Hi all
I also get the following:
Try to print and this message appears " Document could not be printed". I have tried saving and reopening in Reader 9.1, also printing to file and printing as an image.
Nothing works. I think the two issues are connected
I have tried to print docs that have previuosly been printed, the same problem i.e.:
Hi all
An update. I have two machines a desktop PC (XP) connected by USB and a laptop (Vista) that is printer accessed by wired networking (802.11b/g (Wi-Fi)).
The Adobe software on the desktop is the latest
The Adobe software on the laptop is not quite up to date.
I can print from the laptop.
So it seems the issue is with the latest Adobe upgrade.
Would there be any opinions on this or will an upgrade be released soon?
GM
I also have the same problem. I have Adobe Reader 9.3 on Mac with Snow Loepard. Every PDF document that I try to print on a network printer (and I tried two printers so far) I get the following errors in sequence:
"The document could not be printed."
and then
"There were no pages selected to print."
I removed Adobe Reader completely (deleting all the related files anywhere on my machine using 'find' command) and installed it again, the same problem. I can print PDFs using the OS X's Preview application on the same printers just fine.
I also tried printing on a publicly available printer on a totally different network (outside of our organization) and I still got the exact same errors.
Any updates on this?
Roozbeh
This same problem is happening with me. It just started today after I upgraded Illustrator to CS4. I save the .ai file as a PDF and try to print from Acrobat 9 Pro.
I get the "The document could not be printed" then "There were no pages selected to print". The only workaround I've found is to print to a postscript file, then Distill to a PDF. Then it prints fine but it's a time consuming PITA. Somebody suggested it was a Acrobat Reader issue. It seems maybe not.
Have same errors and it drove me crazy. I know it's not the printer because I can print other documents as long as it's not PDF. On the Add-Remove programs, Adobe Reader 9 has no option to remove so I re-installed the 9.0 but the problem did not go away. I tried doing System restore to dates prior to the time I got the errors but problem remains. I was tempted to install FOXIT reader but it seems that it comes with a toolbar. Finally, I installed Adobe Reader 9.3 and it worked
. Try it.
I upgraded Vista Business 64 to Windows 7 Prof 64 just because
I could not print any pdf.
The problem is the same as others wrote "Document could not be printed".
I can print from other applications (word, firefox, etc.), so the printer works fine.
The printer driver was downloded directly from the printer vendor's site for Win 7 64.
I cannot even print with Foxit reader !
I tried to uninstall Acrobat reader 9, and install 8.1.3, 8.1.2, but none of them
can print pdf files.
Now I have Acrobat Reader 9.3 installed and I still cannot print ANY PDF files, with
ANY application (Acrobat, Foxit)
Same problem, and despite the misleading error message it does seem to be related to the network printer connection. In the Printers and Faxes panel, the printer is shown as "Unable to connect." Apparently our network people retired an older print server this morning, and forgot to send out a notification.
I think it is because the PDF files is proteced from being printed. It is common that online PDF files allows you view but not copy or print. Try to check out the properties of the file. If you can download the file, you may print it after unlocking using
PDF Password Remover. Just a possible situation.
The best thing I did was to uninstall Adobe ad now use the Freeware available from Foxit to everything Go to www.foxitsoftware.com and download the pdf reader First button below the 'Help Me Choose button'. Its free (from hassle and bugs and glitches. You might also look at openoffice.org a complete suite to hold-up against Microsoft Office its shareware/freeware constructed by us mere mortals and improved upon by us because Sun Micro Systems actually listen to their consumers. It feels like myPC has been to a rehab facility so unencumbered without Microsoft Office around its neck```````````````````
Im having a similar issue with PDF's that are created by one of our automated systems. Only the Acrobat 9 station has this issue printing pdf files any previous version is ok. I updated acrobat and let the user test on it for a day with no success. I have reinstalled the software and reinstalled all of the updates and it still throws this error. The user prints to 2 network printers in her dept. The printers are not the issue because everything else on her pc prints to them just fine as does the other 20 or so people in there.
What i did find though was that when we copied the pdf from the storage system to the users desktop we are now able to print the pdfs with no problems. From what i can tell our install of Acrobat 9.3.1 has issues with accessing the pdf via the network to print it.
This is an acceptable band-aid for us but i hope that Adobe hurries up and fixes these issues cause its really annoying, especially to a large print shop like where i work at.
Just thought i would throw out my findings and hope that it may help others having the same issues!
