Home/Support/
Forums
This Question is Possibly Answered
1 "correct" answer available (10 pts) 2 "helpful" answers available (5 pts)
15 Replies Last post: Jun 12, 2009 7:20 PM by 1000girl
1000girl User 8 posts since
Jun 5, 2009
Jun 5, 2009 4:55 PM
printing
I have trouble getting proper skin tones when I print eventho the color looks great on the screen. On print w/ preview, I have checked "Let photoshop determine the color". Skin tones look colorless when I print w/ my Canon Pro 9000. If I print using Automate, East Print, the colors are OK but the size can't be adjusted. Any suggestion?
Mylenium CommunityExpert 6,286 posts since
Oct 26, 2006
1. Jun 6, 2009 6:19 AM in response to: 1000girl
Re: printing
Why? Unless your system is fully calibrated, that is utterly pointless and from your description that seems the whole source of evil. Just let the printer driver do the rasterization and color sep and you should get much better results, especially when it is a model with extra inks that PS has no clue about. It's whole management is based on astandard RGB to Lab to CMYK process without special recognition of dedicated photo inks. If you wanted to sue them correctly inside PS, you'd need the proper profiles or build a manual per-channel separation for each ink...
Mylenium
Drew@RU User 25 posts since
May 6, 2009
4. Jun 9, 2009 12:39 PM in response to: 1000girl
Re: printing
Linda--
I'm confused. Did you print it from CS2 and then edit it with the printer software?
It sounds like a issue with the printer and PS using different color profiles. Remember, just because it looks correct on screen doesn't mean it will print the same. Printing and screen rendering are often not even close to matching unless you've had everything calibrated.
I would double check all of your other output settings as well  (in addition to letting the printer manage the color profiles). I find I correct a lot of output problems with by fiddling with the output settings (it's also a great way to learn what all the output settings control!)
Drew
May 6, 2009
6. Jun 10, 2009 1:01 PM in response to: 1000girl
Re: printing
Can you post screenshots so I can get a better idea of how its changing?
May 6, 2009
8. Jun 12, 2009 7:22 AM in response to: 1000girl
Re: printing
Linda--
I don't see the attachments
Drew
May 6, 2009
10. Jun 12, 2009 9:04 AM in response to: 1000girl
Re: printing
I'm still not seing them. Are you using the attachments control at the bottom of the post window or the camera icon in the top controls?
John Joslin Contributor 9,603 posts since
Jul 27, 2006
11. Jun 12, 2009 9:16 AM in response to: Drew@RU
Re: printing
Judging by that annoying message footer, Linda is not using the web interface!
May 6, 2009
12. Jun 12, 2009 9:18 AM in response to: John Joslin
Re: printing
Yeah I think she's replying to the email notifications...which I tried one time and it didn't work, so I thought you couldn't do that
OleRhino User 2 posts since
Jun 12, 2009
14. Jun 12, 2009 6:16 PM in response to: 1000girl
Re: printing
I have the same printer and no complaints at all. One solution would be to buy a monitor calibration device, down to $79 now. (see Spyder at http://spyder.datacolor.com/product-mc-s2e.php). Over print out a large portrait and fix it alongside the monitor. Now adjust the monitor colours until the display matches the print. This is what I did with a laptop. Now if you correct the image to look "normal" it should print out with good results.
David
