Can I do drop down menus in Acrobat Pro?
Jul 29, 2009 11:07 AM
or do I need the "Extended" Version? I've cerated a form and need a drop down menu to display percentages in 10% increments.
    Jul 29, 2009 1:35 PM   in reply to Dyan Roth
    I can't answer about the drop down menus, because I've run across a use for such and haven't explored the possibilities.
    The is no extended version on the Mac Platform. There is on PC Side. Bigest thing it contibutes is XML based forms plus other touches.
    when you go to adobe.com web site click on Acrobat and at some point there is a chart teling you what features are in each version.
    Jul 29, 2009 2:01 PM   in reply to Dyan Roth
    Of course you can do it in Pro. Use the Combo box tool from the Forms menu.
    Jul 29, 2009 2:21 PM   in reply to Dyan Roth
    Depends on what you want to do with it.
    If you just want it to have certain values, then no.
    If you want it to interact with other fields, then yes.
    Jul 29, 2009 2:26 PM   in reply to Dyan Roth
    Did you find this tool? It's under Tools, Forms, Combo box tool.
    After you select it and draw your combo box you can enter the values under
    the Options tab manually.
    Jul 29, 2009 2:38 PM   in reply to Dyan Roth
    Under Item enter 10% and click Add. Enter 20%, click Add. Etc.
    Jul 29, 2009 2:55 PM   in reply to Dyan Roth
    Make sure Sort Items is not checked and then you can sort them manually with
    the Up and Down buttons.
