I want to remove the rows of a table in a form at runtime.
I have created the table by customising a button and writting javascript.
now i want to delete some rows of the table by another button,.
For example i added 4 rows in above form and i want to delete 2 rows (1st and 3rd)
when i click remove button it will delete only 1st row.
the java script of remove button is like this:
for(i=xfa.form.plan.planDocument.plan1.task.instanceManager.max;i>=1;i--)
if(i>xfa.form.plan.planDocument.plan1.task.instanceManager.min)
if(plan.planDocument.Header.plan1.task.Table5.Row1.rowdelete.rawValue==1)
xfa.form.plan.planDocument.Header.plan1.task.instanceManager.removeInstance(0);
This deletes only the first row that is selected
How can i do this.
The instanceManager.removeinstance() method delete only the first row of the all selected rows..
Views
Total Likes
Replyyyyyyyyyyyyyy?????/
Views
Total Likes
Hi rajdudi,
replace ur line
with
xfa.resolveNode("form.plan.planDocument.Header.plan1.taskTable5.Row1.instanceManager.removeInstance("
+i+")"); have a try.
by passing i to removeInstance, it knows the index of the row to delete
Madhu.
Views
Total Likes
Hi Madhu,
Thanks for the reply.
But the changes you advised me to make in the script are not working to give the required result.
xfa.resolveNode("form.plan.planDocument.Header.plan1.taskTable5.Row1.instanceMan ager.removeInstance("
+i+")");
In this script the if statement always checks the first row of the table and then Removeinstance removes the ith row of the table irrespective of the status of Delete check of that row.Whethre it was checked or not.
For example 1st row is checked and i=2 then if then this script will remove the 2nd row.
I want the script deletes all the checked rows only
Views
Total Likes
Hi rajdudi,
please find the attached sample form.
i have written a script for Delete button in click event which calls a function
removenull.removecheckedrows()
code in click event of button
var
tlength = xfa.resolveNodes("body.Table1.Row1[*]").length;
for
( var j=1; j<tlength; j++)
if(!removenull.removecheckedrows())break;else
continue;}
and written a function
// Function to remove the Checked rows from Table1
function
removecheckedrows()
var tlength =xfa.resolveNodes("body.Table1.Row1[*]").length;
for ( var i=0; i<tlength; i++)
if(xfa.resolveNode("body.Table1.Row1["+i+"].CheckBox1").rawValue ==1 )
body.Table1.Row1.instanceManager.removeInstance(i);
return true;
// end function
which will remove the selected rows.
try to implement this in your form
if u r unable to download attached form give ur mailid i will forward the same.
Madhu.
Views
Total Likes
Hi Madhu,
I am not able to download the attachment in your reply.
Please send me that from at rajdudi@gmail.com
Raj Dudi
9764006704 | Pune
Views
Total Likes
