[svn:bz-trunk] 7681: Fix bunch of failing config tests on BlazeDS/ trunk by removing javax.servlet. UnavailableException from the expected error string.
Jun 9, 2009 11:44 AM
Revision: 7681
Author:   aglosban@adobe.com
Date:     2009-06-09 11:44:36 -0700 (Tue, 09 Jun 2009)
Log Message:
Fix bunch of failing config tests on BlazeDS/trunk by removing javax.servlet.UnavailableException from the expected error string.
Modified Paths:
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/destination/ IncorrectRootElementTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/AdaptiveServerToClient/AdaptiveFrequencyTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/AdaptiveServerToClient/FrequencyStepSizeTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/AdaptiveServerToClient/MaxQueueSizeTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/DestinationWithNoChannelTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/DestinationWithNoIDTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/jms/InvalidAcknowledgeModeTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/jms/InvalidDeliveryModeTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/jms/InvalidDestinationTypeTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/jms/InvalidMessageTypeTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/jms/NoConnectionFactoryTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/jms/NoJNDINameTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/throttle/throttleInbound/InvalidBufferPolicyTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/throttle/throttleInbound/InvalidConflatePolicyTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/throttle/throttleInbound/UnknownInboundPolicyTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/throttle/throttleInbound/frequencies/McfGreaterthanMfTest/error.t xt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/throttle/throttleOutbound/InvalidBufferPolicyTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/throttle/throttleOutbound/InvalidConflatePolicyTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/throttle/throttleOutbound/InvalidErrorPolicyTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/throttle/throttleOutbound/UnknownOutboundPolicyTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/throttle/throttleOutbound/frequencies/McfGreaterthanMfTest/error. txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/validation/nonExistingValidatorTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/validation/sameExplicitTypeValidatorTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/validation/sameTypeValidatorTest/error.txt
    blazeds/trunk/qa/apps/qa-regress/testsuites/config/tests/messagingSer vice/validation/wrongTypeValidatorTest/error.txt
