Right Click functionality in Captivate 4
Jun 17, 2009 9:58 PM
Hi all,
Did I get excited too soon when I saw the option "Right click" in the Click box properties?
I published my file with AS3 and AS2, I have tested my files on a web server (so not locally). In both cases I get the Flash right click menu.
I made sure that accessibiliy was enabled (as suggested by Adobe in the pop up box).
Is there anything else I need to do that I am not aware of?
Cheers, Helga
    Jun 17, 2009 10:21 PM   in reply to Helwiener
    Prior to publish you need to uncheck the accessibility option.
    You could do that at:
    Preferences dialog ->Project -> Publish settings: Enable Accessibility checkbox. Uncheck it an dre-publish.
    Manish
    http://blogs.adobe.com/captivate
    Jun 18, 2009 10:16 PM   in reply to Helwiener
    I am inserting the published swf files into a html file that contains a menu and links to other pages, etc.
    When using the swf stand alone the right click works, when using it in another html file. "
    Could you please be specific abou the underlined part. I am sorry I am not able to comprehend it.
    Manish
    Jun 19, 2009 12:11 PM   in reply to M_Anand
    I'm having a similar problem when inserting a SWF, created with CP4 and containing right click boxes, into a Adobe Presenter Project. In this project, when published, the right click boxes will not work, but will open the Flash context menu (as in CP3).
    Jun 19, 2009 11:04 PM   in reply to Lilybiri
    Hi all
    @Manish - I believe what was being said was that right-click doesn't work if you forego the Captivate created HTML page and opt instead to insert the Captivate movie on a different HTML page.
    @Lilibiri - The statement above is probably related to your issue. I believe all the right-click functionality for this is stored in the JavaScript associated with the Captivate created HTML page.
    Cheers... Rick
    Jun 21, 2009 4:10 AM   in reply to RoboWizard
    Thanks, Rick, for the explanation. Could there be a workaround possible (Manish?).  Not using Presenter but Captivate itself for converting the ppt-files to Flash works of course, but Presenter has some nice features... Since both programs are integrated in the eLS? Same problem when inserting CP-created SWF's into a Acrobat-document, which I understand to have the same cause as with inserting in Presenter. Thanks again for your contribution to this great forum.
    Lilybiri
    Jul 14, 2009 8:23 AM   in reply to Helwiener
    Here is what was required for me to successfully publish a .swf file that includes a right-click action trigger:
    (1) Publish location: Default "My Adobe Captivate Projects" directory
    • After publishing, can move to different directory. If you play locally from this other directory, the right-click action trigger will not work, but if you upload to the internet from this location, the right-click action trigger will work.
    (2) Actionscript: AS2
    (3) Accessibility: Off
    (4) Publish For Flash Player 9, not 8 (even though the help file says 8 and higher)
    Nov 5, 2009 10:41 AM   in reply to RoboWizard
    I have a simiular issue I can ge thte right click to work on the htm page but not the published swf file.. I have set the security I have all 3 files htm, swf and JS.
    Here is what I am trying to do. I have a E-learning system that has a shell player for features like chapters select and remote control functions. I publish the captivate 4 files to my Graphic files, I have the player looking at xml which calls the .swf file to play, in xml if I try to change this to call the htm file it just comes up blank so I can’t do that but shouldn’t the swf file contain the right click from captivate? I wonder is the shell needs something for the right click code as it bring up the setting and about property box when I right click in the player.   Any Ideas?
    thanks,
    Chuck
    Nov 16, 2009 3:10 PM   in reply to M K B
    MKB, Thank you for pointing out the power of the My Adobe Captivate Projects folder.  Anyone know why right-clicking works fine when I run the published file (double-clicking the HTM file) from that folder (C:\Documents and Settings\LBivens\My Documents\My Adobe Captivate Projects) but doesn't work if I move the files?
    What's the magic of that folder in that location?
    I read something on the forum that implied that right-clicking will work again once the files are posted on a web server.  But I need these files to work when I e-mail them to my manager for review. (I can't post to the server: I'm only a contractor).
    Am I left to go back to William Heinz' fool-proof workaround?  --Leslie
    Nov 16, 2009 11:08 PM   in reply to Scout\'s mom
    You must move All the files the .js and .swf file and make sure the Adobe security is set for this new location as well.
    Charles Behm
    IT Services, Global Professional Services
    Intuit Real Estate Solutions (IRES)
    20800 Harvard Road * Cleveland, OH 44122
    Tel 216.825.6540     Mobile 216.534-0613
     charles_behm@intuit.com       www.realestate.intuit.com
     Login to our ClientSite to request our services: GPS Request
    Nov 16, 2009 11:39 PM   in reply to Scout\'s mom
    Hello,
    The folder "My Adobe Captivate Projects" is automatically added to the 'trusted folder'. Thus you do not have any problems with the Flash Security settings. Other folders have to be added to the 'trusted' sites.
    Lilybiri
    Nov 17, 2009 9:42 AM   in reply to cebehm
    What a pain!  Thanks to both Charles and lilybiri for the info.
    I guess I'm a tad befuddled.  Are all these obscure security gyrations warranted?  --Leslie
    Mar 3, 2011 2:45 PM   in reply to Helwiener
    Hi. The right-click functionality works for me most of the time. My problem is that I'm running the Captivate simulation within a Flash interface that runs in an HTML file. I have the JavaScript code, and, like I said, it mostly works. But while in a Captivate with a double click or right click, if I click/activate anything in the interface, like a menu, the specialized click boxes no longer work.
    I know that the problem is likely that I've taken the focus off the CP movie and have it on the interface. Does anyone have a way to get the focus BACK on the Captivate movie?
