Image quality in Robohelp
Aug 17, 2009 12:40 PM
I have a linked Framemaker book with images throughout. The image quailty in the finished Robohelp Webhelp html isn't very good.
What are the "best practices" etc. that will get me decent image quality?
Also, how can I get an image to spawn a larger version of itself when clicked?
Regards,
RP
Branched to a new discussion.
Replies 1 2 Previous Next
    Jan 11, 2010 7:59 AM   in reply to Rick Poole
    Did you ever get the answer to this question? I am in the same boat.
    Jan 11, 2010 11:04 PM   in reply to techpubsmistress
    I've moved the thread to the correct category hoping that will get you an answer. It might help to know the format of the images you are putting into FM, whether they have been scaled and so on.
    Follow me @petergrainge
    Jan 21, 2010 10:02 AM   in reply to Rick Poole
    Seems the RH developers would rather you manually import every file a second time after you
    parse it into an RH project. I have never been able to import from any source and retain image quality - that's not allowed.
    Jan 25, 2010 6:28 AM   in reply to jeff.g
    I have the following software versions:
    Robohelp 8
    Framemaker 9
    I have made many tests on a documents in which several figures are inserted. The results are the following:
    1. Never insert PSD figures inside framemaker: results in Robohelp are very bad (very low resolution),
    2. I have inserted the same capture screen inside several anchored frames using different formats: best is BMP, but very close to JPG. Thus, it is better to use JPG as the file is lighter.
    3. The very bad situation occurs in the most popular configuration: a graphic image (for example jpg) with annotations in the same anchored frame. The result is VERY BAD, NOT USABLE!  In fact, this mix produced an excellent annotations resolution but very bad image (bitmap) resolution.
    I have tested it in all possible configurations: all graphics format in FrameMaker, all format by importing to Robohelp, and also using the "group", "ungroup" annotations and image from FrameMaker ....  results are the same ....
    Who has a new idea to make the graphic mix (framemaker annotations + image bitmap in FrameMaker anchored frame) usable in RoboHelp ?
    Jan 25, 2010 11:36 AM   in reply to Rick Poole
    Hope that the following helps (well,maybe...). The RoboHelp 8 Help states:
    To maintain the original quality of images, insert them in FrameMaker documents by reference. RoboHelp copies the referenced images directly from the source if the complete image is visible inside the anchored frame. Similarly, if the images are large, insert them in the source document by reference.
    This is working for me with FM 8.0p277 and RH 7.0.3.001. All of my original image files are copied into the Help folder and are used.
    However, the unstated message is that if you have graphics created in FM, or not imported by reference, or partially cropped by an anchored frame, you won't be able to maintain the original quality. Whether it would be worth it to people with those situations to create new graphic files and import them by ref. into their FM files is going to be an individual call based on several project factors. :-(
    --Gloria Mc
    Jan 26, 2010 1:31 AM   in reply to Gloria Mc
    Thank you for your answer.
    In fact I always import the images by reference. Usually FrameMaker is mainly used for technical manual and in this, the image (technical photos or capture screens) are used with the writer comments. These comments are, of course, made directly from the FrameMaker layout. The sad situation is that the results to RoboHelp is not usable: the comments are well transfered but the image has a high resolution loss.
    You will find, on the attached file, an example of this situation: even on a capture screen (from RoboHelp result) you will immediately see the difference. I precise that both figures (identical software capture screens) have been inserted to FM9 by reference.
    Who has find a solution ?
    Jan 26, 2010 1:25 PM   in reply to NicPervy
    Until/unless Adobe provides better graphics processing capability, the only solutions I know of are to a) find another Help tool that does a better job (both WebWorks and Flare import Frame files; do not know how their graphic quality is for this situation), or b) create your graphics in a graphics program that will properly create a combination of screen capture and callouts (lines, text, etc.) into a single .gif, etc. graphic (even simple PowerPoint or RoboCapture do decent jobs), then import that graphic.
    Feb 5, 2010 1:16 AM   in reply to Rick Poole
    Rick
    I wonder if you have access to anyone who could write a RH8 script to do that?
    Also try a search. Something is nagging me that someone did post such a script.
    @petergrainge
    Feb 5, 2010 8:37 AM   in reply to Rick Poole
    Rick
    I am trying to debug this problem, too. I tried your suggested fix, but now all my images are gone from the help (even though they appear in RH). Ideas?
