Controlling the Playhead Between Slides in Flash Presentation
Jun 23, 2009 7:47 AM
HI everyone.  After using Flash for many years for animation I've finally discovered the Flash Presentation document setup, but I'm stumbling at the first hurdle in getting my head around the document structure and how the playhead moves between slides/screens.
I have a small 48 frame animated "text bullet" which fades in and then glows for a second.  I have placed this on one layer in slide 2, and have tweened it so that it flies in from the left of the screen, stopping in the middle.  This is great but have noticed that when advancing to the next slide, slide 3, and then hitting the left arrow to go back to slide 2, the animated instance of the text bullet is at the same position/state as when I navigated away from slide 2 to slide 3.
So how come the playhead doesn't automatically jump to the start (frame 1) of slide 2 when I navigate back?  I have explored the Behaviours but haven't managed to sort out this very basic first step - help would be appreciated as I can't advance in the design of this presentation unitl I've mastered these basics!!!
    Jun 23, 2009 8:28 AM   in reply to Paradigm
    It's not clear how you have things arranged, but if that animation remains as a self-animated object when you get to the next slide, then returning to the start of it won't reset it.  What you might try is moving it up one frame from where the second slide starts (if that is possible... like I said, don't know how you've got things set up).  Otherwise, you will likely need to give the object an instance name and at the start of the second slide use... instanceName.gotoAndPlaty(2);
