Revision: 7862
Author: jszeto@adobe.com
Date: 2009-06-15 15:06:23 -0700 (Mon, 15 Jun 2009)
Log Message:
GraphicElement PARB Changes
mx.core.AdvancedLayoutFeatures
?\226?\128?\162 Rename layer -> depth
?\226?\128?\162 Rename offsets -> postLayoutTransformOffsets
mx.core.IVisualElement
mx.core.UIComponent
mx.graphics.GradientBase
?\226?\128?\162 Remove scaleX
mx.graphics.GradientStroke
?\226?\128?\162 Add apply(g:Graphics, bounds:Rectangle)
mx.graphics.IStroke
?\226?\128?\162 Remove draw
?\226?\128?\162 Change apply(g:Graphics) -> apply(g:Graphics, bounds:Rectangle)
mx.graphics.LinearGradient
?\226?\128?\162 Add scaleX
mx.graphics.LinearGradientStroke
mx.graphics.RadialGradient
mx.graphics.RadialGradientStroke
mx.graphics.SolidColorStroke
mx.flash.UIMovieClip
spark.components.PopUpAnchor
?\226?\128?\162 Change popUp type from UIComponent -> IFlexDisplayObject
?\226?\128?\162 Rename positionPopUp -> calculatePopUpPosition
?\226?\128?\162 Rename autoSizePopUpWidth -> popUpWidthMatchesAnchorWidth
?\226?\128?\162 Rename autoSizePopUpHeight -> popUpHeightMatchesAnchorHeight
spark.core.RelativePosition
?\226?\128?\162 Rename and move spark.core.RelativePosition -> spark.components.PopUpPosition
?\226?\128?\162 Rename EXACT -> TOP_LEFT (topLeft)
spark.core.SpriteVisualElement
?\226?\128?\162 Remove computeMatrix
spark.primitives.BitmapImage
?\226?\128?\162 Change NORMALUINT from protected -> private
?\226?\128?\162 Change REPEATUINT from protected -> private
?\226?\128?\162 Change SCALEUINT from protected -> private
?\226?\128?\162 Change resizeModeToUINT from protected -> private
?\226?\128?\162 Rename drawElement -> draw
spark.primitives.Line
?\226?\128?\162 Rename skipMeasure -> canSkipMeasurement
spark.primitives.Path
?\226?\128?\162 Change graphicsPath fro protected -> mx_internal
?\226?\128?\162 Rename renderGraphicsAtScale -> generateGraphicsPath
?\226?\128?\162 Change generateGraphicsPath from protected -> mx_internal
?\226?\128?\162 Rename notifyElementLayerChanged -> invalidateDisplayObjectSharing
spark.primitives.Rect
spark.primitives.supportClasses.GraphicElement
?\226?\128?\162 Rename getBitmapData -> captureBitmapData
?\226?\128?\162 Add protected hasComplexLayoutMatrix:Boolean getter
?\226?\128?\162 Remove target
?\226?\128?\162 Change DEFAULT_MAX_WIDTH from public -> private
?\226?\128?\162 Change DEFAULT_MAX_HEIGHT from public -> private
?\226?\128?\162 Change DEFAULT_MIN_WIDTH from public -> private
?\226?\128?\162 Change DEFAULT_MIN_HEIGHT from public -> private
?\226?\128?\162 Change allocateLayoutFeatures from protected -> mx_internal
?\226?\128?\162 Change invalidateTransform from protected -> private
?\226?\128?\162 Change captureBitmapData from public -> mx_internal
?\226?\128?\162 Change applyMaskType from protected -> mx_internal
?\226?\128?\162 Change dispatchPropertyChangeEvent from protected -> private
?\226?\128?\162 Change applyComputedTransform from protected -> mx_internal
?\226?\128?\162 Change filterChangedHandler from protected -> private
spark.supportClasses.StrokedElement
?\226?\128?\162 Remove getStroke()
?\226?\128?\162 Add getStrokeExtents() override
QE Notes: None
Doc Notes: None
Bugs: N/A
Reviewer: Glenn
Modified Paths:
flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.a s
flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/ButtonBar.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/DataGroup.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Group.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/Gr oupBase.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/core/SpriteVisualElement.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransform.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransitionSha der.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/Anima teTransitionShaderInstance.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/BitmapImage.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/Ellipse.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/Line.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/Path.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/Rect.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/Fi lledElement.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/Gr aphicElement.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/St rokedElement.as
flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/Te xtGraphicElement.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/AdvancedLayoutFeatures .as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IVisualElement.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/TransformOffsets.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/BitmapFill.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/GradientBase.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/GradientStroke.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/IFill.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/IStroke.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/LinearGradient.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/LinearGradientStro ke.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/RadialGradient.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/RadialGradientStro ke.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/SolidColor.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/SolidColorStroke.a s