    Feb 5, 2010 2:37 PM   in reply to Rick Poole
    I agree.Sounds like a bug.
    Feb 12, 2010 6:59 AM   in reply to Rick Poole
    This same thing happened to me. I posted on every available forum and no one could offer a solution. I think it is definately a bug. The only thing that brought my images back was to open a new project. Make sure to save your settings in the original project first and load them into the new RH project.
    Missy
    Feb 12, 2010 7:00 AM   in reply to Rick Poole
    Oh, I forgot to add...The only acceptable format for me in both FM and RH is .png.
    Feb 12, 2010 9:58 AM   in reply to Rick Poole
    HI Rick Poole,
    May you please provide me with the detailed workflow or steps so that i can try to reproduce the issue at my end. How are you creating the FM document? Are you using Anchored Frame? Are you using Text Frame tool to create Text Frame over the image? And how are you bringing that document into RH?
    Please provide as mush details as you can as it would help me in my research on this.
    Feb 16, 2010 5:47 PM   in reply to Rick Poole
    Hi Rick
    Sorry I've gone quiet. I'm fighting a broken cross ref problem. And I
    haven't gotten a satifactory answer. Not sure what I'm going to do.
    You've captured the image problem nicely.
    Deborah
    Feb 17, 2010 5:45 PM   in reply to Rick Poole
    Thanks, Rick. I'll have to do the same. I'm in the midst of hand tooling a
    few other things to get the behavior that I want. The images are next. I
    have a beta deadline Friday...sigh.
    Feb 18, 2010 2:16 PM   in reply to Rick Poole
    Hi Rick
    I need a sanity check. I'm not getting this to work. How exactly did you
    reset each image in RH? Also, many of my images are in DropDownCaption. Did
    you have that? Did this fix work for those, too?
    Deborah
    Feb 19, 2010 7:59 AM   in reply to Rick Poole
    Hi Rick
    Can you tell me how you resized the images and got them to work?
    Deborah
    Feb 19, 2010 9:12 AM   in reply to Rick Poole
    Thanks, I'll give it a try shortly...
    Feb 19, 2010 10:15 AM   in reply to Rick Poole
    Rick
    Sadly, that did not work. In fact, when I reopened the Size dialog box, the
    preferred width and height checkboxes were checked again. The images I have
    the most trouble with are in DropDownBody DHTML. I'm not sure if that's the
    problem, although some work fine.
    Also, I have two images that disappear completely, leaving appropriately
    sized white space. Have you seen this?
    Deborah
    Feb 19, 2010 10:28 AM   in reply to Rick Poole
    sigh...ok, thanks. It was worth a try.
    Feb 22, 2010 10:02 AM   in reply to Rick Poole
    Hi Rick,
    Is this still the only solution - to touch every image in every HTML file? Seems crazy if you have hundreds of images. I was just wondering if there is another solution/alternative coming from what you may have heard.
    If you do this, what happens if your FM book is linked by reference into RH - when you update the RH book, does it undo all the manual changes you've made?
    Adriana
    Feb 22, 2010 11:19 AM   in reply to Rick Poole
    Just tried it now (thanks) - it does not do anything for me. Too bad- it could be my solution! I posted in that other thread that I couldn't get the script to work- perhaps the writer will reply?
    Adriana
    Jun 17, 2010 10:16 PM   in reply to adrianaharper
    Can anyone attach the script that is not working an
    d if it a JavaScript I will be able to figure out the issue and might be of some help
    Jun 18, 2010 7:20 AM   in reply to Rick Poole
    This is not script related but I thought I could share one experience with image quality when linking FM9 files in RH8.
    The FM book originally referenced images of many different formats and I noted that some images were liked just fine into RH but some got down-sampled and bacame useless. I realized that the ugly images were TIF and EPS files that had been automatically converted to JPG. I think I have tried every possible combination of settings in the Import Image dialog but no luck.
    The only solution I could find was to replace every TIF and EPS file in the FM book with a corresopnding JPG that I had converted manually myself. When every image in the FM book was converted to either BMP or JPG, the RH image quality was acceptable.
    Jul 14, 2010 1:51 AM   in reply to anderics
    Hi Anderics,
            can you share one of the small FM file set along with the image (of format EPS or TIF) which is showing up a lossy conversion
1 2 Previous Next
Actions
