I tried was replacing the filter. It didn't work, so I searched for any clues on the internet and find none on this specific issue, but found that I should have not only replaced the file, but also updated the registry with the version of old EPSIMP32.FLT (mine is 98.5.14.0 from Office 2000)
    Everything works now, right? Wrong! When using docx, the stupid thing just ignores the filter and converts itself the EPS into some trash! To be able to use the filter, you must save the file in compatibily mode (save as "Word 97-2003 Document") and then insert the EPS. If you save it again in docx, the EPS will be lost.
    Summarizing:
    • Replace the EPS import filter (EPSIMP32.FLT).
    • Update the registry (right now I don't have the key, so just search for EPSIMP32.FLT and update the version).
    • Test it:
      • create a new Word document,
      • save it as "Word 97-2003 Document",
      • insert an EPS,
      • print to PDF (the internal converter does not work).
    If someone needs more information (such as the specific registry key), I can provide later.
    So am I! EMF just sucks and the EPS filter in Word 2007 is a bad joke. PNG is not a great option, since it's a bitmap and resolution specific. If Word supported PDF, that would be perfect, as EPS files are easily converted into PDFs.
    Mar 7, 2010 5:11 PM   in reply to Bill@VT
    I just noticed this problem existed with a bunch of my Word 2007 files and this thread is the only thing I could find on the issue.
    As others have pointed out, I think it's the docx format that causes the problem in Word 2007.
    To fix my problem I had to do the following:
    1. Save the file as a doc file
    2. Delete the eps graphic
    3. Reinsert the eps graphic
    4. Create the PDF
    I can also save the resulting doc file as docx and the eps file still works. If I want to add more eps files or change/update any I'd have to repeat the process above.
    I didn't have to do anything with filters.
    Mar 8, 2010 7:11 AM   in reply to AndyNils
    Microsoft has released a hot fix that supposedly addresses this issue, it is at
    http://support.microsoft.com/kb/977468
    I downloaded the fix and tried it; it actually made the problem worse!  Apparently they
    are trying to fix their filter rather than bypassing it.  What I am doing is
    1.  Making maps in AutoCaD Map and printing (plotting in autocad) them to a pdf file
    2.  Opening the pdf file in Acrobat and resaving it as eps
    3.  Importing the eps file into a Word 2007 document
    4.  Use Acrobat to convert the Word document to pdf
    Before the hot fix when I did the process the resolution of the map in the final
    pdf file was not as good as in the original made from AutoCad.  Also the colors were
    not correct.  After installing the hotfix there are still these same problems but also now
    any non horizontal text is not displaying correctly.
    Be careful about trying this hotfix.
    As others have noted, back in Word 2003 the above steps 1 - 4 worked very well and resulted
    in a high quality pdf file with the map as good as in the original pdf.
    Mar 18, 2010 4:27 PM   in reply to AndyNils
    I ran into this problem after "upgrading" to Word 2007. It's utterly ridiculous. If the "EPS is outdated" attitude is the excuse for it, then MS needs to allow PDFs to be inserted to Word docs.
    May 12, 2010 11:15 AM   in reply to gprobst
    I agree that EPS will be around for a long time. Being able to import vector based artwork is essential. Vector art is a good way to keep file sizes smaller, and quality at it's best—provided it works. The problem with WMF and EMF files is that they have never been able to handle curves well. WMF files generally make curves by using a lot of tiny segmented lines. If you download any of Microsoft's vector based clipart you can see the evidence of this everywhere. Bring one of those images into Corel Draw or Illustrator to modify it and you won't find a curve. Gradient colour is also converted, I believe, by stacking thin lines. In Word 2007, when I have produced EPS files that had gradient colour, they often displayed with "white pin-stripes" because some of the lines would disappear.
    I get terrible results in Word, PowerPoint and Excel. However, I don't have any issues with Visio. I'm not sure why.
    Why would Microsoft take a superior file format and make it reproduce in a substandard format?
    May 18, 2010 7:57 AM   in reply to AndyNils
    For some reason, the import eps feature stopped working
    for me in Word 2003 a few months ago.  Has anyone experienced this problem?  Any suggestions?
    I am having to convert the eps files to png using ghostscript, but this is a hassle in terms of file size, etc.
    BTW, thanks to earlier contributors to this thread.  It is very informative.  I have been struggling with Word and eps for years.  Things were working decently for me with Word 2003, until something changed.
    May 18, 2010 8:05 AM   in reply to grtoro
    Try saving your eps files as version 8 illustrator. I found I had a lot of luck that way in Office 2003.
    May 18, 2010 12:59 PM   in reply to Sono Birba
    Since this problem keeps coming up, I decided to test it with WORD 2007, VISIO 2007, and AA8 on VISTA. I created a vector file in VISIO and printed to the Adobe PDF printer (with print-to-file selected) to get a junk.eps file. I then imported the file into WORD 2007 (it actually displayed -- I am not sure that the print added a display graphic to the EPS file), and printed to the Adobe PDF printer. Everything went fine. (I may have actually used PDF Maker, but it worked fine in any case.)
    Jun 23, 2010 4:44 PM   in reply to AndyNils
    Jun 25, 2010 10:58 AM   in reply to pkhoan
    It didn't work for me. I could only find a way to link by "insert object". I get a black box on the screen. And it's not the correct dimension.
    Jul 4, 2010 3:51 PM   in reply to AndyNils
    Thanks to the original poster for getting this discussion started and for the helpful details.
    I have found that Word 2010 actually returns to the behavior of passing-through the raw .eps when printing, which is the Word 2003 behavior described by AndyNils. So the displayed images look poor but the printed PDFs look great. So I guess this is the best "workaround". Hooray!
