Sri200
How to change the font size of Text box tool ?
Jun 12, 2009 4:06 AM
I am using Acrobat PDF 6.0
Tools > Advanced Commenting > Text Box Tool
I need to know how to change the font size. The default font size is too big.
let me know
    Jun 25, 2009 3:53 PM   in reply to Sri200
    I feel you pain dude. Here's what you do. Select the text you have in the text box, so only the text is highlighted. Then hit control E. Wallah. That should fix your problemo. If control E doesn't work, you may need to go into Preferences and select "use single key accelerators", but I know less about that because I didn't have to do that with my 6.0 program. Good luck!
    Jun 26, 2009 5:58 AM   in reply to Sri200
    Typically you would select the text and right click to change the properties.
    Jun 29, 2009 7:06 AM   in reply to Sri200
    In the 'Prefernces' for Acrobat, you can set the default font and font size. If you need to make a one time change, create you comment in MS Word with the font, size, and other formatting you want to use, and then cut and paste the text into the text box. Once you have created the text box this way, you can use the context menu for the comment field to make these properties your default.
    Jun 29, 2009 7:43 AM   in reply to Sri200
    I do not have AA6 available right now (I can check at home this evening). I am also using AA Pro, not Std. In AA7, there is a text box tool that is a commenting tool. When I started typing, a properties toolbar came up that had the font size and such. I haven't figured out how to get the toolbar after the fact. In AA8, I selected the text box tool and then went to view and selected the properties bar (the font size and all showed then), or use Ctrl-E when editing the text. I have not been able to figure out how to edit the text in a text box after you have created it - think it is a mental block right now. Bill
