Document could not be printed
Jul 16, 2009 10:27 PM
  Latest reply: altekro.com, Apr 3, 2013 10:10 AM
Replies 1 2 3 4 Previous Next
    Apr 28, 2010 1:40 PM   in reply to R.P Singh
    Hi
    Mines OK now, just don't know what I did.
    Gary
    Jun 1, 2010 4:24 AM   in reply to Gary Mea
    Same problem with Vista not printing pdf.   installed Foxit Reader from foxitsoftware.com which open pdfs and prints without any prolbems.  Interesting Adobe are not saying anything about this problem.  Similar error reported http://forums.adobe.com/thread/642000?tstart=1
    Jun 3, 2010 4:47 AM   in reply to Gary Mea
    Im very happy you goy iy together!. hope this alos me to donw load flas point 10.
    Jun 15, 2010 10:08 PM   in reply to nullifidian
    I had this intensely annoying issue with saving AI files as PDF's.  Nothing would print from Acrobat!!!  After a few hours of trying everything... I FIXED IT w/o reinstalling anything!
    It seems to be a font issue.  I went through and expanded every instance of every font to a vector object until it worked.  I eventually narrowed my particular issue to the font 'Didot'.
    THE SOLUTION (for illustrator CS4 to pdf):
    Remove, rasterize or expand all instances of every different font until it works...
    There may be a way of handling embedded fonts that is more elegant...
    My setup:
    Mac Pro 2006, OS X 10.5.8, CS4.  The font Didot was stored in "Library/Fonts/Didot.dfont"  - maybe it's the ".dfont" extension?
    Cheers,
    Dan
    www.ilove4d.com
    Aug 27, 2010 9:31 AM   in reply to nullifidian
    All,
    This problem is typically caused to another piece of software being installed that has some kind of PDF functionality.  Internet Explorer starts looking for DLLs that it cannot find, and generates the error.  The best method for fixing this problem is to copy some of the Adobe Reader's DLLs into and Internet Explorer directory.  Below is what I use in a batch file to fix the problem with Adobe Reader 9 on Windows XP:
    REM HOT FIX FOR IE and adobe
    copy /y "%PROGRAMFILES%\Adobe\Reader 9.0\Reader\ACE.dll" "%PROGRAMFILES%\Internet Explorer\ACE.dll"
    copy /y "%PROGRAMFILES%\Adobe\Reader 9.0\Reader\AGM.dll" "%PROGRAMFILES%\Internet Explorer\AGM.dll"
    copy /y "%PROGRAMFILES%\Adobe\Reader 9.0\Reader\BIB.dll" "%PROGRAMFILES%\Internet Explorer\BIB.dll"
    copy /y "%PROGRAMFILES%\Adobe\Reader 9.0\Reader\BIBUTILS.dll" "%PROGRAMFILES%\Internet Explorer\BIBUTILS.dll"
    copy /y "%PROGRAMFILES%\Adobe\Reader 9.0\Reader\JP2KLIB.dll" "%PROGRAMFILES%\Internet Explorer\JP2KLIB.dll"
    The above may not display correctly in the forum, so note that each line of your batch file should start with copy and end with dll".
    Hope this helps you all.  It took much testing to get this figured out.  As I'm sure everyone has found, it is next to impossible to find the fix for this.  As a side note, we have tested this same solutions with other versions of Adobe Reader and Windows, so modify the above to suit you needs.
    Good luck!
    Tod
    Sep 7, 2010 11:50 AM   in reply to T_Ashby
    I just started having this problem in 10.6.4 on a Mac Pro and CS5 Design Premium version of Acrobat Pro.
    My only solution appears to be "print using Apple Preview."
    Great marketing, guys. Really top-notch.
    Preview worked, though. It never occurred to me to use it as a PDF printer. Quality seems slightly worse, but what can you do? Slightly soft text and images are better than blank sheets of paper.
    Sep 13, 2010 5:59 AM   in reply to Ben Frey
    I tried all the solutions in this post and still NO JOY! What's next? When will Adobe
    be coming out with Adobe reader 10.0 to finally acknowledge and fix the problem?
