stuie2
Acrobat 9.1.2 and Thunderbird
Jun 10, 2009 5:53 PM
I've searched the forums for an answer to getting Acrobat 9 to use Thunderbird as it's email client. Doesn't seem to be any real answers. However, I have a slightly new problem with this. I've done what needs to be done to make Thunderbird the default program. Even went into my registry to confirm. However, every time I try to send a document off, it keeps telling me that it can't open Eudora. Now, Eudora USED to be my default mail, but like I said, I've changed that. Not only did I change the default, but I even deleted the program, and even went as far as to go into my registry to remove it from my Client\Mail section. Acrobat still is asking for Eudora even though it's completely gone. Is there an option I need to address in Acrobat to stop it from looking for Eudora? The error message says it can't access C:\Eudora\Eudora.exe. Duhh, it's not even on my computer any more.
    Jun 10, 2009 7:30 PM   in reply to stuie2
    Acrobat and Reader use whatever is the default MAPI e-mail client. I think I heard that AA9 has added some ability to use other mail connections, but classically the products have simply interfaced to the MAPI interface for Windows Machines. I do not know if Thunderbird can be configured as a MAPI client, but suspect it can. Simple MAPI will do, it does not have to be the newer version MS developed.
    Jun 11, 2009 2:47 AM   in reply to stuie2
    Repair the Acrobat installation.
    Jun 11, 2009 6:56 AM   in reply to stuie2
    Seems like you have registry corruption. Try using "Little Registry
    Cleaner" to fix your registry (Googleit, it's free). See if that helps.
    Best Regards,
    Steve
    Jun 11, 2009 7:57 AM   in reply to S.D.A.
    I agree with SDA. If you have removed Eudora and it is still coming up, then there is an issue with parts of the registry. A lot of programs do not work with the registry well (it is confusing anyway) and that may particularly be the case with an uninstall. It may also be that the OS put some things there when it first noted the e-mail program and has not fixed it. It indeed sounds like an OS issue for the setup of your mail client. Good luck. Bill
    Mar 18, 2010 10:09 AM   in reply to Bill@VT
    I am attempting to use Acrobat 9 Pro to use the COMMENT>ATTACH FOR  EMAIL REVIEW. When I attempt to set the email addresses I want to send  the attached PDF to, and try to continue, it says that Adobe cannot  connect with my email client (Thunderbird).
    I am on Windows 7 and have set  Thunderbird as my default email client. In fact, it has been so  difficult to get Adobe to see the email client that we had to delete  Outlook (actually uninstalled) from the available programs (It has never been configured or used). In fact, the  extensions, protocols and MAPI are all set to Thunderbird.
    Thunderbird help says it is capable of simple MAPI and in fact, Thunderbird is the designated MAPI handler as far as Win 7 is concerned.
    I am  attempting to begin this Reviewer process with the simpliest form:  attach for email review. This is compatible with Reader 7 and up and  allows reviewers to make comments and send them to the initiator. I DO  NOT want to use Outlook. I have used some version of Mozilla mail since  the mid 90's.
    If  someone can explain a workaround for me I would appreciate it very  much. This hiccup is holding up a business transaction.
    Thank you!
    Mar 19, 2010 4:22 AM   in reply to stuie2
    Go to Control Panel>Internet Options>Programs. Be sure that Eudora is not listed as the default mail package. I suspect that there is still some latent part of your system that thinks Eudora is there. Acrobat simply goes to what the system lists.
    Jul 2, 2010 11:35 AM   in reply to stuie2
    I found this in another thread, as I was having the same problem.
    I found a way to make this work. It boils down to setting Thunderbird as default in a very specific way - even if you think it already is the default, it will only work in this way. I'm using Windows 7 Profssional and Acrobat Pro 9.0.
    Here' how: Start > Default Programs > Set program access and computer  defaults > Custom (expand this) > Choose a default e-mail program
    Then, click on 'Thunderbird'. - 'Use my current email program' won't do it, even if Thunderbird is already your default.
