bigbrook
Using Google Analytics in large robohelp project
Jun 1, 2009 12:28 PM
I want to use google analytics to track a large training and help website. Actually seperate sites but same material. Training just has a browse sequence turned on.
When I insert google analytics code via template to all pages, as suggested here, I get google reporting on the skin pages rather then the real pages, except for the initial welcome page.
What can I do to get google analytics to track each page and how do I insert the code properly so it doesn't catch extraneous pages?
I'm using robohelp 7 and did have it on roboserver, but it would never work properly for us.
  • RoboColum(n)
    Oct 8, 2004
    Jun 2, 2009 1:19 AM   in reply to bigbrook
    I don't want you to think that we are all ignoring your query so I'll pipe up and say I doubt there is much expertise in these forums with Google analytics. Having said that now I suspect someone somewhere will pop up and answer your query . That said, as you stated the RH Server is the Adobe tool that does much the same thing and it does work. If upgrading to RH Server 8 is an option I'd strongly recommend it as it is a whizz to install and use and has some additional features over previous versions that are IMHO worth getting. In the meantime maybe some other forum may provide the answer.
    Read the RoboColum(n) for mutterings on RoboHelp, Technical Communication Suite and technical communication.
    Jun 2, 2009 7:10 AM   in reply to bigbrook
    There are a couple of good threads on RH Server 8 and the general opinion seems to be that RH8 is way better than any previous version. I don't work with it so I cannot say either way. Nevertheless, while understanding the feeling, it might just be you are abandoning just at the wrong moment.
  • RoboColum(n)
    Oct 8, 2004
    Jun 2, 2009 8:55 AM   in reply to Peter Grainge
    I'd certainly echo Peter's thoughts. I am a RH 8 Server user and found it an absolute wheeze to install and use. We got our own server, installed TomCat and the JRE, setup a database and away we went. Obviously I can't speak to the conflicts you have encountered in the past but it certainly seems like the latest version could provide some of your answers. Perhaps if you download the RH8 Server trial you'll be able to sell it to the bean counters. It may be worth trying rather than spending time getting info on RH8 and GA. Just a thought!
    Jun 2, 2009 11:58 AM   in reply to bigbrook
    Hi there
    It would seem tha the answer for you is to edit each page to include the Google Analytics code.
    Question here: Is there different analytics code for each page? Or is it generic code that can simply appear in pages and it does its thing?
    I'm thinking that if it's generic, you might insert it into the Header or Footer of a Topic Template or Master Page, then appy that across all topics to rapidly deploy it.
    Cheers... Rick
    Jan 13, 2010 7:00 AM   in reply to bigbrook
    Hi
    I was just about to do the same thing. Did you get the code to publish in the end? I've tried putting it in the master page and it's not publishing.
    Any tips appreciated.
    Nick.
    Jan 13, 2010 7:11 AM   in reply to ntompkins
    How about a find and replace in your output file?
    You can replace every occurrence of the end body tag (</body >) with the Google analytics code and the end body tag. If you don't want to do it ever time after publish, you could create a macro to do the find and replace.
    Greet,
    Willam
    This e-mail is personal. For our full disclaimer, please visit www.centric.eu/disclaimer.
    Jan 13, 2010 7:16 AM   in reply to Willam van Weelden
    Thanks for helping so quickly.
    What do you mean when you say output file?
    I've tried using RHs Find and Replace function but it seem to work with multiple lines of code.
    What tool would you use to find and replace the code?
    Nick.
    Jan 13, 2010 7:29 AM   in reply to ntompkins
    I mean the completed WebHelp in your output folder (normally ). You can also replace it in the project itself, but in my experience, RoboHelp doesn't always's look kindly to custom javascript.
    As for a tool, you can use FAR (helpware.net) or BKReplace. BKReplace is free and FAR has a trial period. Try them both and then decide.
    Greet,
    Willam
    Jan 13, 2010 8:19 AM   in reply to Willam van Weelden
    Thanks - sounds logical will give it a go and let you know how I get on.
    Nick.
    Apr 9, 2010 7:26 AM   in reply to bigbrook
    Hi bigbrook,
    I've gotten Google Analytics to work with my (AIR) browser-based Help project (on our company's intranet). I know you use RoboHelp 7 and publish to WebHelp (I use RoboHelp 8 and publish to [AIR] browser-based Help, which is just HTML files + some Flash), but below is the procedure I use. Perhaps you'll find it helpful. I think the main difference is that RoboHelp 8 uses master pages, which are like topic templates in RoboHelp 7, and that you can apply a master page when generating the Help.
