jslatte
Indesign CS4 won't open
Aug 19, 2009 7:41 PM
I just installed the CS4 creative suite, and everything works but indesign. When I click on it in applications it instantly says that it quit unexpectedly. I tried the trial before purchasing and installing the software and didn't have any problems. I have a mac.
    Aug 20, 2009 4:51 AM   in reply to jslatte
    Did you uninstall the trial before installing the suite?
    Aug 20, 2009 5:16 AM   in reply to jslatte
    Delete chache.db in Library/Application Support/Adobe/Adobe PCD/cache and it should give you the option to insert a your serial when prompted.
    Aug 20, 2009 5:23 AM   in reply to jslatte
    It should fix the whole suite as it is the workround to the licence expire bug and you will be able to use the whole suite as normal (no trials). If this fails, you may need to use the CS4 cleaner (http://www.adobe.com/support/contact/cs4clean.html) before re-installing again
    Aug 20, 2009 6:56 AM   in reply to jslatte
    It's located in Hard Drive > Library > Application Support etc. not Users > Home... or at least it is on mine!
    Aug 20, 2009 7:03 AM   in reply to jslatte
    Yay!