    Sep 13, 2010 2:04 PM   in reply to nullifidian
    Hello, I ran into the same issue with a client I was helping.
    Upon clicking print in Acrobat 9 pro, the print dialog goes away and I get two errors:
    The Document could not be printed.
    and
    There were no pages selected to print.
    no errors in console were produced.
    The work arround I found was to select "advanced" in the print window and then check "Print As Image."  I found as long as that box was checked the trouble document could print.
    First I tried removing/reinstalling CS4, repairing premisisons, and reloading print drivers with no success. I also tried it on two seperate macs running differnet OS versions (10.5.8 and 10.6.4) as well as differend minor versions of Acrobat 9 pro (9.3.4 and 9.0.0.). The problem/solution were reproducable on both machines.
    I also found that Preview.app had no probem printing any of the trouble documents.
    Hope this Helps!
    Sep 13, 2010 4:04 PM   in reply to Sonic8400
    I cannot print ANY pdf document using Adobe Reader and I always get the two errors:
    "The document could not be printed."
    "There were no pages selected to print."
    Preview.app prints the documents just fine.
    I think it is silly, and interesting to observe that Adobe doesn't say anything about it.
    R.
    Sep 14, 2010 10:21 PM   in reply to roozbehf
    can you provide the exact steps that you are following?
    Sep 14, 2010 10:28 PM   in reply to DrPhilH
    Ok, you will never be able to print pdfs using adobe reader, because adobe reader is just to read the pdfs, you need acrobat to print the pdfs, there will b no use of waiting for reader 10 even it will also not print, you can download acrobat trial (30 days) and then try printing pdfs.
    Sep 14, 2010 11:06 PM   in reply to R.P Singh
    Seriously R.P.?! Are you an Adobe rep?
    Then why Adobe website says otherwise for Adobe Reader 9?
    "Adobe Reader software is the global standard for electronic document  sharing. It is the only PDF file viewer that can open and interact  with  all PDF documents. Use Adobe Reader to view, search, digitally sign,  verify, print, and collaborate on Adobe PDF        files."
    - http://www.adobe.com/products/reader/
    and why are there so many support pages on Adobe website about Problems Printing Documents from Adobe Reader?!
    Why Adobe doesn't come clean and say you can't print from Reader?
    E.g.,
    - Printing Tips
      http://www.adobe.com/support/reader/
      http://kb2.adobe.com/cps/332/332720.html
    - Printing Problems, Adobe Reader
      http://kb2.adobe.com/cps/315/315727.html#main_Can%27t%20print%20any%20 PDF%20file
    Sep 14, 2010 11:44 PM   in reply to roozbehf
    Ok are you printing a microsoft document into pdf or you are taking physical printout from a printer?
    Sep 15, 2010 12:01 AM   in reply to R.P Singh
    I am trying to print a PDF document on a physical printer.
    As I mentioned, regardless of the PDF document I open, and printer I choose (inkjet or laserjet), it fails.
    I can easily print using any other application. I can print the same PDF document using Mac OS's Preview.
    Sep 15, 2010 12:38 AM   in reply to roozbehf
    try printing with acrobat trial
    Sep 15, 2010 2:36 AM   in reply to R.P Singh
      Hi all
    No probs at all now for some while.
    Sep 15, 2010 3:46 AM   in reply to R.P Singh
    What next? I attempted to print from Adobe Acrobat Standard edition. I tried with Foxit, PDF Complete. Again, NO JOY! I think what is going on here is that when Acrobat creates the file, it's corrupt and the reason that Adobe doesn't want to admit to the problem is it will set up a MAJOR public relations problem and confidence problem in their product. So rather than do the right thing, Adobe chooses to ignore the problem, and either fix it behind the scene and have a lot of pissed off people, or they just have no clue.
    Time to step up to the plate and approach the problem head on and fix it!
    Sep 15, 2010 6:55 AM   in reply to R.P Singh
    You must be a troll, right?
    You can't be serious.
    Read this thread. People with Acrobat Reader AND people with Acrobat Professional have this problem.