    1. Open your RoboHelp project.
    2. Go to the Project Set-up pod.
    3. Right-click Master Pages and select  New Master Page.
    4. Give your master page a name. Google is a good  suggestion.
    5. Add the Google tracking code after the <?rh-region_start type="body"  ?> tag.
      The topic <body> should look like  this:
      <body>
               <p>&#160;</p>
          <?rh-region_end  type="body" ?>
      <!-- Google Analytics tracking code -->
          <script type="text/javascript">var gaJsHost = (("https:" ==  document.location.protocol) ? "https://ssl." : "http://www.");
          document.write(unescape("%3Cscript  src='" + gaJsHost + "google-analytics.com/ga.js'  type='text/javascript'%3E%3C/script%3E"));</script>
          <script  type="text/javascript">try {
          var pageTracker = _gat._getTracker("
      UA-xxxxxxxx-n");
          <!-- The following line allows you to track the Help on an Intranet that does not have a Fully Qualified Domain name (such as our SharePoint site. It is sharepoint.xyz.local and not sharepoint.com/.net/.org.)-->
              pageTracker._setDomainName("none");
              pageTracker._trackPageview();
              } catch(err) {}</script>
      </body>
    6. Save the master page.
    7. Open your Adobe AIR/browser-based Help/WebHelp Single Source  Layout.
    8. In the Content section, select Apply  to all Topics and select the master page you just created.
    9. Generate the Help.
    10. Upload the Help to the web server.
    1. Currently Being Moderated
      Jun 22, 2010 6:19 AM   in reply to Jason Nichols
      Hi miauster,
      I saw your posting about using Google Analytics in RoboHelp.  I haven't used Google Analytics yet myself.  Can you tell me, since the URL for a RH project doesn't change regardless of the topic the user clicks on, is Google Analytics able to provide you with information about what topics users went to, how many times, etc.
      For others reading, I know RoboHelp Server does reporting but we won't be purchasing.  I am interested in finding other ways to capture information on what topics users are navigating to within my RH project and gain insights into possibly which topics are getting hits most often, etc.
      Any information would be appreciated.
      Sue
    2. Currently Being Moderated
      Jun 22, 2010 6:27 AM   in reply to SueKL
      Hi Sue
      It is my understanding that one adds the Google Analytics tracking code to the topics that you wish to track. When the topics load into the frame of the frameset or into the browser, the code is then executed. So even if you don't see the URL changing in the address bar, it is still able to track things.
      Cheers... Rick
      Helpful and Handy Links
      RoboHelp Wish Form/Bug Reporting Form
      Begin learning RoboHelp HTML 7 or 8 within the day - $24.95!
      Adobe Certified RoboHelp HTML Training
      SorcerStone Blog
      RoboHelp eBooks
    3. Currently Being Moderated
      Jun 22, 2010 6:32 AM   in reply to Captiv8r
      Hi Rick,
      Thanks for the quick response.  Do you happen to know if it will work w/the great suggestion posted by miauster in thread #13 which will eliminate having to put it on every page I want to see.  Also, would we have to do this everytime we regenerate the project or would it just stay on the page?
      Again, thanks for the response.  Greatly appreciated.
      Sue
    4. Currently Being Moderated
      Dec 31, 2013 9:17 AM   in reply to SueKL
      I'm also curious to know how the great suggestion in post 13 works. I followed the instructions and generated my WebHelp output. I haven't yet asked the developer to upload the help to the web server until I understand more about this. After I generated the help, I viewed the page source code and I didn't see that the Google tracking snippet code in any of my help topic pages. Do I need to see this, or do we not see analytics code until or unless we upload the help to the web server?
    5. Currently Being Moderated
      Jan 6, 2014 7:38 AM   in reply to dmagnum74
      Nothing changes when you upload the generated files so if you don't see the code in them now, it will not be there.
      I am not clear how adding something to the body of a master page and applying that to existing topics would get the code in. Adding master pages to existing topics only applies the headers and footers. I am wondering if something Rick has posted in the past is how it was done. There is a sort of no man's land in a master page where body content does get added but I am not sure it would work here.
      @Rick. Do you think that could be it?
      @petergrainge
    Bookmarked By (1)
