Shrinking text on spiral path
Jul 20, 2009 10:27 AM
Using CS4 and I need to make the text look like it is going down a drain. Google returned some results for older versions that had a script to do this but with everything Adobe the script faded away.
I have the text on a spiral path, but how do I get the outer text to look bigger and the inner text to look smaller?
    Jul 20, 2009 2:58 PM   in reply to darkhelmet1234
    The only way i can think of is to put the text on a spiral path and resize the letters on at a time.
    Jul 20, 2009 3:47 PM   in reply to Wade_Zimmerman
    Here's a hacked up version of another script that was posted a month or so ago. You can play with the starting size and the amount of decrease by changing the numbers.
    // change size of paragraph text
    //$.bp();
    ChangeSize();
    function ChangeSize()
        selectedItems = selection;
        // check to make sure something is selected.
        if (selectedItems.length == 0)
            alert("Nothing is selected");
            return;
        endIndex = selectedItems.length;
        for (index = 0; index < endIndex; index++)
            pageObject = selectedItems[index];
            pageItemType = pageObject.typename;
            if (pageItemType == "TextFrame")
                // get the paragraphs from the selection.
                theTextRange = pageObject.textRange;
                paraTextRange = theTextRange.paragraphs;
                numParagraphs = paraTextRange.length;
                for (i = 0 ; i < numParagraphs ; i++)
                    aParagraph = paraTextRange[i];
                    charTextRange = aParagraph.characters;
                    charCount = charTextRange.length;
                    if (charCount > 1)
                        end = charCount;
                        fontSizeChanger = 14/end;
                        currentFontSize = 18;
                        for (j = 0 ; j < end; j++)
                            theChar = charTextRange[j];
                            theChar.size = currentFontSize;
                            currentFontSize = currentFontSize - fontSizeChanger;
    You might check here for  simplier version
    http://forums.adobe.com/message/2037393#2037393
    Jul 20, 2009 6:21 PM   in reply to darkhelmet1234
    put your text on a straight path and convert to outlines - use the free distort tool to taper the text or use a tapered rectangle (what are they called? Truncated triangle?) as a shape to define a warp. Drop your tapered text into the brushes palette and make it an art brush - draw the required spiral shape and stroke it with your brush. You can scale the brush to fit your spiral in the art brush dialogue. You may also have to reverse the direction of the brush to get the thick end outer-most.
    Jul 20, 2009 8:40 PM   in reply to RogerPaine
    Very Excellent and elegant, there is your answer.
    Jul 20, 2009 9:47 PM   in reply to Wade_Zimmerman
    P.S. You don't need to make the text outlines - that doesn't mean that it is editable though because it is automatically converted to outlines when you drop it on the brushes pallet
    Jul 20, 2009 10:59 PM   in reply to RogerPaine
    No way to do it keeping the text editable, i suppose?
    Jul 20, 2009 11:02 PM   in reply to JayJhabrix
    That was what I was trying to do.
    Jul 20, 2009 11:15 PM   in reply to Wade_Zimmerman
    I know... was just wondering if there was a quick fix...
    Jul 21, 2009 6:39 AM   in reply to JayJhabrix
    Yeah it would be good to be able o do all this kind of text stuff with
    a text effects tool.
    Jul 21, 2009 9:05 AM   in reply to Wade_Zimmerman
    The text generated by the script is fully editable.
    Jul 21, 2009 10:17 AM   in reply to darkhelmet1234
    OP must also decide what kind of effect is desired. Distort transforms will, predictably, distort each character. Scripts that vary text size will not distort individual characters. The effects are the not the same.
    See previous discussion: http://forums.adobe.com/message/1275493#1275493.
