OK I'm sure this has been done before but after much web searching I'm totally stuck.
I have been asked to create league for the local Rugby Club so created two tables:
LeagueTeam:
LeagueTeamsID int(11) PRIMARY
TeamName varchar (40)
Season int(11)
LeagueResult:
ResID int(11) PRIMARY
LeagueID int(11)
SeasonID int(11)
hteam int(11)
ateam int(11)
hscore varchar(3)
ascore varchar (3)
I have looked around the internet and found the following Query which seems to do what I want but, not being too good with MySQL queries I need a lot of help
SELECT TeamName AS Team,SUM(P) AS P,SUM(W) AS W,SUM(D) AS D,SUM(L) AS L,
SUM(F) AS F,SUM(A) AS A,SUM(GD) AS GD,SUM(Pts) AS Pts
FROM(
SELECT
hteam LeagueTeam,
1 P,
IF(hscore > ascore,1,0) W,
IF(hscore = ascore,1,0) D,
IF(hscore < ascore,1,0) L,
hscore F,
ascore A,
hscore-ascore GD,
CASE WHEN hscore > ascore THEN 2 WHEN hscore = ascore THEN 1 ELSE 0 END PTS
FROM LeagueResult
UNION ALL
SELECT
ateam,
1,
IF(hscore < ascore,1,0),
IF(hscore = ascore,1,0),
IF(hscore > ascore,1,0),
ascore,
hscore,
ascore-hscore GD,
CASE WHEN hscore < ascore THEN 2 WHEN hscore = ascore THEN 1 ELSE 0 END
FROM LeagueResult
) as tot
JOIN LeagueTeam ON tot.LeagueTeam=LeagueTeamsID
GROUP BY Team
ORDER BY SUM(Pts) DESC, SUM(GD) DESC
When I run it in DreamweaverCS3 I get a #1111 invalid use of group function.
When I run it in phpmyadmin the error message occures on the line starting " SELECT ateam, 1, "
Please can anybody help me to get this working in Dreamweaver or suggest another way of doing it?
First, I see an error with SUM(Pts) as you have defined it as uppercase PTS in your derived table. I would also suggest that you use a different alias for your summed values than their original values. For example, use something like SUM(D) AS Sum_D.That probably isn't causing the query to fail, but it is ambiguous.
If you are still having problems, I would start by testing the derived table query to make sure it does not contain any syntax errors.
Thanks bregent I will try that on monday when i get back to work and let you know
I have also been told that it may be something to do with
>as I was saying I have been told it may be something
>to do with the version of PHP not allowing sub selections??
OK, first it would have nothing to do with the verison of PHP. Possibly they meant MySQL. This is not a sub-query it is more commonly known as a derived table. AFAIK, MySQL started support of derived tables in 4.1. What version are you running? I have also heard that there are a lot of problems with derived tables in MySQL so you just might want to use a view instead.
OK thanks for all your help on this bregent .
mySQL version is: 4.1.22-standard
As I said I am not brillian with mySQL (I can do basic queries and sorting) so I have not come across VIEW before.
How would that work in this situation, could I still use VIEW to ceate my results from the tables i have in place?
Sorry to be a pain but I feel i'm getting close and this is the last thing I need to finish.
I don't know if this would be cheating, but have you tried setting it up in Access and then viewing the query as an SQL view. You can cut and paste this into your work then and the difficult work is done for you.
Alternatively, you could change codes to Union. I am sure that would be a lot easier. ![]()
If you dont have a version of Access, let me know. I might be able to throw something together for you in there. I dont have MySQL as I tend to go down the Access and asp route I am afraid so can't really help with all the other stuff. I have a book called Dreamweaver Demystified which I find really good. Mine is the MX 2004 version but I am sure that Adobe will have sorted out a CS3 or CS4 version as well.
Good luck with it
Simon
OK changed to a server with 5.1 so now I put the query in Dreamweaver pressed Test and, Presto got this:
Hooray it works perfectly . . . or so I thought!
when i try to access the Recordset from Dreamweaver's Bindings tab I get the following message?