This is infuriating:
Me: I need to fill out this PDF form...
Some time later: All done! Time to print!
Adobe Reader: The document could not be printed.
Me: What a cryptic and unhelpful message! I'll try printing as an image.
Me: Huh. I'll try printing to a pdf, then open that file in Preview and print from there.
Adobe Reader: Saving a PDF file when printing is not supported. Instead, choose File > Save.
Me: Sounds good. I'll do that.
Adobe Reader: Data typed into this form will not be saved. Adobe Reader can only save a blank copy of this form.
Me: At a loss for words.
I will be avoiding anything with the name Adobe on it for the foreseeable future.
It is April 15th 2010. Adobe Reader is not working anymore for Mac OS X 10.5.8.I can print pdf files, just with a lp command from a terminal, from the Preview software (Apple original default pdf viewer) and with Skim (a free PDF reader).
The problem is with Adobe Reader, as it has been extensively reported.
I add the letter I tried to submit to help desk.
Ladies and Gentlemen at Adobe.
How are we supposed to have a relationship when you guys are so aloof and unresponsive to the little people out here? Have any of you bothered to read the forums? Why has there been such a poor response from you regarding the issue of A R 9.x and pdf printing? The only thing is a DIY Trouble shooter which a). is time consuming considering most folk that are at the troubleshooting stage are already hot under the collar and b). rather short in the fix department. The only viable solution I have seen on the forums so far that has any merit is uninstalling A R and substituting it with Foxit's Reader. (Nice one! Thats how you woo customers and grow your market share especially in this current ecoclimate!). I know that this message will be read by the guys who are not directly linked to The issues in Reader because I had to use this portal as there is no other way to get a response from the Reader Guys. So.... Please, to YOU reading this get it to the right people and even if its only in the Breakroom, mention to somebody who can, that there are a whole lot of people (not just those who are competent enough to get to a forum to look for help) who are having printer problems that did NOT exist prior to upgrading to A R v9.x and get them to go to the various forums and read whats going on and respond - Please,- even if its to say that there is no solution just show that you know.
Thanking you in advance,
Andrew
Normally one very satisfied Adobe Customer.
PS I have copied this message and posted to the forums applicable.
Update version 9.3.2 is now available. Try that. http://www.adobe.com/downloads/updates/
I downloaded Acrobat Adobe Reader 9.3
The only download available for Mac OS X 10.5.8.
It does not work out of the box. Just doesn't print (I am able to print from any other program, same machine, same printer, same drivers)
I spent more than 2 hours trying to update the Adobe Acrobat Reader version 9.3
No Way! It gives an error (already reported in this forum for version 9.2).
The update could not be completed saying that the AAReader was modified since installation...
I re-installed, without luck.
I am fed up.
I have a AA Reader installed and working in several Linux machines and MSWindows machines.
With my Mac, I have no luck. I won't waste any more time in a lousy coded program.
I will stop using AA Reader in my Mac and post my (and lot of more users' ) problem in every forum I am part of.
thanks for the intended help.
The Adobe Company is silent not giving any support to Apple's users. Is it part of the battle that Apple and Adobe are having in other levels?
My problems started after installing Flash Player 10 on a PC running Windows 7 and reader 9.3, direct USB printer.
Generally older PDFs print OK but some newer ones crash Windows print spooler.
If I take the files to a machine running XP, Reader 8 and an older flash player they print OK.
I uninstalled Reader 9.3 and installed Reader 8 but the problem did not go away. I also removed Flash Player but still the same.
If I look in the print spooler I see two files for each print task. One is a .SHD file of about 2K and the other is a .SPL of about 100K per page. This is described by Windows as a Shockwave Flash Object.
To get the printer to work I have to delete the contents of the Spool folder and re-start the print spooler.
Any ideas please?
I just printed using Reader 9.3.2 with NO problem. My OS10.6.3 (Snow Leopard) Macbook Pro 2.16gHz, Brother MFC-7340 printer.
Suggestions:
1. Remove Reader (trash), download and reinstall. Be sure you have the right version for your Mac i.e, Intel or PowerPC.
2. Be sure you have the latest printer drivers from your printer manufacturer.
3. Repair permissions with Disk Utility or shareware Onyx.
4. Safeboot (hold shift key down while restarting).
5. Restart the normal way (without holding shift key).
These routine maintenace actions may help.![]()
I had already tried most of the recomendations. Just in case I dwonloaded the latest install for the Adobe Reader but still the same.