    People with Mac OS and Win XP and Win Vista and Win7 have this problem.
    People with Acrobat 8 and Acrobat 9.
    People with nose rings and people with bleached hair.
    Those on OS X can print the same documents without issue from the built-in free OS X "Preview" application on the same machine that cannot print them from Adobe Acrobat Professional 9.3
    So printing with an Acrobat trial version won't change that.
    Adobe has a problem here. It's probably font related somehow, because printing "as an image" works, but of course that rasterizes all of the type, making it a poor solution, especially for professionals with clients that have expectations of quality work.
    It's sad and embarrassing that a college kid with an old MacBook could come into my office and print a PDF with Preview I created on my brand new Mac Pro but that I cannot print using Acrobat Professional.
    I did not pay over 2,000 dollars for software that can't even print it's own native file format. Well, actually, I did.
    But I won't make that mistake ever again.
    Sep 15, 2010 10:09 AM   in reply to Ben Frey
    Ben,
    On my machine, this happens even when I check the "Print as image" check box.
    Here I put a summary of the problem for people who don't have the time to read all the posts.
    In Summary:
    On Mac OS X, having Adobe Reader 9.3, when I try to print a PDF document on a printer I get the following errors:
    and then,
    This happens,
    • with ANY pdf document that I open, whether they are created with Adobe products or other applications;
    • with any selection of pages (all, current page, or a range of pages);
    • regardless of having the "Print as image" checkbox checked or unchecked;
    • on different printers (inkjet or laserjet, Lexmark and Epson);
    • on older versions of Adobe Reader 9 as well (I haven't tried it on Adobe Reader 8.x);
    The same documents can be printed using the Preview application on Mac OS X.
    Different people experience a subset of this problem, but the fact that I cannot print regardless of the document, the print as image option, the printer type or the page selection tells me that the problem is not related to these. This is a nasty bug and may have something to do with some Adobe settings being messed up. Since there is practically no way to completely uninstall Adobe on a Mac (Thank You Adobe for being so careless) I cannot tell whether a clean install would solve this issue. I tried removing every footprint of Adobe from my machine two times (from system files, property lists, etc) and installing the reader again, but the problem still exists.
    I hope this helps. Does anyone from Adobe care about this?
    Sep 20, 2010 8:58 AM   in reply to nullifidian
    Question to you all. Did you try registering your Adobe product?
    Remember that little message that appeared after you first ran the Reader after install, telling you to Regsiter your Adobe software. Well if you kept clicking the remind me later then you will notice that some features will stop working until you register.
    I was havng this same error today with Adobe Acrobat Pro, till I remember that small quirk that would occur whenever I don't register Adobe products.
    Sep 20, 2010 9:11 AM   in reply to Ms-Hilton
    Nope, make sure the product is registered didn't make a difference. Nice try by Adobe to make sure there is no bootleg users out there
    Sep 20, 2010 9:29 AM   in reply to DrPhilH
    Hi
    Have not registered Adobe Reader, it all works now.
    Oct 6, 2010 3:02 PM   in reply to nullifidian
    I might have just found the source of the problem. Read this:
    http://forums.adobe.com/thread/392791
    It says:
    We have been running all our Macs for years with a case sensitive file system which is one of the options on the Mac OS X installer. All our applications work fine except Adobe Reader. I have asked and complained to Adobe for a year or two. Whenever we try to print it just says that "Adobe Reader cannot print this document". We would use Preview but we use forms and digital signatures that Preview can't handle. We end up having to copy all our PDF files to a Windows system to print. This is pathetic, especially from Adobe.
    I have a case-sensitive file system. Can all of you who have this printing problem confirm if they have a case-sensitive file system as well?
    Roozbeh
    Oct 7, 2010 6:55 AM   in reply to roozbehf
    Unfortunately, that's not going to be it for me, because I do not have "case sensitive" formatting on any of my drives.
    Good thought, though.
    Oct 14, 2010 10:34 AM   in reply to nullifidian
    Another possible Solution...Windows 7 people.
    I just had this error pop-up on my PC and my IT (who is genious) was able to quickly fix error by restarting the Print Spooler. Instantanious fix.
