[Test(expects="Error")] not functioning as expected
Jun 11, 2009 8:29 PM
When testing against implementation code which is expected to throw an exception the test fails even when the expected exception is thrown.
I broke this test down into a very simple example to help illustrate the issue:
public class ExpectsExampleTest
    public function testExpects():void
        throw new Error();
The above code result in the following error:
6/11/2009 23:23:39.519 [WARN] FlexUnit4 There was 1 failure:
6/11/2009 23:23:39.522 [WARN] FlexUnit4 1 tests::ExpectsExampleTest.testExpects Error
Not sure if I am missing something or not, however the implementation appears to be correct.
Eric
    Jun 11, 2009 8:32 PM   in reply to efeminella
    Eric,
    there was a bug surrounding this issue. Latest bits in SVN should have it corrected. There was a difference between the docs and code.
    if you get the latest, it will work as is, or, you can change the word expects to expected and it will likely work in yours.
    It the new version it accepts either,
    Mike
    Oct 18, 2010 2:19 PM   in reply to Michael Labriola
    mlabriola wrote:
    Eric,
    Mike
    thanks mike, you're right
