Hi All,
Consider the following scenario:
BigCorp deploys thier Flash player the Group Policy Software Installation (GPSI).
BigCorp rolls out the latest version of Flash player to thier site. Although BigCorp has followed all thier testing plans, and not noticed errors - users begin to report issues with a line of business app which uses Flash.
Admins at BigCorp disable the policy which installed the latest version of Flash payer, and re-enable the previous version. Affected users reboot thier machines and they hang indefinatley at the GPSI instllation stage.
This behaviour appears to be by design, but the behaviour of the installer is not sane at this point.
I believe that this issue is caused by the feature noted at http://kb2.adobe.com/cps/402/kb402435.html - since removing HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayer\SafeVersions prevents this from happening. (Specific versions are listed, and appear to work as one might expect; i.e. remove the DWORD value at HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayer\SafeVersions\10 and earlier versions can be installed)
The reason for the indefinate wait during installation of a downlevel version appears to be that the installer is displaying a dialog box that has been suppressed by GPSI since it is, I imagine, waiting for a response from the user that it will never recieve. At this point the only way to allow the machine to complete a reboot is to either a)disonnect the network b) force the policy to fall out of scope.
Evidence for this can be obtained from the %windir%\system32\macromed\Flash\install.log; specifically the line:
MessageBox: 12582960,"The version of Adobe® Flash® Player ActiveX that you are trying to install is not the most current version. Please visit http://www.adobe.com/go/getflashplayer to obtain the latest, most secure version."
Whilst I can understand (to some extent) the design of this feature - preventing the installation of an older client in this manner is disruptive to Adobe's clients.
It would be advantageous if we could override this using an MSI property. For example the Safe Versions features is in effect, unless the notional IGNORESAFEVERSIONS property is set to 'YES'. (Perhaps Adobe could consider this a feature request?)
This would afford protection for the maximum number of customers, but allow users with a business need to roll back to an older version of Flash player to shoulder the responisbility of running an older version.
http://kb2.adobe.com/cps/141/tn_14157.html is NOT a sensible solution for customer who are relient on GPSI for Flash Player installation. Repeatedly running the downloadable uninstaller is not a sane thing to do, as far as I can tell.
I've only tested this with the Adobe supplied MSI (not the in-browser installer) as I have thousands of machines to deploy this to.
Does anyone else have issues with this, and how do you get around them?
Apologies for digging up this thread but this issue has meant that I haven't deployed any updates to the Flash Player ActiveX since 10.0.45.2 for fear that it'll break my whole GP software deployment.
Firstly, I don't think Adobe will ever do 'the right thing' and introduce a new MSI property to make the install ignore any existing SafeVersions registry keys because I don't think they can; the actual ActiveX install is a custom action that calls an external executable embedded within the MSI that doesn't use Windows Installer technology so it wouldn't be aware of any MSI properties.
However, I've recently revisited this problem and I think I may have come up with a solution.
The trick I've employed is to ensure that the HKLM\Software\Macromedia\FlashPlayer\SafeVersions registry key gets removed during the MSI uninstall routine. To do this you need to modify the MSI to add a new row into the Registry table.
You can do this by generating a transform using Orca, like so;
Registry = [any unique value you like]
Root = 2
Key = Software\Macromedia\FlashPlayer\SafeVersions
Name = *
Value = [Blank]
Component = ISRegistryComponent
The important bit is the asterix against the Name value. This tells the MSI to always remove that registry key upon uninstall no matter what existing values are contained within the key. Once that key is gone you can install any other version of Flash Player you like, even older versions.
This whole method of deployment relies on a couple of things to work though;
One last thing to note though is if you've already assigned Flash Player using Group Policy you can directly modify the install_flash_player_10_active_x.msi that was used to include the above registry row (ie, not using a transform) and then re-deploy it. This ensures that the SafeVersions key will be removed right from the start if it is ever uninstalled. Of course, if any of your users have manually upgraded to a newer version since then this won't work - in that case you'll have to remove the SafeVersions key manually, perhaps using a VB script (ideally at machine shutdown).
I hope this information helps anyone who's had a headache with deploying Flash Player through Group Policies.
Cheers,
Zinc
Message was edited by: Zinc666