    However, when I have .png in Word 2010 and print them to Acrobat 9 or Acrobat 6 (tried them both), the images get cut up into smaller images and inserted in the PDF. This results in huge files (a 400kb .png causes the PDF to grow by 7mb). More importantly, the text flow is destroyed and everything is columned (and so some text looks broken too). Has anyone seen this problem before?
    Here is an example http://www.filefront.com/16951807/example.zip I hope that someone can try it and tell me if this happens to them as well.
    (sorry for hi-jacking this thread)
    Jul 4, 2010 5:43 PM   in reply to Wa-Haa
    Interesting. The OFFICE 2007 equation editor does not work in doc mode, only docx. Maybe a similar fix for the compatibility mode by bringing the equation editor from OFFICE 2003. Might try it. I am awful tempted to remove OFFICE 2007 and install OFFICE 2003 from my other machine.
    Jul 8, 2010 9:35 AM   in reply to AndyNils
    I found the Adobe PDF printer produced the pdf with the .eps files included, but after closing and reopening the document neither the convert to pdf or the pdf printer worked.
    Jul 9, 2010 1:55 AM   in reply to basares
    My bad. Aparantly saved to a different file than the one I was checking for changes. Word trouble late at night is not easy to deal with, I go into hate mode easily and don't know what I'm doing....
    But anyways. The Pdf printer seem to produce nice looking vector figures, but the "convert to pdf" on the acrobat ribbon or the "word-save as" don't.
    Jul 9, 2010 4:34 AM   in reply to urinal-fS6nU9
    Urinal,
    I'm guessing the png has some sort of transparency in it. This is how it converts to pdf, not much you can do about that during conversion.
    However if you have acrobat Pro, go to advanced>pdfoptimizer
    Select the 'Discard Objects' option and make sure there's a tick for 'Detect and merge image fragments'
    Set any other options as you require and save the optimized pdf.
    Jul 10, 2010 1:57 AM   in reply to SimonATS
    Hi SimonATS, thanks for the reply. This isn't a transparency problem because I've used non-transparent png, jpeg (which doesn't support transparency), and even bmp. You can see in my example files that the image is not a transparent png. Also, the image fragmentation would not explain the text fragmentation that's occurring.
    Oct 3, 2010 2:17 AM   in reply to urinal-fS6nU9
    No one seems to notice that the main issue here is Windows..  I am currently preparing logo files for a client in order for her to manage her own business materials, and in reading this thread I have to say I feel rather frustrated that .eps files are presented as the 'issue' when I feel they are remarkable - small, elegant, accurately scalable - and it is, seemingly endlessly Windows softwares that are causing the problems....and that are sadly so ubiquitous.
    I have no idea how to provide my client with a small, scalable logo that she can use and print from her home office.
    Is there honestly no solution??
    Oct 3, 2010 1:25 PM   in reply to Constansea
    Only a suggestion of a workaround. Try to edit the eps file in a vector graphics package and save as a EMF file. I assume it should not be much larger, if any. EMF is capable of storing vector graphcs. I would suggest trying SVG graphics, but SVG does not seem to have taken off as well as was expected. I am assuming the logo is simple and it is not better in a bitmap format, with the associated scaling issues. If it had a fancy picture as part of the logo, it may be better to use a bitmap and not a vector format.
    Jan 26, 2011 8:58 PM   in reply to AndyNils
    After much testing, I have found one way for Microsoft Office 2007 applications to handle EPS files reliably, and it is so easy I can't believe I didn't think of this sooner. Microsoft Office 2007 apps can convert EPS graphics accurately to PDF files. If you're a frequent user of Word, Excel, Access or PowerPoint 2007 like me, and you need to to create PDF files vector-based content from Microsoft Office 2007 on a regular basis, you'll appreciate this easy work-around for working with EPS files in MS Office 2007.
    Unlike Microsoft Office 2003, the traditional methods of handling EPS files in MS Office 2007 apps using the "Insert" or "Paste Special" commands to handle EPS files in Word 2007 can cause EPS filesl to discard vector, font and/or color data. PDF files generated with EPS files using these insertion methods will result in poorly redefined and truncated EPS content that differs vastly from the original vector file.
    Here is the 2-step work around I discovered after hours of methodical, albeit failed, work-around testing:
    1) Browse for your EPS file in your file directory and copy it to the clipboard. Do not copy it from within your vector art application.
    2) In Word 2007, set your cursor to the desired insertion point and paste the EPS file into the Word document.
    Using this method, I was able to resize and crop EPS files right in the MS Office 2007 applications, including Word 2007. My PDF files generated from Word 2007 are perfect. I tried both transparent and opaque EPS files and they both performed equally well.
    Jan 27, 2011 10:39 AM   in reply to pgrahamiv
    Thanks, but it didn't work for me. My gradients still break apart and are "pinstriped" and my curves are not smooth.
    Jan 27, 2011 5:29 PM   in reply to pgrahamiv
    Correction. It prints well, but the electronic display is awful. So, it's a partial solution in terms of the tests I've just tried.
    Jan 28, 2011 12:27 AM   in reply to pgrahamiv
    It didn't work for me either.
    My files are exported Matlab figures. I had to open them in Acrobat, export to eps before I inserted them in Word. Seems the problem is that I used Arial MT and Symbol as font in my figures. When I export from Matlab it these fonts are not embeded so when I open the file in Acrobat they are replaced with Helvetica (but still with a Arial label) for the normal letters and some shape function for the greek. When I then export the file and reopen it in Acrobat Arial MT is embedded and the file can be imported in Word and produce a nice, zoomable pdf export.
