I am trying to install adobe reader 9.0 to a computer on a network. The my documents folder is mapped to a network drive on the server. The computer is running win XP Pro SP3.
The error I keep getting is:
error 1324 the path my documents or the volume is invalid. please enter the path and try again.
there is nothing to enter to change. It seems the installation is hard coded to look for a particular drive or something. Can someone please help.
thanks!
Thanks for the response, but the first thing I did was to read the forum that you pointed out. I did not find anything that had a definite solution outlined that related to my problem. The other problem is that the computer is at church and calling adobe is a problem for me, since I need to be in front of the computer to fix it and help them diagnose the problem.
the only thing I have gathered from the posts and other websites is that it is related to the registry entries somehow. I dont know which ones it is having a problem with since there are no installation logs to refer to.
Have you solved your problem yet?
Could you please let me know if you have the "My Documents" folder redirected to a network shared folder.
If so then try to logon to the machine with the local administrator account or another local user with administrator rights. This will assure that the "My Documents" is local and not a redirected folder.
Installing Reader should work fine and once it's installed should be available for use to all users.
Interesting problem and probably would be the same on Acrobat too. Too bad I do not have a solution. I think there are some posts about a registry entry for the default folder, but you will just have to search the forum. Other than that, I have never seen anything posted on this type of topic before.
This same issues will happen with Acrobat, Acrobat Reader and Authorware.
This Solution should help every product which is being installed in a Windows 7 environment.
The issue is with the "My Documents" folder redirected to a server using Group Policies. The Acrobat installer is looking for c:\documents and settings or c:\users and can't handle it when the folder is in a different location.
I just had the same problem when I tried to install Acrobat 9 Pro. I first had to reset My documents to C, install the program and then change it back to our network disk. According to our IT guy, most programs today requires My documents to be on your own computer, otherwise they wont install.
Lena
North America
Asia Pacific
