Home/Support/
Forums
0 Replies Last post: Jun 15, 2009 8:37 AM by Chet Haase
Chet Haase User 137 posts since
Sep 10, 2008
[svn:fx-trunk] 7836: PARB changes for effects.
Revision: 7836
Author:   chaase@adobe.com
Date:     2009-06-15 07:37:21 -0700 (Mon, 15 Jun 2009)
Log Message:
PARB changes for effects. This includes various property renames, a couple of class renames, moving 3 classes to a sub-package, and various doc cleanups. This also includes changing a handful of Array properties to typed Vectors.
QE: This breaks Mustella due to the renames
Doc: Docs will need to be updated to reflect the changes as well
Bugs: None
Reviewer: Jason
Tests: checkintests, Thermo's transitionbug test
Modified Paths:
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/Sc rollBar.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/Sl ider.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Animate.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateColor.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransform.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/CallAction.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/CrossFade.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/CrossFade.pbk
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Move.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Rotate.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Rotate3D.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Scale.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/Wipe.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/Animation. as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/IAnimation Target.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/RepeatBeha vior.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/easing/EasingFractio n.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/easing/Linear.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/easing/Power.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/easing/Sine.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/interpolation/ArrayI nterpolator.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/interpolation/HSBInt erpolator.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/interpolation/IInter polator.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/interpolation/Number Interpolator.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/interpolation/RGBInt erpolator.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/Anima teColorInstance.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/Anima teInstance.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/Anima teTransformInstance.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/CallA ctionInstance.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/FadeI nstance.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/Resiz eInstance.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/WipeI nstance.as
    flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/HSBColor.as
    flex/sdk/trunk/frameworks/spark-manifest.xml
Added Paths:
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransitionSha der.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/Keyframe.a s
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/MotionPath .as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/animation/SimpleMoti onPath.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/Anima teTransitionShaderInstance.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/utils/BitmapUtil.as
Removed Paths:
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateShaderTransit ion.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/KeyFrame.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/MotionPath.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/SimpleMotionPath.as
    flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/Anima teShaderTransitionInstance.as
