I've read up a lot on the following problem elsewhere, but wanted to come straight here after not having a lot of luck.
I have .ts files of 720p HD video that I captured from a motorola cable box with CapDVHS. They play just fine on my computer, no apparent problems anywhere, with audio or anything.
I've read up on muxing/demuxing and have tried countless variations of trying to import them into Premiere/Encore/AME after sending them through various programs and I have yet to completely succeed. USUALLY, the problem is that the audio begins to get out of sink over the course of the 2 hour file, maybe by a couple of seconds at the end(at the beginning it is fine), but other times AME has produced m2v files that cut out with 30 minutes to go and are just black video for the remainder and there are others.
So, what I want to know is, if you were me and you had my files and you wanted to import them into Premiere/Encore, etc. What would you do? What are your steps for success? Anyone have any experience with this type of file and Adobe software?
I'd like to be able to edit the video and produce Blu-rays from these files...
But I don't think handling video of all types is too much to ask.
If you want a bloated program that is highly unstable, full of bugs and leaves a 150+ GB footprint, no. Luckily Adobe chose not to go that route and kept to what they are supposed to be good in and even then there are bugs, instabilities and things to be improved.
It is utterly ridiculous to expect a 'pro' editor to be able to handle all kinds of consumer and non-suitable material. There is freeware/shareware for that.
When you go to the butcher for a nice steak, do you expect him to repair the soles of your shoes as well, since he uses cows in his trade? And do you expect him to also sell shoe laces?
A jack-of-all-trades is the last thing we are waiting for.
-Jeff
Nice simple workflow Jeff. Hope it gets the OP to editing the game films.
[Edit] PS for similar, with a client's wife's cooking show TV programs, I just hooked the DVR up to my A-D unit, and did a straight Capture using it's software to DV-AVI. These edited fine and the difference in the TV feed and the output DVD were very acceptable. No device control between the software and the DVR, but hey, with the remote in one hand and the mouse in the other, very little extra footage was Captured.
Hunt,
Thanks. It works on my .m2ts files when I know what the audio and video
codecs are. I hope it works on his .ts files. It's all going to depend
on what codec his capturing program used to create the .ts files.
The workflow is simple, but it will take a little bit of time in the
Quick Start guides and help files for DGAVCIndex and VirtualDub to get
the exact steps required in each program.
-Jeff
So it comes down to info about the source .ts file. Frame rate? Codec used (most likely H.264)? The log file (not the .dga file) created by DGAVCIndex should have some useful info about the frame rate and codec.
The frame rate reported in VirtualDub during export is the speed at which VDub is processing the video, not the intended or actual playback rate. But that's me only guessing at what you saw and where you saw it because you sort of glossed over that part.
-Jeff
Yes, I didn't assume that frame rate meant much, but I thought I'd mention it...Also perhaps of note, the final .avi plays at the same speed as it appears as it is encoding, if that helps at all.
Here is the info from the log:
Stream Type: Transport [188]
Profile: main@high
Frame Size: 1280x720
Display Size: 1280x720
Aspect Ratio: 16:9 [3]
Frame Rate: 59.940060 fps
Video Type: NTSC
Also, I deviated from your rules slightly I am using DGMPGDec because DGA wouldn't load my video and I figured it was because it was mpeg based...That may be completely wrong. So I then used "MPEG2Source" as my avisynth script...which also may be completely wrong...
Since the codec in the .ts file is MPEG2, you made a good choice (the
only choice!) switching to DGMPEGDec. The source statement in your
script is appropriate as well.
After you load the .avs script file into VirtualDub, go to File>File
Information and make sure the frame size, frame rate and number of
frames match what DGMPEGDec logged.
Instead of exporting to .avi right away, try just playing the file in
VirtualDub. Then, after you export, try playing it in WMP. How do
those frame rates compare?
-Jeff
The frame size and frame rate read the same, however I don't have a number of frames in my DGMPEGDC log...
And when I play the video in VirtualDub it plays fine...
Man, so many difficulties...I've been working on this for days (not 24 hours days) and I don't know how much more I can do it.
In the DGMPEGDec log file, the coded# and playback# represent the number
of frames.
Since it plays fine in VDub before you export, it is the export that is
likely messing things up. Here's what I do:
1. Go to the Video menu. Select Fast Recompress.
2. Got to the Video menu again. Select Compression.
3. In the dialog box that opens, select Lagarith from the codec list.
4. Click the Configure button. Do you have a multi-core processor?
If so, check Use Multithreading. In the Mode drop-down list,
select YUY2 and click OK. Click OK again.
5. Go to the File menu and choose Save As AVI...
You should be good to go.
This stuff is not easy. The encoding schemes, file structures, varying
decoder quality, application design and the occasional lame attempt at
copy protection all conspire against the end user. Most users aren't
pirating copyrighted material; they just want to buy or record one time
only, and then watch it when they want, on the device(s) that they
want. Unfortunately, taking HD material and converting to SD or smaller
involves lots of computing power, and for the most part, lots of
different computer programs. And there's lots of places in the workflow
to make errors that will be genuinely fatal to the end result.
-Jeff
I'm running out of ideas.
-Jeff
I would think that this FPS issue could be handled along the way in Jeff's suggested workflow. If not, and G-Spot will tell you what you are dealing with, I use a conversion program, DigitalMedia Converter, to go NTSC to PAL and PAL to NTSC a lot. On the files that I am given (all sorts of CODEC's), it has worked fine with Frame Rate conversions. It would be one more step, but might be worth it. Still, there has got to be a way to address this issue in the current workflow - IMHO.
Here is the screenshot.
The Uncompressed video played correctly, speed wise, but the colors were all negative (black was white, white was black).
I do find it interesting that the frame rate when encoding seems to signify what the final frame rate is. With the uncompressed it was around 60, which is the actual frame rate and it ended up smooth and other times it has varied and the slower it was, the slower the video turned out. (When reading 14 or so, it was very slow...)
GSpot indicates that VirtualDub created a proper Lagarith 720p60 .avi file. The error is in your playback chain. Whatever program or programs you are using to view the exported file, they are smurfing the playback.
Anything that could mess up DirectShow, like Codec packs for example, is the likely culprit.
For essentially bullet-proof playback, I use the KMPlayer here. Many folks use Media Player Classic. Windows Media Player is very susceptible to bad codecs and corrupted filters.
-Jeff
Well it appears that you are right. WMP was choppy, VLC wouldn't even play it, but after bringing it into premiere and rendering it (it had a yellow bar) it played smoothly...
Now I'll need to do the entire file to see if my audio matches up with it perfectly.
Another question, video and audio of this type, after this process (the .avi and .ac3 files), can they be brought directly into Encore to burn from (after transcoding) or is Premiere needed to export a more suitable file?
Thank you very much for all your help.
H.264 takes longer to transcode, but produces better quality than MPEG2
at similar bit rates. That's even more important when sports videos are
involved. As always, test a short segment and compare for yourself.
And if burning to BD, make sure to use an RE disc to avoid wasting a
blank disc.
-Jeff
I finally had success using the above methods, but now I have a new problem.
I now have some SD video, captured the same way, it is 544x480.
I tried using the same steps as I did for the HD video, but I have yet to succeed. The closest I got was a outputted DVD where the motion was really choppy - and had a somewhat "interlaced" look...
Is there an obvious reason why the HD process would not work for this SD, 4:3 video? Anyone know?
Also on a related topic, I had a file that mixed HD and SD and that seemed to really throw everything off. Is there something I should be doing to "normalize" this file or something, for example if the SD part was what I really cared about and didn't care what the HD looked like?
North America
Asia Pacific
