tnewland82
Adding Closed Captioning to Single Text Caption (Version 4)
Aug 6, 2009 6:22 AM
I have created a CBT that has a number of audio files that now require Closed Captioning. However, rather than having the "blanket" audio file for the entire slide, each text caption on each slide has its own audio file.
Is it possible to add closed captioning to a single text caption audio file? I know it is possible for a "blanket" audio file, but I need to do it for single text captions. If not, does anyone know of a work around to this issue?
Thanks!
    Aug 6, 2009 6:32 AM   in reply to tnewland82
    Hey there,
    No unfortunately it isn't. In order to use CC text is has to be added to the Slide rather than an individual object. The only workaround I can think of would be add audio files containing silence to each of your slides, this should then enable you to add the CC text.
    If you feel that you should be able to use CC's with objects such as Captions then please file an enhancement request using the web address I have included below.
    Adobe Captivate Feature Request/Bug Report Form
    Best - Mark
    Visit the macrofireball blog
    Aug 7, 2009 7:45 AM   in reply to tnewland82
    Hi there
    This is the first time I have ever used CC so I could just be lost, but would appreciate any and all help
    So you may not realize that the CC doesn't simply appear on its own during playback. You (or more accurately, your user) must first click the CC button to make the CC area appear.
    Or, with Captivate 4, you can use an advanced action to open the CC area automagickally.
    Cheers... Rick
    Helpful and Handy Links
    Captivate Wish Form/Bug Reporting Form
    Adobe Certified Captivate Training
    SorcerStone Blog
    Captivate eBooks
