Adobe 8.1.3 adobe pdf printer error
Jun 2, 2009 2:43 PM
I have adobe 8.1.3 installed on a Windows XP machine. When I try to print to the adobe pdf printer, the printer que shows the status of the print job as "Error - Printing" and I get a dialog box called "Save PDF File As" and no matter how many time I click save or cancel the dialog box continues to pop up.  Only after I cancel the print job manually (in the queue) can I get the pop up box to go away.
Any suggestions?
    Jun 3, 2009 5:06 AM   in reply to bluemac316
    Can you print-to-file with the Adobe PDF printer and then open that file in Distiller to complete the conversion process? If so, you likely have disabled AcroTray (check the running processes - ctrl-alt-del - and see if it is running). It can be started from the Distiller folder and should be listed in the startup folder.
    Jun 21, 2009 9:33 PM   in reply to bluemac316
    I may have discovered a solution to this problem.
    See attached PDF file for possible solution.
    Check out and see if this works.
    Tariq
    Any suggestions?
    Jun 21, 2009 9:32 PM   in reply to bluemac316
    Sorry about the double post---I got an error message on my first post, was not sure if it went through.
    Tariq
    Message was edited by: tariqm1
    Sep 9, 2009 5:51 AM   in reply to tariqm1
    Thanks tariqm1,
    This port switch fixed the small annoyance of a problem that had been plaguing me for years!
    Great post.
    -jacob.ritchie