MySQL Error#: 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ') as tot, LeagueTeam
WHERE 0 = 1 GROUP BY Team' at line 1
It seems to be including a WHERE statement?
it also runs when i test it in MySQL on the servers so we must be looking at a Dreamweaver problem here, any Ideas, I'm so close I can taste it!!
Changed Team to TeamName and got the same error ![]()
Do you think its something to do with 'tot' or tot.
Thanks for sticking with me on this one bregent if I knew were you lived I'd buy you a beer!
Bacca
Not really sure why DW is balking. Some things to try
1) Make sure you have renamed PTS in the derived table so it is consistent with the naming in the outer query.
2) Don't use alias names that are the same as column names. Rename them!
If neither of those is the issue, I would go ahead and turn the derived table into a View. It will be easier to read and manage the SQL and make troubleshooting easier.
OK Bregent this is where I am,
I discoverd if I ignore the error from dreamweaver and go straight into the code and bind a column to the page using the following syntax:
<td><?php echo $row_rs_Results["Team"]; ?></td>
<td><?php echo $row_rs_Results["P"]; ?></td>
<td><?php echo $row_rs_Results["W"]; ?></td>
<td><?php echo $row_rs_Results["D"]; ?></td>
<td><?php echo $row_rs_Results["L"]; ?></td>
<td><?php echo $row_rs_Results["F"]; ?></td>
<td><?php echo $row_rs_Results["A"]; ?></td>
<td><?php echo $row_rs_Results["GD"]; ?></td>
<td><?php echo $row_rs_Results["PTS"]; ?></td>
(rs_Results being the name of the Redordset I created) the page displays the correct information ![]()
So here is the final Query
SELECT TeamName AS Team,SUM(PP) AS P,SUM(WW) AS W,SUM(DD) AS D,SUM(LL) AS L, SUM(FF) AS F,SUM(AA) AS A,SUM(GLD) AS GD,SUM(PNTS) AS PTS
FROM (
SELECT hteam LeagueTeam,
1 PP,
IF(hscore > ascore,1,0) WW,
IF(hscore = ascore,1,0) DD,
IF(hscore < ascore,1,0) LL,
hscore FF,
ascore AA,
hscore-ascore GLD,
CASE WHEN hscore > ascore THEN 2 WHEN hscore = ascore THEN 1 ELSE 0 END PNTS
FROM LeagueResult
UNION ALL
SELECT ateam,
1,
ascore, hscore,
ascore-hscore,
CASE WHEN hscore < ascore THEN 2 WHEN hscore = ascore THEN 1 ELSE 0 END FROM LeagueResult
) AS T
JOIN LeagueTeam ON T.LeagueTeam=LeagueTeamsID
GROUP BY TeamName
ORDER BY SUM(PNTS) DESC, SUM(GLD) DESC
I have just one more request, I need to only choose the results that correspond to the latest season, here is the results table showing SeasonID
LeagueResult
LeagueID int(11)
SeasonID int(11)
hteam int(11)
ateam int(11)
hscore varchar(3)
ascore varchar (3)
The seasonID will be passed via a url variable called SeasonNow .
I'm know I need a: SELECT SeasonID and also a WHERE SeasonID = SeasonNow
How do incorporate this into my recordset without messing up what is already working?
hope that makes sense.
Bacca
This one is now sorted. Many, many thanks to Bregent - you were a great help.
For those who come across this problem in the future I will leave the final query:
SELECT TeamName AS Team, SUM(PP) AS P,SUM(WW) AS W,SUM(DD) AS D,SUM(LL) AS L, SUM(FF) AS F,SUM(AA) AS A,SUM(GLD) AS GD,SUM(PNTS) AS PTS
FROM (
SELECT hteam LeagueTeam, 1 PP,
hscore FF,
ascore AA,
hscore-ascore GLD,
FROM LeagueResult
UNION ALL
SELECT ateam, 1,
ascore,
hscore,
ascore-hscore,
FROM LeagueResult WHERE SeasonID = SeasonNow
) AS T
GROUP BY TeamName
North America
Asia Pacific