    Didn't have to download anything didn't have to restart anything (except the spooler).
    I guess this is a common issue with Windows 7.
    Oct 14, 2010 12:53 PM   in reply to tcfiles1
    The print spooler issue is a whole other can of worms. That was a Win7 issue in general. I figured out the fix on that myself. Nothing to do with the Adobe problem
    Oct 15, 2010 1:29 AM   in reply to roozbehf
    I have just hit this problem printing tickets purchased from Eurostar.
    If you accept the option to print your tickets at home Eurostar deliver them as a PDF.
    When I try to print them on my Mac (Snow Leopard, Acrobat Pro 9.4.0), I receive the same two error messages reported above
    and
    followed by
    "A drawing error occured"
    These tickets print fine with Preview, and I can print other PDF files with Acrobat OK.
    These tickets also print fine with Acrobat Reader 9 on Windows 7.
    It looks as though there is some problem with the Eurostar-generated PDFs.
    Possibly an error in the generated PDF which Preview and the Windows version of Acrobat Reader tolerate, but which Acrobat Pro on the Mac can't handle.
    How can I determine whether this is a bug in Acrobat Pro (Mac version) or whether the Eurostar-generated PDF is in error?
    The document properties show
    PDF producer: iText 2.0.7 by Iowagie.com
    Application: JasperReports
    Message was edited by: digamma, to correct a typo
    Oct 25, 2010 3:26 PM   in reply to sanjaysh
    I am having the exact same issue.  "Document could not be printed", then the error "There were
    I selected 9 pages to print, but none of them will print.  This is from a PDF I created/exported myself from a Visio 2006 document.
    Interesting... since the only reason I buy Acrobat Pro is so I can PRINT.  :\
    Oct 26, 2010 10:56 AM   in reply to nullifidian
    Hello!
    I have been reading the thread here and I have these same problems since July. We got an update to our loan origination system which included the 9.3.3 reader.  Ever since that update nothing has been right.  I have deleted and reinstalled everything from 8.2 to 9.4.  We have installed memory and checked the drivers on our printer.  Nothing seems to help.  When I try to print, I get a blank page.  Other people get the error messages. I don't know what else to do.  Any one have any ideas?
    Thanks!
    Lisa
    Nov 9, 2010 8:29 AM   in reply to nullifidian
    One possible workaround: Print the pdf to xps using a Microsoft Document XPS printer, then open the xps file with IE and print it from there. This worked for me.
    Nov 24, 2010 11:32 AM   in reply to nullifidian
    I had this problem with a document I created in Word 2010, then imported into Acrobat Pro X to make into a form.
    I couldn't print it in Acrobat Pro X or Acrobat reader 9.  I would get the errors:
    "The document could not be printed" then "There were no pages selected to print".
    Since i created the document, I was able to take it apart and remove items until it printed correctly which it eventually did.
    What had happened was that I had added some new text in Acrobat Pro, all other text was imported from the original Word document .
    This new text created in Acrobat was causing the error.  Once I deleted this, it printed fine. I had to reimport 1 page form Word with the edits made in that file to make my final document.
    - If you didn't create the original document, this is of no help to you unfortunately.
    - Printing to a .xps was not a workaround for me as the error occurred there also.
    Nov 27, 2010 6:05 PM   in reply to larpeck
    I have Windows XP Professional and have been getting the same two error messages, The Document cannot be printed, and There were no pages selected to print.
    I was going to try to register with Adobe to see if that would work. I went to Start-All Programs-Adobe Reader 9.
    When I did that a small installation dialog box opened saying Installing Adobe Reader 9. It just took a few seconds then the blank PDF page opened up. I selected the document I had been wanting to print and clicked on the printer icon. It printed perfectly! I just tried printing another document which I was unable to print before and it too just printed.
    Hope it stays fixed! Give it a try and good luck.
    Dec 14, 2010 11:57 AM   in reply to R.P Singh
    So far so good!  Your instructions have worked for my iMac 10.6.5 running Acrobat Professional 8.2.5.  I never had trouble with Reader.
