Document could not be printed
Jul 16, 2009 10:27 PM
  Latest reply: altekro.com, Apr 3, 2013 10:10 AM
Replies 1 2 3 4 5 4 Previous Next
    Sep 12, 2012 4:36 PM   in reply to nullifidian
    We may face this issue if any third party PDF printers (Any printers apart from Adobe) are installed as well, try removing them all and check.
    If you do not have any third party PDF printers installed try following the below steps.
    1. Click on Start > type Services.msc and open the Services window.
         In the Services window choose to Start the " Printer Spooler"  service, if it is already started choose to restart it and then try printing.
        If you still face the same issue, follow Step 2.
    2. Check if the application is updated, if not launch the application and then click on Help > Check for Updates.
    3. If Step 2 does not help re-install the application.
    Sep 30, 2012 8:13 AM   in reply to lesyeux
    Thanks, lesyeux - unchecking that option finally fixed the prob.
    For german users:
    Bearbeiten -> Voreinstellungen -> Allgemein -> Geschützten Modus beim Start aktivieren -> ausschalten
    Adobe Reader X 10.1.4
    Feb 26, 2013 4:50 PM   in reply to nullifidian
    I solved this issue by installing NitroPDF reader.  I don't have a clue why installing another PDF reader would fix it Adobe Acrobat X, but it did.  Oh, and I didn't un-install X either.  Good luck young Padawan.
    Apr 3, 2013 8:06 AM   in reply to nullifidian
    I recently upgraded to Adobe Reader 11.0 and had similar issue.
    I solved it by doing the following
    Edit -> Preferences-> Documents -> View Documents in PDF/A mode ........Make it as "Never"
    Restart your adobe reader and now you should be able to print.
    Apr 3, 2013 10:10 AM   in reply to nullifidian
    A temporary fix for this problem:
    1. email yourself the document.
    2. Click view.
    3. Enter in the information.
    4. Right click and print.
    5. Clicking change under destination. (Google Chrome)
    6. Select PDF.
    7. Save the document.
    This is a problem with permissions and is very common.
    Hope this helped.
Actions