    I can now email my pdf documents from Acrobat.
    Jul 2, 2010 12:52 PM   in reply to effulgence
    Thank you for posting this information! It's amazing that Adobe didn't seem to find it necessary to help Windows 7 users with this solution.
    Jul 21, 2010 3:34 PM   in reply to stuie2
    I found this link for Windows XP machines, as I had a problem with Acrobat 7 on one of them.
    This program will set your default mail client! It worked for me.
    http://www.snapfiles.com/get/defaultmail.html
    Oct 4, 2010 1:13 PM   in reply to effulgence
    This is the only thing that worked!  Thank you.
    I have windows 7, acrobat 9.0 and thunderbird.
    I also have outlook 2010 so it seems to think that it is king.
    Feb 4, 2011 9:04 AM   in reply to stuie2
    Good detective work on your part! I just browsed around Mozilla to see what they have about this. Here is a link to an interesting article on MAPI support:
    http://kb.mozillazine.org/MAPI_Support
    I am not an expert on MAPI, and only studied it a long time ago when certifying on Exchange. But I suspect that this is the issue:
    Thunderbird only supports SimpleMAPI while MS supports ExtendedMAPI. From the article:
    "Thunderbird's SimpleMAPI support is buggy."
    Not sure if this needs to be pursued from the Mozilla side or the MS side. However, they do advise re-installing Thunderbird (after backing up). Has anyone tried this?
    Feb 24, 2011 10:48 AM   in reply to stuie2
    Hi Folks,
    I've only been able to make this work by removing all other (than Thunderbird) registered email clients from the Windows 7 registry. I tried ALL of the suggestions people have made, but Acrobat (v10, now) seemed to have eyes only for Outlook on my machine.
    I was finally able to have Acrobat use Thunderbird by deleting all other registered email clients from the registry (using regedit to find HKEY_LOCAL_MACHINE\SOFTWARE\Clients\Mail) leaving ONLY Mozilla Thunderbird (the key name)... and Voilla... Acrobat will finally attach a file to a Thunderbird message window for sending...
    Your mileage may vary, and you should back up your registry before messing around this way...
    SJB
    Apr 12, 2011 10:22 PM   in reply to stuie2
    A solution that worked for me, as posted by gertw22 here:
    http://forums.adobe.com/message/3610561#3610561
    I quote:
    Be careful, as some of the other answers here are really bad advice.
    Calculating status...
    Oct 21, 2011 2:19 AM   in reply to stuie2
    Windows 7 64 Pro, Thunderbird 7.0 (updated recently) : the "publish form" is completely bugged.
    Before reading solutions here : can't find mail program error messages (can't find my adress book in TB)
    After applying the fix : set the by default programm forced on Thunderbird -> http://forums.adobe.com/message/3610561#3610561
    Acrobat "resolves mail adress", then the submit button make a small dialog box appear (can't read anything in it). Nothing happens.
    I can click and re-click several times, same "empty" or "not displaying a message long enough" dialog box keeps appearing. No forms sent whatsoever.
    This is critical. I'm an ACI. I must set up a special training for one of our customers, about delivering forms. Ok, that issue is on my personnal computer, so far.
    I may need to fix the install, or reinstall whatsoever, BUT : can I really come with that kind of answers in a classroom ?
    "-Oh, and now publish the form, by clicking here..."
    "-Oh, that doesn't work ? Hmmm, it's a known issue without any solution. Uninstall everything and reinstall everything, that should work (or not). Yeah, I know, it's Acrobat...
    and no, sorry, I don't have time to uninstall an reinstall everything on all the computers in the classroom, sorry, it's the end of the day. Bye ! What ? You, students, think this
    training was in fact useless ? Hm, you kinda of right...we spent a whole day setting forms, discussed how Acrobat is a cool software, and in the end our forms are good to be dropped to the trashcan."
    May we have a answer from the Acrobat Team here ?