    Thanks!
    Dec 31, 2010 10:20 AM   in reply to nullifidian
    I removed Adobe and while reading through the posts downloaded and then reinstalled the latest reader, Adobe Reader X (http://get.adobe.com/reader/).
    I am using Windows 7. It is working fine now.
    Jan 12, 2011 9:15 AM   in reply to nullifidian
    We had the same problem here ("The Document could not be printed" and "No pages selected to print").
    I could replicate the problem only when printing to the network printer.  Printing to my local printer worked fine, which pointed to an issue communicating with the print driver.
    Our solution (or workaround) is to use a different print driver.  This is a solution we've used for a variety of printing issues over the years.  We had the same issue with Toshiba printers before, and now with Xerox printers:  Simply add a second version of the printer out there, share it with a name like Generic_Driver or something.  This will point to the same physical network printer, but instead of using the default Postscript driver, go into the printer properties and change the driver to a generic driver like the HP LaserJet 4.  At least in our case, many if not most PDFs print just fine using the default print driver, but it's a heck of a lot easier to troubleshoot printing problems if you've got an alternate print driver ready to go.  The problem will very often come down to an incompatibility between the software and the PS driver.
    Jan 12, 2011 10:46 AM   in reply to nullifidian
    Hi all,
    I too am having the same problem - on only one computer in my office of 20 or so computers.
    When I attempt to print a document, I get the now infamous error "Document could not be printed" error in reader. Can still print from any other program, but need to use Adobe Reader. I tried it on both versions 9 and now Adobe Reader X, with the same results.
    I am running XP Pro completely updated. I have attempted the following:
    1.) In the print option, click "advanced" then select to print as image. Still can't print
    2.) Save the document onto the computer, open and tried to print. Doesn't work.
    3.) Uninstall completely everything with Adobe on it, and reinstalled. Still no go.
    The computer prints through another PC that has the printer shared. This setup is the same throughout my office, with no problems for other computers.
    Any help would be much appreciated, and I will update if I find anything out.
    Richard
    Jan 19, 2011 7:53 PM   in reply to R.P Singh
    I can't believe Adobe hasn't done something about what seems a widespread problem across several platforms and Adobe products. I just started have this problem and have tried several of the solutions offered here:
    making sure I was registerd & repair didn't work nor did eliminating the Preferenes folder. Printing as image DID work but not a great solution.
    I am running Acrobat Pro 9.x on Windows 7 x64. The problem only started recently and seemed to occur only with documents of multi-layers of data (ArcGIS export to PDF maps). Other documents printed fine. It seemed to be a problem of incompatible fonts, but I don't know for sure, only that several of the documents gave me an error message on open that some of the fonts may not print correctly. I'm on a network printer, burt also tried to print with a direct USB connection from my computer. Same errors ("could not pint -- Drawing error occured).
    I don't know which is more irritating, the problem (though solved by print as image) or Adobe not respoinding to such a long-running thread.
    Grrrrrrrr.
    Has anyone started a ticket on this?
    George
    Jan 22, 2011 7:45 AM   in reply to Validator
    this is my problem too -- did you fix it?
    Jan 24, 2011 3:36 AM   in reply to thecornerangel
    Have not fixed it. what I do to get around it is when the document is displayed, I print
    it as a picture. Terrible that adobe can't fix it.
    Jan 25, 2011 5:20 PM   in reply to DrPhilH
    Here's more bad news: I just ugraded to Acrobat 10/windows and GET THE EXACT SAME PROBLEM! Auuuuggghhhh! Got a call-back to tech support right now. Will keep people advised on a solution, if any.
    Update: sitting here waiting for them to call back and fiddling. I opened the layers table of contents and turned off one layer (a text layer surrounding a map). That allowed the document to print, so at least I've isolated the problem. Also, it's a multi-page document generated by a Data Drive Pages export from ArcGIS. I still think it's related to some font not translating well. I also tried to "flatten layers" but it's either hung up doing so or just akes forever -- I let it run 25 minutes before ending the program.
    More news as it occurs... .
    George
Actions