As I said previously there is only a problem with more recent PDF's. To be more specific I receive orders and enquiries as scans and documents converted to PDF's from some of the worlds major oil companies and it is ONLY those created within the last three weeks that have caused problems. I would like to attach one but I am not allowed.
My problem has been fixed by installing Foxit but now I have the problem that I cannot uninstall Adobe because some of the files are in use by the Windows system.
I hate Windows 7
Thank you so much to those of you who suggested downloading the Foxit reader. After wasting most of the day uninstalling, reinstalling, fixing this that and the other thing and not being able to print after upgrading to AR 9.3, in 10 minutes Foxit was installed and printed like a charm.
I was trying to print a form from the IRS website. I had done this many times before without a problem. I knew there was nothing wrong with my printer, drivers, computer or anything else.
Thanks again.
A permanent and definite fix for this issue, we can Re-create the Acrobat preferences files and this will definately resolve this issue.
For Mac:
For Windows:
While reading several kb articles, I found none of them to be helpful.
Especially this one: http://kb2.adobe.com/cps/403/kb403914.html
They make things way to complicated. In our case, we noticed that Standard 9 was saving documents so that when the print option was select the default option selected for Comments and Forms was, "Documents and Markups." Simply changing this setting to "Documents," as with all previous version of Adobe resolved our printing printing problems. Hope this is helpful for all of banging your head against the wall like we were. -Hunter
Having tried a couple of the suggestions here (reinstalling, repairing and using foxit)
I was able to get around the problem by going to my "advanced" settings when I selected "print".
(Your printer driver may not have this option.)
Under this setting, I have the option to print as "image".
This works. Quality isn't thrilling, but in a pinch it may be adequate.
Please note that I also have to return to the print settings and turn this option off when I'm done printing. I don't want this as a default for quality reasons.
Good luck!
Same problem with Vista not printing pdf. installed Foxit Reader from foxitsoftware.com which open pdfs and prints without any prolbems. Interesting Adobe are not saying anything about this problem. Similar error reported http://forums.adobe.com/thread/642000?tstart=1
I had this intensely annoying issue with saving AI files as PDF's. Nothing would print from Acrobat!!! After a few hours of trying everything... I FIXED IT w/o reinstalling anything!
It seems to be a font issue. I went through and expanded every instance of every font to a vector object until it worked. I eventually narrowed my particular issue to the font 'Didot'.
THE SOLUTION (for illustrator CS4 to pdf):
Remove, rasterize or expand all instances of every different font until it works...
There may be a way of handling embedded fonts that is more elegant...
My setup:
Mac Pro 2006, OS X 10.5.8, CS4. The font Didot was stored in "Library/Fonts/Didot.dfont" - maybe it's the ".dfont" extension?
Cheers,
Dan
www.ilove4d.com
All,
This problem is typically caused to another piece of software being installed that has some kind of PDF functionality. Internet Explorer starts looking for DLLs that it cannot find, and generates the error. The best method for fixing this problem is to copy some of the Adobe Reader's DLLs into and Internet Explorer directory. Below is what I use in a batch file to fix the problem with Adobe Reader 9 on Windows XP:
REM HOT FIX FOR IE and adobe
copy /y "%PROGRAMFILES%\Adobe\Reader 9.0\Reader\ACE.dll" "%PROGRAMFILES%\Internet Explorer\ACE.dll"
copy /y "%PROGRAMFILES%\Adobe\Reader 9.0\Reader\AGM.dll" "%PROGRAMFILES%\Internet Explorer\AGM.dll"
copy /y "%PROGRAMFILES%\Adobe\Reader 9.0\Reader\BIB.dll" "%PROGRAMFILES%\Internet Explorer\BIB.dll"
copy /y "%PROGRAMFILES%\Adobe\Reader 9.0\Reader\BIBUTILS.dll" "%PROGRAMFILES%\Internet Explorer\BIBUTILS.dll"
copy /y "%PROGRAMFILES%\Adobe\Reader 9.0\Reader\JP2KLIB.dll" "%PROGRAMFILES%\Internet Explorer\JP2KLIB.dll"
The above may not display correctly in the forum, so note that each line of your batch file should start with copy and end with dll".
Hope this helps you all. It took much testing to get this figured out. As I'm sure everyone has found, it is next to impossible to find the fix for this. As a side note, we have tested this same solutions with other versions of Adobe Reader and Windows, so modify the above to suit you needs.
Good luck!
Tod
North America
Asia Pacific
