Nodya
Remove Adobe Logo (7.0)
Jul 28, 2008 3:24 PM
I can't remove the adobe logo in presenter 7. I tried to modify the vconfig.xml file w/ my modify logo but nothing works!
Any ideas? Thanks for your help in advance
    Jul 29, 2008 10:06 PM   in reply to Nodya
    These are the steps to change the logo as described in Help file
    1. Create a new file named logo.swf(The ideal size for the finished logo.swf file is 47 x 27 pixels) that contains your custom branding.
    2. In Windows Explorer, navigate to the templates folder where Presenter 7 was installed.
    3. Add your custom logo.swf file to the Templates folder.
    4. In PowerPoint, publish the presentation to your computer.
    5. View the output to see the new logo.
    May 3, 2010 2:00 PM   in reply to kathita_goel
    How do I remove the
    "Adobe Presenter" during loading....
    Jun 15, 2010 1:04 PM   in reply to Global Video
    The following is from: http://www.adobepresenter.info/page/2/.  The first set of instructions is to modify individual presentations.  The second set of instructions will basically set the default for subsequent presentations.
    1. Open a presentation in PowerPoint, and save and publish the presentation to your computer to copy the files locally.
    2. In Windows Explorer, locate this folder:
         c:\Documents and Settings\username\My Documents\My Adobe Presentations\PresentationName\data
    3. Open the vconfig.xml file in an XML editor or Notepad. Scroll down about one-half page to the <language id=”en”> section, and type this code on a blank line, inserting your custom text as the value:
    <uitext name="ADOBE_PRESENTER" value="Insert Your Custom Text"/>
    4. Save and close the vconfig.xml file.
    5. Open the index.htm web page holding the presentation, located here:
    6. When the page opens, view your custom text as the presentation loads.
    Rather than leaving the default Adobe Presenter preload text, or customizing the text for each presentation, you can modify an Adobe Presenter program file to change the text for all your presentations. Here’s how:
    1. Locate the Themes folder on your hard drive.On Windows XP, in Windows Explorer, find the folder here:
         c:\Documents and Settings\username\Local Settings\Application Data\Adobe\Adobe Presenter\Themes
    On Windows Vista, from the desktop click Start > Run and type the following command:
         %LOCALAPPDATA%\Adobe\Adobe Presenter
    Click OK to close the Run dialog box and open the folders; double-click the Themes folder.
    2. Open the language.xml file in an XML editor or Notepad.
    3. Look for the <language id=”en”> section near the start of the file, and type this code, inserting your custom text as the value:
    4. Save and close the language.xml file.
    5. Back in PowerPoint, save and publish the presentation to your computer, selecting the View Output option.
    6. Test the new content.
    Oct 9, 2010 1:58 PM   in reply to Stevebar5118
    didnt success to remove the "Adobe Presenter" text in the start intro.
    i did exactly  what you wrote and it’s the same= shows the "Adobe Presenter" text in the start screen.
    any ideas?
    rami
    Sep 13, 2011 7:59 AM   in reply to Stevebar5118
    Hi there,
    I've recently tried this with Adobe Presenter 7.07.
    The preload text changes to what I've specificed in the XML file, however, it doesn't go past the loading page it just sticks on the preloader page, if I remove the line it shows the "Adobe Presenter" text and works fine. Have you experienced anything similar before. Am I doing something wrong.
    Many Thanks for your help
    Tim
    Sep 16, 2011 2:56 AM   in reply to lamberttg
    Hi Tim,
    Yes, you are correct adding tag <Uitext="ADOBE_PRESENTER" value="custom name" > in vconfig file is not working. This is an issue in Adobe Presenter and we will surely try to fix in our next release.
    Thanks & Regards,
    Shubhi
    Oct 3, 2011 1:06 AM   in reply to Nodya
    Hi
    I try to remove the LOGO, but it seems it does'nt work.
    I did as descibed under:
    I Createed a new file named logo.swf
    In Windows Explorer, Inavigated to the templates folder where Presenter 7 was installed. (C:\Program Files (x86)\Adobe\Presenter 7\Templates)
    I added the logo.swf file
    And I published my powerpoint presentation.... the Adobe logo is still there!!!
    Anne Siv
    Oct 3, 2011 2:01 AM   in reply to Anne-Siv
    Hi Anne,
    I am sorry, but we know that this is a issue in Presenter 7 and we will be fixing this in our new release.
    regards,
    Shubhi
    Oct 3, 2011 4:37 AM   in reply to VideoPep
    Thanks Shubhi
    Hope the new release will be soon then???
    Regards
    Anne Siv
    Dec 7, 2011 11:40 PM   in reply to VideoPep
    Do we have any dates yet as to when the new release will be out?
    Dec 7, 2011 11:41 PM   in reply to Fordyboy75
    ALERT,  I will be back in the office  December 20th, 2011.
    for rush digital requests please contact Maria Manouk :
    Maria_Manouk@GlobalTotalOffice.com
    Jan 26, 2012 10:07 AM   in reply to Nodya
    Will this ever be fixed? I am unable to change the logo, make it link to something, or change the loading text with v7.0.7.
    Jan 26, 2012 10:08 AM   in reply to jlcts2
    out of office due to family emergency
    Sep 12, 2012 12:16 AM   in reply to VideoPep
    Hi
    I do now have Presenter8
    The logo.swf file is set to 47 x 27 pixles. But it is to big and it shows over the "Play" button. Logo.jpg
    Any suggestions?
    Regards
    Anne Siv
    Sep 12, 2012 12:41 AM   in reply to Anne-Siv
    Hi Anne
    Can you please mail the swf to me?
    My mail ID is mkalyanp@adobe.com
    Regards
    Mahesh
    Sep 12, 2012 1:05 AM   in reply to mkalyanp
    Fra: mkalyanp forums@adobe.com
    Sendt: 12. september 2012 09:41
    Til: Anne Siv Sivertsen
    Emne: Re: Remove Adobe Logo (7.0) Remove Adobe Logo (7.0)
    created by mkalyanp<http://forums.adobe.com/people/mkalyanp> in Adobe Presenter - View the full discussion<http://forums.adobe.com/message/4692158#4692158
    Sep 12, 2012 4:35 AM   in reply to Anne-Siv
    The other logo (the one in presenter information) why is it not possible to use a .psd file? I want the background to be transparent.... Are there any other way to do that? And what size should the file be? No matter what i try it seem blury...
    Anne Siv
    Sep 12, 2012 4:49 AM   in reply to Anne-Siv
    I found a soloution to this... I saved the the original logo file (a .ps file) to an .png file. And it works
    Anne Siv
