Iteryx
Error #2044 & Error #2048
Jul 7, 2009 11:46 AM
Hello,
I am running Flex 4 SDK and a beta of Flash Builder 4 on an Eclipse IDE. I have two files: one is a small flex program that establishes a XML Socket on the localhost, the other is a Java program that writes a simple string to the port that the flex program listens to. The purpose of this program is to get used to TCP with flex. Both programs run inside of the Eclipse IDE. However, when I run the program, I get the following error message:
Error #2044: Unhandled securityError:. text=Error #2048: Security sandbox violation
I have searched quite a bit for a solution to this problem to no avail.  Any help would be greatly appreciated.
Thank you.
    Jul 7, 2009 1:31 PM   in reply to Iteryx
    There are "Security WhitePapers" on the Adobe site.  They explain the rules for security.
    Alex Harui
    Flex SDK Developer
    Adobe Systems Inc.
    Blog: http://blogs.adobe.com/aharui
    Jul 8, 2009 8:32 AM   in reply to Iteryx
    For what it's worth, I just put together something simple and it seems to work:
    Both are run from a common folder.  Note that (AFAIK) you can't create a socket server in Flash (only clients)...so the java socket server needs to be started first:
    Keep in mind that things won't work out of the box (due to security issues) - an easy way to get things up and running (sans crossdomain file returned from your socket server) is to ensure your app is running in the local-trusted sandbox.
    To do this you need to add the path (where your Client.swf resides) to a text file living in either your global "FlashPlayerTrust" folder or your user level FlashPlayerTrust folder.
    For example, on Mac I've added a file called 'trust' containing one line:
    file:///Users/clucier/apps/SocketTest/
    ... to my "global" FlashPlayerTrust folder located at: /Library/Application Support/Macromedia/FlashPlayerTrust.
    See http://livedocs.adobe.com/flex/3/html/help.html?content=security2_25.h tml
    Pardon the verbose post, attachments don't work too well for me lately so included src inline...
    SimpleServer.java:
    import java.io.*;
    import java.net.*;
    public class SimpleServer
            public static void main(String args[])
                    // Message terminator
                    char EOF = (char)0x00;
                    try
                            // create a serverSocket connection on port 9999
                            ServerSocket s = new ServerSocket(9999);
                            System.out.println("Server started. Waiting for connections...");
                            // wait for incoming connections
                            Socket incoming = s.accept();
                            BufferedReader data_in = new BufferedReader(
                                  new InputStreamReader(incoming.getInputStream()));
                            PrintWriter data_out = new PrintWriter(incoming.getOutputStream());
                            data_out.println("Welcome! type EXIT to quit." + EOF);
                            data_out.flush();
                            boolean quit = false;
                            // Waits for the EXIT command
                            while (!quit)
                                    String msg = data_in.readLine();
                                    if (msg == null) quit = true;
                                    if (!msg.trim().equals("EXIT"))
                                            data_out.println("You sayed: <b>"+msg.trim()+"</b>"+EOF);
                                            data_out.flush();
                                    else
                                            quit = true;
                    catch (Exception e)
                            System.out.println("Connection lost");
    Client.mxml (Flex 4):
    <Application xmlns:fx="http://ns.adobe.com/mxml/2009"
                 xmlns="library://ns.adobe.com/flex/spark"
                 xmlns:mx="library://ns.adobe.com/flex/halo"
                 width="1024" height="768">
        <!-- Compiled FXG placed on the left -->
        <layout>
            <VerticalLayout/>
        </layout>
        <fx:Script>
            <![CDATA[
                import flash.net.XMLSocket;
                import flash.events.*;
                private var hostName:String = "localhost";
                private var port:uint = 9999;
                private var socket:XMLSocket;
                public function connect():void {
                    socket = new XMLSocket();
                    configureListeners(socket);
                    socket.connect(hostName, port);
                public function send(data:Object):void {
                    socket.send(data);
                private function configureListeners(dispatcher:IEventDispatcher):void {
                    dispatcher.addEventListener(Event.CLOSE, closeHandler);
                    dispatcher.addEventListener(Event.CONNECT, connectHandler);
                    dispatcher.addEventListener(DataEvent.DATA, dataHandler);
                    dispatcher.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler);
                    dispatcher.addEventListener(ProgressEvent.PROGRESS, progressHandler);
                    dispatcher.addEventListener(SecurityErrorEvent.SECURITY_ERROR, securityErrorHandler);
                private function closeHandler(event:Event):void {
                    ta.text += String("closeHandler: " + event);
                private function connectHandler(event:Event):void {
                    ta.text += String("connectHandler: " + event);
                private function dataHandler(event:DataEvent):void {
                    ta.text += String("dataHandler: " + event);
                private function ioErrorHandler(event:IOErrorEvent):void {
                    ta.text += String("ioErrorHandler: " + event);
                private function progressHandler(event:ProgressEvent):void {
                    ta.text += String("progressHandler loaded:" +
                                event.bytesLoaded + " total: " + event.bytesTotal);
                private function securityErrorHandler(event:SecurityErrorEvent):void {
                    ta.text += String("securityErrorHandler: " + event);
        </fx:Script>
        <Button label="connect" click="connect()"/>
        <TextArea id="ta" width="300" height="200"/>
    </Application>
    Jul 8, 2009 8:48 AM   in reply to CoreyRLucier
    This post was also helpful and worked for me... shows how you can easily setup your socket server to also serve up the cross domain policy file.
    http://blog.pettomato.com/?p=9
    Note the call to System.security.loadPolicyFile prior to making the client connection.
    Regards,
    C
    Jul 8, 2009 11:46 AM   in reply to Iteryx
    import flash.system.Security;
    Security.loadPolicyFile(...) should work fine.
    Sorry to hear you are on Vista..will try to dig up where the global FlashPlayerTrust folder is.
    -C
    Jul 9, 2009 10:51 AM   in reply to Iteryx
    This may help:  http://opensource.adobe.com/wiki/display/flexsdk/Setup+on+Windows
    Scroll down to the FlashPlayerTrust section, they mention a Vista specific issue with creation of the folder and file...  perhaps thats what you ran into.
    In any event, the trust file they setup in those steps is all inclusive (of C:\)..curious if that liberal policy helps your case.
    -C
