Bandwidth and usage statistics
Jun 5, 2009 4:13 PM
we need to record and display daily/weekly/monthly statistics on vod application usage,
we are working with multiple application and need statistics for each one of them individually
parameters required are bandwidth,number of connection,view time ...
can someone point on practical way to do it?
Regards,
Kobi Shalom
kobi@koh.co.il
KOH IT Solutions
    Jun 5, 2009 5:11 PM   in reply to KOHITSolutions
    FMS creates standard logs, and you can read them using most log readers (such as sawmill) or a custom application.
    Take a look at the access logs in the fms/logs directory... that's where you'll find much of the info you need. The fields in the logs can be customized... see fms/conf/logger/xml for descriptions of the options.
    Jun 15, 2009 6:18 AM   in reply to KOHITSolutions
    I've never worked with streaming server, but I'm almost certain that it does not support multiple Vhosts. You might want to confirm that with Adobe sales.
    Jun 2, 2010 12:19 PM   in reply to JayCharles
    Hi Jay,
    Is there any way to access logs using the Administration console?
    Jun 3, 2010 12:34 AM   in reply to jephperro2
    You can click on Manage servers and then on the tab server logs. There you will see some logging info from the server. Please keep in mind that if you need more details it is always better to check the static logs as the information in admin console is not static reading from the FMS logs. This has some limitations as it will only show live logging and also not all events will be displayed here. There will be limited information regarding which core was started or went down and event such as connect to a certain application.
    If you require more details FMS logs or Admin APIs are the way to go.
    Abhishek
