How to download Adobe connect recorded meeting?
Jul 28, 2009 1:36 AM
The recorded adobe connect can be seen by using the recording link. But it is always on the local server.
How can we download such a meeting/ session so that it can be listened offline on desktop?
Thanks & Regards,
Daman
    Jul 19, 2011 5:52 AM   in reply to Damandeep
    I have the same question. I would like to download the recoded meeting. How to do that?
    Regards,
    Valee
    Jul 20, 2011 9:44 AM   in reply to Valeeswaran.K
    Only the HOST of the meeting can offer that option.
    The HOST has to go into Adobe Conenct Central and access their room. On Connect Central they go to the recordings tab under the room and select the recording. Once selected they can choose "Make Public" and then "Make Offline". At that stage they will see Connect Add-In launch and the meeting will play completely from start to end. It has to record that "playback" locally so the PC/Mac cannot be used for anything else while that is going on. Once completed the FLV file is located on the local PC/Mac. That FLV file can be posted anywhere for others to download. You could use the File Share POD in a public room to share the file for people to download.
    May 13, 2013 10:15 PM   in reply to Heyward Drummond
    If I don't see those options to choose from should I contact my Admin? Because I do have the option to record just can't find them afterwards.
  • Jorma Jennings
    Jul 5, 2007
    May 14, 2013 8:11 AM   in reply to SunguraGames
    The options that Heyward lists are on the server side of Connect, not within the Meeting. If you are in the meeting room, go to the Meeting menu and select the Manage Meeting Room option. Otherwise, log into the server and browse to your meeting room. From there select the Recordings link. You should see a list of all recordings that have been made in that room. In that list there will be a link to Make Offline for each recording.
